Occasional high pitch chirp when accelerating between 25-30mph *video*
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Hamilton, Jul 27, 2014.
  1. Hamilton
    Hamilton Junior Member
    26
    Hello everyone.
    Recently upgraded from an 05 Prius to a 13 Persona Prius. Loving it!
    The 13 was used and it had about 17k miles. What I have noticed, and still learning all the new stuff on this gen 3, but while testing out power mode driving in town, occasionally I will get a high pitch whistle while accelerating after its reached maybe 5mph. The high pitch sound lasts only a few seconds and if I take my foot off accelerator it immediately stops. Sometimes it does it again when I tap the accelerator again but stops after just a couple of seconds and speeds are up past maybe 15mph.
    Weird? Never heard anything like on my 05 ever.
    Anyone else experienced this? I tried searching and found nothing similar. I would hate having to take an issue like this to a dealer because they always want you to recreate the issue and you know things never act up when you need them to.
    Thank you for your help with this. Kind regards.
  2. xliderider
    xliderider Senior Member
    7,901
    3,130
    Honolulu, HI
    Power mode basically remaps the throttle response. Other than that, not really any difference between normal and Eco mode.
    Try getting to a place where you can do full throttle acceleration in normal and Eco modes. See if you can hear the same whistling sound in something other than Power mode.
    Just guessing that you might have a vacuum leak or something that may only be heard when at higher rpm when vacuum levels are highest.
    SCH-I535
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Hmmm have you had the latest recall done?
    How loud is this high pitched sound? The car will whine when accelerated. Is it every time you floor it or just once in a while?
    My inverter blew about a year ago. It's a weak spot on the gen3 hence the recall. There was no warning to my inverter going pop other than with hindsight. A few weeks before and on a hill within about half a mile of where the inverter failed, I was in Power mode and decelerating down a hill when the car did a very loud high pitched whine similar to the low volume whine when setting off etc. It lasted about 3 or 4 seconds and then went. It did this on two occassions in about the same place if I remember. No warning lights, no performance issues.
    I wonder now with hindsight whether it was the inverter failing. It was about the same frequency of sound as the normal low pitched whine but it was very loud - about the same level as very squealy brakes.
    Are you just hearing the normal whine of a Prius or is it similar to my description?
  4. Hamilton
    26
    Thanks guys.
    I drive mostly on regular mode and hardly on power mode. Have only had the car a week though. But have only heard it on power mode. Never ever on any other mode. And it is loud enough to be noticed unless my stereo is blasting. And it's not every time I accelerate. I've tried reproducing it and can't. When it's happened that I remember, a couple of times, I've been driving about 35, slow down to turn , and begin accelerating again after the turn and it will do it. Will try other modes or pay extra attention to see if it ever does it on another mode.
    And yes it is a pretty loud high pitch noise. Not insanely loud like omg something is about to burst, but noticeable. Not your typical Prius whine from acceleration. Definitely louder and higher pitched and just for top 3-4 second ever. I have not done any recalls on it. I just got it and don't know which it's had done. Honestly I don't know much on the recalls in place right now. Will do some further reading. Can I just call a Toyota dealer with a VIN to see which recalls it needs?
    Thanks so much!
  5. Hamilton
    26
    Hello again,
    A couple of updates on the issue.
    I checked the vehicle records and it had the software update done in May by the previous owner. Is that the inverter recall you are referring to? Or is their a physical part that needs to be replaced if trouble begins?
    Sound update: My wife drove the car today and said she heard the sound this time when backing out of the driveway on normal mode when she tapped the accelerator. I am going to have to get around trying to emulate the noise in a parking lot or something. My dads been in the hospital since Saturday so Ive been staying with him overnight.
    But any other ideas or suggestions kind priuschat folks?
    Thanks again!
  6. cproaudio
    cproaudio Speedlock Overrider
    2,401
    760
    CA
    Other members have reported that in power mode the engine revs about the same or only slightly higher than normal. The extra power comes from electric motor. Hence the high pitch whine.
  7. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I'm wondering if what they're hearing is just normal. How 'loud' a sound is is subjective I guess.
    I know when my inverter failed I got a very loud high pitched whine for a few seconds whilst in Power mode going down a long incline. It was so loud I could hear it above the music and wind noise. If fact I was so concerned I posted a thread on here, but some weeks later the inverter failed answering the question :)
  8. Hamilton
    26
    Thanks guys.
