No guages?
Discussion in 'Prius c Main Forum' started by JAlessi, Apr 24, 2012.
  1. JAlessi
    JAlessi New Member
    New York
    New 2012 Prius C owner, it's also my first Toyota. I really love my new 'C', but I'm always worrying that I'm accelerating to hard, it's difficult to tell without a tach gauge. I commute 78 miles to work each day (156 mile round trip), and I get great gas mileage... somewhere between 55 and 63 mpg. Does anyone else miss the tachometer or is it just me?
  2. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    You basically have two choices. Get an Android tablet and put the Torque app on it. On which you can display several gauges. Or, buy a ScanGauge where you can display 4 gauges at a time. The ScanGauge, for me, is easier to set up and use. Search for these on this forum and you will find a lot of good info.
  3. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Unless you know the exact RPM you should be at or stay under than it doesn't matter if you have one or not. The HSI indicator will tell you what you need to know until you know more about Prii and hypermiling. Then you can look into the options jbrad4 mentioned. :)
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    You can't accelerate too hard with the Prius. And you don't need a tach.
  5. JAlessi
    JAlessi New Member
    New York
    That's actually what I wanted to hear. Thanks!:)
  6. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    however...
    however, i too like a tach. my solution along with many other folks is the scan guage II. i also use it for water temp. do i have have it. no. do i choose to have and enjoy it. yup:)
  7. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    yeah.. when you're accelerating, the HSI is the best thing to really use to gauge from.
    a tach isn't really indicative of how fast you're accelerating because of the Hybrid system and how it works together.
    most times, an individual would want to read the RPM of the ICE when they're using it to see if the ICE is running high or not and using it to help with their fuel economy.. not so much about acceleration and speed.
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I do not use the tach in my scangauge for accelerating per se.
    It confirms wind speed and direction:
    1700 No wind
    1600 Tail wind
    2000 Head wind
    etc.
    and it confirms how steep hills are.
    It is much more a 'how are the driving conditions stressing the power needed to go 61 MPH' meter for me.
