Odometer Error Constant At All Speeds
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Mr Incredible, May 5, 2012.
  1. Ridder
    Ridder Member
    141
    51
    Netherlands
    I would have to get 215-45-19 wheels to compensate for 10% higher speedometer readings
  2. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    IIRC, the 205/55r 16 pretty cures most of the problems. Less than 1mph difference that I've been able to tell.
  3. RocMills
    RocMills Active Member
    789
    276
    Las Vegas, Nevada
    I've tested my speedometer against my GPS on several trips now, from 25 MPH to 60 MPH (had a brief freeway trip last week), and I did not see any difference between what my speedometer read and what the GPS reported.
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    The difference on my torque app:
    The speedometer display reads 50 mph.
    The computer reads 48 (per torque).
    GPS reads 49.
    Take the speedometer for what it's worth. Just know that if you are ever pulled over, you were really speeding. :)
  5. Mendel Leisk
    38,247
    Your speedometer reading slightly low is causing you multiple problems, LOL? To the point that you swap tires?
    Sorry, just don't understand the issue. As has been noted: it's mandated for speedo's to read low.
  6. Mr Incredible
    955
    506
    Neb
    Yes, the issue has eluded you, regardless of mandates/no mandates.
    My snow tires are 205/55's. That size has removed the speed differential to less than 1mph. Now they are off. The speed differential has returned.
    That is all.
    Carry on.
  7. Mendel Leisk
    38,247
    Our snows (195/65R15) are bigger OD than the stock 215/45R17, so we have a similar seasonal shift to our speedometer, somewhere between 1~2 percent. Sorry, but I just can't get worked up about this. Most cars on the road have a similar "error" in their speedo, again, because it's mandated.
    The car's overestimating mpg by about 8% bugs me more, but I still manage to get to sleep. ;)
    RocMills likes this.
  8. Mr Incredible
    955
    506
    Neb
    I'm not sure anyone was getting 'worked up' as much as there was simply a lot of discussion about it.
  9. RocMills
    789
    276
    Las Vegas, Nevada
    Since I don't speed, at least not intentionally, I have no problem with that. Even if I were speeding and got caught, I wouldn't have a problem paying the consequences for my choice to break the law. :)
    ztanos likes this.
  10. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    The UN document is also implemented in the Australian rules (not sure if you were including us in "Asia").
    I haven't done extensive testing but a quick test I have done had a calculated speed of 105.6 km/h when the displayed speed was 110 km/h.
    See also Speedometer accuracy - reads faster than real mph? | PriusChat
  11. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    63.36 mph vs 66 mph. That's what I've observed as well.