    The reason I suspect it's not a normal sound is that it doesn't do it consistently. I can't even duplicate it purposely. It's pretty loud almost like air coming in at a high rate through somewhere. Did you hear the noise on more than one day GrumpyCabbie?
    But it is directly tied to the accelerator Cproaudio, because on one occasion I heard it, I let go of accelerator and it stopped, then tapped accelerator again and it did it for a couple more seconds. Could it be the electric motor doing the high pitch? That loud?
  9. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Did it twice and both times when I was going down an incline and the car was regenning in Power Mode. Never did it under acceleration for me, but I guess there are many parts of the inverter getting stressed and for me it was the regen side? Not sure how it works inside. Maybe IF (and it's a big if) your inverter is going it could be the acceleration side? Or it could be something totally innocent. When the dealers looked at my car the computer had loads of inverter error codes, though whether they were there before or after it failed is unknown.
  10. Hamilton
    26
    Thank you Cabbie.
    I may take it in just to see if any codes are on cpu regarding the inverter. If not, at least theres a record started on the matter in case something comes up later.
  11. Hamilton
    26
    Update:
    Have definitely confirmed it does it in regular mode also. Does not need to be in Power mode. Also have realized its not so much as a high pitch noise as more of a chirp that last anywhere from 1 to 3 seconds at a time. Only does it at lower speeds (under 20mph) primarily when accelerating. It almost sounds like some kind of air valve or something. I once drove in a car that had its front windshield replaced and they had not sealed it well I guess and when it went over 60mph you would get a chirping when air would get in under the glass. It almost reminds me of that a bit. A short chirp, but definitely tied to pressing accelerator.
    You guys still think its normal? Thats its electrical motor or inverter?
    I drove an 05 for 2 years and 50k miles and never heard anything similar. Maybe the Gen IIIs do this normally?
    Please advise.
    Thanks!
  12. xliderider
    7,901
    3,130
    Honolulu, HI
    Maybe a sticky PCV or EGR valve?
    SCH-I535
  13. Hamilton
    26
    Interesting. I have found a way to almost replicate it constantly. It seems to be at a very specific rpm when im accelerating between say 20-30 mph and the line is barely below reaching the power bar. Can almost do it every time and almost hold it there to make it chirp for a few extra seconds. But I cant make it last for more than 3-4 seconds. And just on initial acceleration. Could either of these valves be guilty of this? Thanks!
  14. xliderider
    7,901
    3,130
    Honolulu, HI
    If you can replicate it, take it in to a dealer and have a service advisor, or better yet, a mechanic ride along with you.
    SCH-I535
  15. Hamilton
    26
    Ok guys
    Havent had a chance to take it to the dealer. Just takes so long and I havent had the time. My dad was in the hospital for a couple days so that had me tied up too.
    But I was able to record a video of the noise. What do you experts think?
    You can view video here Dropbox - IMG_3784.MOV
  16. Hamilton
    26
    No ideas Prius experts??? o_O
  17. alekska
    alekska Active Member
    435
    138
    Atl
    Prius's invertor is basically a PWM power supply for electric motors MG1 and MG2. The amount of power is varied by modulating the frequency and width of the square wave that power transistors generate. Square wave has a lot of harmonics (is equivalent of many sine frequencies) - and some of these (lower) frequencies can fall within a hearing range of a normal person. This is what you hear - whine - under some conditions. I do not see any problem with this. Its working as it is supposed to. Some people have more sensitive ears, and they notice a higher level of the whine/hum.
    2005 inverter is slightly different design, and therefore has different frequencies (by the way I can hear weak buzz/hum in both my 2005 and 2010).
    Under the power mode in 2010 the inverter generates 650 Volt vs 500Volt in normal mode, therefore you might hear a different tone/loudness of the hum in different modes.
    Best,
    - Alex (ex-EE)
  18. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    How rude.
    There are loads of suggestions in the thread. You want to know for sure, go ask your dealer.
  19. Goneflying
    Goneflying Junior Member
    Netherlands
    It sounds like the same issue I had with my 2010 prius. It got even worse when the temperatures outside went up. Basically it was a rattle of the clamp and its coulant lines that are attached to the 'wall' under the hood in the area of where the wipers are. There is a vid on youtube too, sounds similar to yours:
    My mechanic solved this by putting some isolation material in between the clamp and coulant lines.
  20. xliderider
    7,901
    3,130
    Honolulu, HI
