NY Clean Pass (HOV): Chevy Volt does not meet the emissions requirement and does not qualify
Discussion in 'Chevrolet Volt' started by usbseawolf2000, Jan 17, 2011.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    Source
    3 people like this.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Interesting, why does the 2011 HCH not qualify? I noticed these mileage figures for the 2010 vs. 2011 HCH from http://www.fueleconomy.gov/feg/sbs.htm:
    2010: 40 city/45 highway, 42 combined
    2011: 40 city/43 highway, 41 combined
    Did the 2011 HCH undergo a significant change to "lose" gas mileage or was it due to some calculation/measurement switchover?
    By that, I'm guessing (pure speculation on my part) that the 2010 mileage figured might've been obtained by conversion by formula of old (pre-MY08 method) and the 2011 had to go through the new set of tests?
    Also of note (to me) was this:
    If so, it seems that this "45 mpg" requirement is a moving target. Under the old EPA methods, the above had at least "45 mpg" for at least one of their measures. Just because the EPA did a conversion by formula doesn't meant the above cars' mileage changed.
  3. Flying White Dutchman
    4,374
    313
    i think poeple high up will make some change and the volt will be exepted
  4. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    I'm wouldn't so sure of that...
    I think the Volt will need to change to meet the requirement or the requirements will have to change drastically, which could let in a bunch more vehicles. This is the state of New York making decisions based on some (semi-arbitrary) criteria. I doubt they'd bend to the will of GM or the Federal government, if either are pushing.
  5. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    I think highway 45 MPG and SULEV emission are the requirements. Honda reprogrammed the HV battery and owners were complaining about the performance (less assist) and MPG hit. I think 2011 EPA numbers shows that older model owners were indeed correct. Highway MPG dipped below 45 MPG so it no longer qualifies. I don't think it is fair to remove 2006-2010 models since they qualified already.
    Volt is rated with 35 miles EV range. LIE HOV lane stretches 40 miles and it's gas engine is rated 40 highway MPG. Volt's emission is also ULEV (not Super Ultra Low Emission). There is no guarantee owner will have full charge either. I think it is a good call.
  6. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    In our beloved Merlin, vehicles have to have an EPA rating of 45 MPGs
    to be exempt from periodic emissions testing.
    The Gen II up to 2007 met this requirement, it was the only car to meet
    the requirement.
    However, due changes in the EPA testing procedure effective in 2008,
    2008s and 2009's do not meet the standard as the new figure is 43MPG.
    Same exact ICE/HSD, same AT-PZEV rating, etc. Go figure.
    So as it now stands pre-2008 Gen IIs and Gen IIIs are exempt.
    2008s and 2009s are not... idiotic.
    I don't expect it to ever be "fixed."
    In this case, it is not about pollution it is about revenue generation.
    FWIW, my earlier rant:
    http://priuschat.com/forums/gen-ii-prius-main-forum/79856-maryland-emissions-testing-what-joke.html
  7. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    Improvement beyond traditional is the desired outcome. ULEV most definitely doesn't qualify as that. And without a guarantee of routine plugging, dependence on the engine becomes an emission problem. Heck, just the range-reduction from winter is enough to raise red flags. After all, what percentage of FFV never use E85?
  8. fuzzy1
    10,044
    I'd say the same thing about letting SOVs into HOV lanes in the first place.
    Out here, at least, HOV lanes are about reducing congestion. There are more effective ways to reduce pollution.
  9. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    Fail.
    How could they muck up the emissions on this car?
    Did the UAW stick their fingers in the design and say "you have to use crappy engine X from plant Z or else we're going on strike. We're not going to learn to build a new engine"
    W
    T
    F
