nosiey lifter
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jtuchol, Jul 29, 2015.
  1. jtuchol
    jtuchol Member
    141
    whitehouse,ohio 43571
    can the lifters be adjusted or shimmed up I have a 07 Prius with 189k & a nosiey lifter or valve noise?
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Prius engine has solid lifters. Valve clearance can be adjusted by changing the lifter(s) which requires the removal of camshaft(s). Are you sure the noise is from valve train?
  3. jtuchol
    jtuchol Member
    141
    not sure yet, it only makes noise when idling with no load on it, I read on the forum that can disable each coil to make sure which one it is in top end car runs good just bought at auction for a good price no lites every thing works looks like oil was just changed too.
