1. Offline
    MTribe New Member
    Apr 24, 2008
    Palo Alto, CA
    Your Vehicle Year:
    OK guys, after a search I was unable to find anything quite like this one...
    I hear a subdued rattle from the front right suspension area when going over small bumps of high frequency. That is, manhole covers, rough roads, brick surfaces, etc, but NOT big bumps like speedbumps. No air whooshing sound in as in a similar post.
    I can't hear much difference with the windows down versus open. It sounds very similar to if you've ever had a shock loose. It rattles whenever the shock changes direction, hence being so noticeable on the aforementioned surfaces. It's quite certainly not a dash rattle or from something lightweight like trim--it sounds more structural than that. The best analogous sound I could think of would be if the hood prop rod was rattling against the unibody in the engine compartment. I don't think it's that--that's just the sort of sound it's making.
    After poking around at everything I could find, it's still there! Any ideas? :confused:
  2. Offline
    Jul 12, 2007
    10,558
    430
    Adelaide South Australia
    Your Vehicle Year:
    I had my front left McPherson strut replaced under warranty due to a rattle, fixed it right up.
    Hope this helps.
  3. Offline
    Mar 8, 2008
    9,153
    1,793
    Your Vehicle Year:
    Especially if you have more than 60K miles on your odometer it would be reasonable to find that your front struts/rear shocks need replacement. If you can raise up the car, look for any evidence of oil seepage on the strut/shock body. If you see substantial leakage you should feel comfortable replacing them.
    Even if you don't see leakage it is possible that the strut has failed. If the noise bugs you this would be sufficient reason to replace them (although this is a fairly expensive proposition.)
  4. Offline
    MTribe New Member
    Apr 24, 2008
    Palo Alto, CA
    Your Vehicle Year:
    OK, just in case it comes up in future searches, I replaced the front struts and the problem went away. So surprised it happened at 50k miles!
  5. Offline
    Mar 8, 2008
    9,153
    1,793
    Your Vehicle Year:
    Thanks for the update. Did you DIY or did you pay for this work to be done?
    If you DIY, did you try compressing the old struts manually to see how they compared to the new? I'm also interested in your parts source and the cost for this.
    If you paid for the work to be done, did you use a Toyota dealer or some other repair shop?
    I had replaced the rear shocks on my 2004 at ~30K miles because one was leaky. The car now has 53K miles and I have recently been noticing front suspension noise. Hence I am thinking about replacing the front struts. It appears that KYB aftermarket may be less expensive than buying the official Toyota front struts (also made by KYB.)
  6. Offline
    MTribe New Member
    Apr 24, 2008
    Palo Alto, CA
    Your Vehicle Year:
    Paid for a shop to do it. Got one quote for $1100 for a well-known local shop, and $450 at a shell service station, including parts. Went for the $450 and everything seems great! Wasn't able to look at old parts...
  7. Offline
    • Moderator
    efusco Troll Slayer
    Nov 26, 2003
    19,635
    881
    Nixa, MO
    Your Vehicle Year:
    Good to know...I did just search as I've been having rattling (can't tell if it's left or right). Thought it might be my BT skid plate, but I checked that thoroughly the other day and it's tight as a drum without rattles.
    The BT strut brace is, likewise, quite firm/stable feeling when I grab and shake it so I don't think it's vibrated loose or anything.
    It's odd b/c the sound makes you think you should feel something, an unsteady turn or something...but it's pretty normal feeling other than an occasional vibration in the steering wheel..
    Ugh, I don't want to replace the struts...
  8. Offline
    willchu New Member
    Apr 8, 2007
    17
    Bump +1
    For those worried about the rattle...I've had the rattle for 4 months now and didn't bother replacing the struts only because it's crazy expensive for me anyways. But it's just a noise and I haven't felt anything bad with the driving part. No vibrations...just clank clank and that's it.
    When I do get money though I will have them replaced...let's see how far I get with them.
  9. Offline
    iraqiswhack New Member
    Nov 30, 2008
    45
    places
    Your Vehicle Year:
    around the 100k mile mark on any car, have the strut mounts and bushings checked, along with control arms, springs,, etc. suspension around 100k is due for a checkup.
  10. Offline
    derh2o New Member
    May 2, 2007
    26
    I have the same problem, or at least i think i do. the rattle comes from the brakes. try going over some bumps with light brake pressure. if the sound goes away, then obviously you have the same problem I have. the dealer said no problem as calipers, etc., are a bit loose to insure the don't create undue resistance. I plan to get a 2nd opinion.
  11. Offline
    mkaliski New Member
    Apr 7, 2005
    27
    Columbus, Ohio
    Your Vehicle Year:
    I recently noticed a TSB for the 2nd Gen Prius regarding front suspension noise. It called for replacement/upgrade of ICE engine mounts. Not sure if that would help but it worth a look see.
  12. Offline
    sdtundra New Member
    Mar 11, 2008
    891
    16
    Your Vehicle Year:
    Would u happen to have a link for the TSB? Even when I handed them the sheet for the AUX TSB they said that it was fake:eek:
  13. Offline
    xsmatt81 non-AARP Member
    Mar 27, 2008
    522
    Vegas
    Your Vehicle Year:
    the only rattle I get is from the clove box, and it's empty except for the legal stuff.
    driving me nuts
  14. Offline
    DGH Thread Terminator
    Aug 13, 2006
    196
    Wales, WI
    Your Vehicle Year:
    Wow, someone with the same problem I had.
    Solution: Dealer shimmed the front pads, also added a very thick grease to hold things in place. Had to regrease them after about a year.
    All is nice and quiet, good luck to you.
    Dan.
  15. Offline
    mkaliski New Member
    Apr 7, 2005
    27
    Columbus, Ohio
    Your Vehicle Year:
    Prius Motor mount information noted below:
    TOYOTA Some Prius owners may notice a knock from the front of the vehicle, especially when driving on rough roads. In T.S.B 0300-08 issued on Sept. 18, Toyota said an engine mount attached to the transaxle was the culprit. Adding engine mount insulators should quiet things down.
  16. Offline
    mkaliski New Member
    Apr 7, 2005
    27
    Columbus, Ohio
    Your Vehicle Year:
  17. Offline
    vsasson New Member
    Jul 22, 2007
    Hackensack, N.J.
    Your Vehicle Year:
    My 2004 Prius had a leaking strut in the first year of operation and it was replaced under the warranty. But my 2007 Prius has a noise from the front left suspension that Toyota hasn't been able to fix in two service visits six months apart. I'm due for another service next month and hope they can find the problem (I have only 11,000 miles on the car). The left strut was replaced by Toyota (and the windshield, twice, which the technician broke), but it didn't fix the noise. It occurs over big bumps and sounds like a metallic hiccup. Can anyone out there help me? Coiuld it be from the steering?
Share This Page
