Next Toyota Prius to get electric all-wheel drive
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by jsfabb, Nov 19, 2012.
  1. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
    If rumors are to be believed, big changes are in store for the next Toyota Prius. UK outlet Auto Express recently spoke with a Toyota engineer who leaked details concerning the development of the popular hybrid's successor. According to that engineer, "The next Prius will redefine the hybrid as we know it."
    JMD and wjtracy like this.
  2. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    I guess the front-rear wheel drive electric motors make sense. Rear wheel drive is limited to 37 mph, but I wonder if they will utilize both motors while taking off from a stop? I know the Atkinson (sp?) ICE is lacking in torque, so 2 electric motors would really get it up to speed quick.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Sounds like a really goofy rumor. I think it's possible that Toyota might sell an AWD/e-4WD version or make it an option, but I doubt they'd want to make it standard across all models. Seems like extra cost and weight to me.
    After all, Prius is the top selling car in CA, yet most of us in CA don't need AWD/4WD. And, Toyota's sold millions, despite them being FWD.
    JMD and telmo744 like this.
  4. austingreen
    austingreen Senior Member
    13,531
    4,062
    Austin, TX, USA
    The launch is really determined by the battery, which has much less power than the motor. Unless the awd version has a more powerful battery, it will mainly be for traction in rain/mud/snow - still that is what kept my cousin in snowy upstate ny from buying one.
    The rumor was a e-awd option. The base gen IV prius is supposed to still be fwd with a nimh battery, although in the last interview toyota declined to comment on the battery. The weight is supposed to drop around 150 lbs.
    lensovet likes this.
  5. bwilson4web
    15,389
    I started to reply but got hung up on:
    The "37 mph" gave it away.
  6. austingreen
    13,531
    4,062
    Austin, TX, USA
    lol. I don't believe that is a fixed number but only a proposed one. I'm guessing that is an engineering goal for efficient operation of the motor from 0-60 kph. It may be the same motor as mg1 or mg2 with fixrd gearing to the rear wheels. Again only a rumor, on two sites, then many copied them. Its the internet.
    bwilson4web likes this.
  7. wjtracy
    wjtracy Senior Member
    11,311
    3,588
    Northern VA (NoVA)
    ...well you can't beat 75 MPGr is a lot better than 100 MPGe
    r = really
    e = excu-u-u-se me
  8. hill
    8,064
    Toyotas have had their faux 4WD/AWD since late 2005 ... introduced via our 2006 RX-400h Lexus. Later - they put in in to hyhi too. It's a far cry from the real traction one gets in a jeep with 2 positraction axles. Even with studs, we've still had traction loss on our 400h. And most of us know what can happen when the hsd spins up with no tracion.
  9. austingreen
    13,531
    4,062
    Austin, TX, USA
    I hope there will be improvement in those 9 years - 2005-2014:) It may be just a check box though, or might not even make the car:( I haven't a RXh or other Toyota faux eAWD. Theoretically an electronic system should be able to react faster than a mechanical one, but that requires good sensors and software. Additional weight and cost should be lower than a mechanical system also. Has anyone driven the latest model RXh or HiHy to tell if its improved?
    Perhaps toyota will provide it as part of a handling package with lithium - perhaps required for taking the extra regen, and better traction tires.
  10. Former Member 68813
    3,524
    981
    US
    Here is the new rumored Prius:
    from: New 90mpg, 4WD Toyota Prius shapes up | Auto Express
    If Toyota steals some engine features from Mazda's DI Skyactiv technology, converts it to Atkinson cycle and combines with hybrid, more power and 60-70 MPG EPA is doable.
  11. Tideland Prius
    16,063
    A 4wd-i version would help sell in the northern states and in Canada as well as snowy areas of Japan (Hokkaido region?). It'll weigh less than a traditional AWD setup and theoretically the mpg loss should be less. I don't see the problem having it limited to 37mph as it's meant for light duty anyway. In addition, would having a 3rd elec. motor help with regen? IOW, they can increase the amount of braking power by having two elec. motors slow the car down. hill, what are you thoughts?
    I do like the idea that they're pushing the boundaries. I've always thought of the Prius as Toyota's testbed for the latest and greatest in hybrid technology before it filters down to the other vehicles. Toyota has always surprised us with each new generation of the Prius (SKS, bluetooth and nav in 2003 and PCS/DRCC/LKA/updated SKS in 2009 along with the significant updates on the hybrid powertrain).
    The move to stick with NiMH could mean Toyota is trying to keep costs down, looking to gain mpg elsewhere such as weight loss. Maybe they think there's more to gain there than using Li-Ion?
    I know Honda's moving to Li-Ion (see the updated 2013 CR-Z) but they can do that as IMA costs less than HSD and the smaller li-ion battery needed would have a smaller incremental cost (I think) than if Toyota were to switch over.
    lensovet and dbcassidy like this.
  12. fuzzy1
    10,038
    I thought that regen was already limited by the battery charge rate, not the motor. So my guess is that the additional motor, alone, won't help.
  13. Tideland Prius
    16,063
    Ahh ok, darn.
  14. hill
    8,064
    Zero% Chance the next gen Prius will look like this. So trust me. Before the 2010 was revealed -they had so many lame a$$ pictures of what the Gen III was supposed look like - it was ridiculous. Even after they previewed/revealed the gen III to a handful of us PC'rs ... folks continued to publish wackey concept pictures of how the prius was supposed to be. I'm sure the goofy pictures will continue ... just like before.
    SGH-I717R ? 2
  15. markabele
    5,084
    1,782
    Nebraska
    Ya, I remember early Volt concepts made it look like a freakin futuristic sports car.
    I doubt they stray a ton from the "Prius look."
  16. austingreen
    13,531
    4,062
    Austin, TX, USA
    That is true, but there is nothing that says the 4wd version won't have a lithium or higher power nimh battery to take advantage of it. That would also give it more hp, which may be a selling point.
  17. hill
    8,064
    Typically more power means more cost. As it is, Dianne says there's no chance that the V will ever come in a PiP version ... too expensive. If that's the case, logic follows more power (bigger pack?) would make cost infeasible.
    SGH-I717R ? 2
  18. austingreen
    13,531
    4,062
    Austin, TX, USA
    Ford is saying that their li in the fusion is 30% less expensive than the nimh that panasonic was selling them.
    We are talking 2015 when this beast goes on sale. I would expect it to cost Toyota about $400/kwh. A 1.3 kwh lithium should have about 20% more power than a nimh and likely a 20% larger SOC in management, if it costs toyota $520, how much cheaper could that nimh possibly be? $100? I don't know the mark up, but I would think that would be reasonable to pass along to the customer. If the car is built in North America, a lithium pack should be at a lower cost to toyota than nimh.
    As to Diane being privy to whether toyota is going to come up with a prius v phv in 2015, that is doubtful. Sales people don't get informed. The car magazines will no before the car sales person.
  19. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    AWD drive plug-in getting 70-100 mpg (20EV mode for me) for my driving would get my business in 2015. Right now I'm leaning toward the Fusion plug-in, a good looking hybrid with many of the safety options Toyota charges thousands for offered standard, auto/on/off lights, DRL's, auto night mirror.
    But AWD drive hybrid/EV, 100mpg, it's the ultimate driving goal.
  20. richard schumacher
    7,663
    1,038
    United States
    Forget that restyling junk. An option for using the Prius as a whole-house backup generator would be useful.
