Do you have fog lights on your 2010 Prius?
Poll closed Jan 24, 2010.
Yes, they came with the car as original equipment 3 vote(s) 10.7%
Yes, they are Blinglights 1 vote(s) 3.6%
Yes, they were retrofitted using all OEM parts 1 vote(s) 3.6%
Yes, they were retrofitted using some aftermarket parts 4 vote(s) 14.3%
No, I don't have fog lights 19 vote(s) 67.9%
  1. Offline
    yadax3 New Member
    Aug 30, 2009
    Message Count:
    231
    17
    Northern Nevada
    Your Vehicle Year:
    I really appreciate all of the useful information I've found on these forums regarding what options are available for retrofitting fog lights on my 2010 Prius. That said, I'm still on the fence about which option to choose so I'm hoping some of you with experience in this area can help me (and maybe others like me) make a decision.
    My needs in priority order are as follows:
    1. Functional fog lights for occasional use in heavy fog - no more than a few times per year
    2. Aesthetics - something to replace the dark gray blanks on the front of my car
    My options as I understand them are as follows:
    • Blinglights
      • Lowest cost ($65+)
      • Lowest quality
      • Easiest installation
      • More for aesthetics rather than function
      • Appearance not OEM-like
    • OEM covers + aftermarket kit
      • Moderate cost ($130+)
      • Medium quality
      • More difficult installation
      • OEM-like appearance
    • OEM parts
      • Highest cost ($500+)
      • Highest quality
      • Installation difficulty the same as using a kit
      • OEM appearance
    Here are my questions:
    1. Are my conclusions/assumptions accurate?
    2. Can you recommend a good quality kit that includes an OEM-like switch? I really don’t want something that looks cheap and/or doesn’t function as well.
    3. Is there enough difference in the quality of OEM parts and aftermarket kits to warrant the huge difference in cost? (I'm guessing there isn't but I'm trying to get a sense of the difference in quality)
    Thanks so much for sharing your time and expertise, Laura
  2. Offline
    Dark_matter_doesn't New Member
    Aug 8, 2009
    Message Count:
    469
    Seattle, WA
    Your Vehicle Year:
  3. Offline
    yadax3 New Member
    Aug 30, 2009
    Message Count:
    231
    17
    Northern Nevada
    Your Vehicle Year:
  4. Offline
    radioprius1 Climate Conspirisist
    Aug 13, 2009
    Message Count:
    1,355
    153
    Iceland
    Your Vehicle Year:
    For the interior, cockpit switch: in my opinion, the best looking switch is the OEM one. The Yaris kit switch looks the second best. The rest are a distant third (IMHO!)
    I did not want to mess around with crossing the firewall so I wired my foglights to come on when the headlights come on. After I installed them this way I never had to think of them again.
    For the fog lights and covers, I would get the OEM covers and the fog lights from the kit. You absolutely can not tell a difference between the fog lights from a kit and the OEM ones. I can't imagine paying multiple hundred dollars for the fog lights when I can get them both for $40 off ebay.
    I hope some of this helps. Basically I went with your 2nd option.
    1 people like this.
  5. Offline
    jayvee New Member
    Aug 11, 2009
    Message Count:
    341
    83
    WA
    Your Vehicle Year:
    Only possible issue is the lack of "DOT" indication on the Yaris kit's lamps. The Yaris kit does not have DOT on the lens. This could be a problem with a licensing inspector at some point. Depends on the state, their regulations, and the inspector him/herself.
    I chose to take the risk. Likely the worst that could happen is you need to find another aftermarket kit with a DOT stamp. They are out there, too, for about $70/pair, if I recall. Still cheaper than OEM, even paying for both sets.
    2 people like this.
  6. Offline
    yadax3 New Member
    Aug 30, 2009
    Message Count:
    231
    17
    Northern Nevada
    Your Vehicle Year:
  7. Offline
    Aug 8, 2009
    Message Count:
    469
    Seattle, WA
    Your Vehicle Year:
  8. Offline
    BBaggins New Member
    Aug 4, 2009
    Message Count:
    27
    Cornfields of Illinois
    Your Vehicle Year:
    I bought the Bling kit first. Installed one. They look really cheep. Nothing at all like the OEM lights. No way I'll have those things on my new car.
    Bought the Yaris kit with the OEM covers. Install was nearly the same as the Blings as you have to take off the same parts to access the mounting area.
    Happy camper now!
    1 people like this.
  9. Offline
    mgb4tim Noob
    Jul 8, 2009
    Message Count:
    1,002
    74
    Pittsburgh, PA
    Your Vehicle Year:
    that's a pretty good idea. Is there a reason NOT to have them on with your headlights (low beams only)?
  10. Offline
    Jim Calvert New Member
    Jul 30, 2009
    Message Count:
    256
    28
    Worthington, Ohio
    Your Vehicle Year:
    I don't know about the Bling kit, but the Yaris kit looks as good as the factory installed Foglights - and for only about $27 plus shipping on Ebay. My total cost for the Yaris kit plus the OEM covers (about $32 each plus shipping from www.parts.com) was about $125. You cannot tell them apart from a Prius V set of foglights.
    As for installation details, this has been covered extensively in another thread in this forum - including lots of photographs.
    Jim
  11. Offline
    Aug 13, 2009
    Message Count:
    1,355
    153
    Iceland
    Your Vehicle Year:
    I think it's illegal in Canada or something. I live in Louisiana so I'm pretty sure I'll never find my way up there!
  12. Offline
    rachaelseven New Member
    Jul 7, 2009
    Message Count:
    618
    205
    Adams, MA
    Your Vehicle Year:
    As previously mentioned, the DOT marking is the only meaningful difference between the $40 kit and the OEM lights. You're stuck with the same OEM cover/adapter thingies no matter which lights you get, unless you want to hack up the blanks and do the blinglight thing. So the only real decisions in my mind are:
    1. Do you care about DOT markings? If not, get the Yaris eBay kit. If yes, buy the OEM lights.
    2. Which wiring method to use? You have 3 main choices:
    • Factory stalk switch (my choice, most difficult).
    • Some dash mounted switch, like the Yaris switch or another similar switch, less difficult, but slightly less elegant.
    • Relay off the headlights from under the hood (no unsightly switch and all wiring in the much easier to access underhood area, no messing with dash).
    1 people like this.
  13. Offline
    silverfog New Member
    Sep 26, 2009
    Message Count:
    152
    23
    Raleigh,nc
    Your Vehicle Year:
    Best visibility in thick fog is with fog lights and sidelights only. To be forced to have headlights on at the same time sounds to me counter-productive. I used OEM kit with dashboard switch circuit only operable with ignition on. This seemed the easiest installation and also the most practical.
  14. Offline
    yadax3 New Member
    Aug 30, 2009
    Message Count:
    231
    17
    Northern Nevada
    Your Vehicle Year:
    Does "OEM kit" mean you bought all OEM parts or is there an all-OEM kit available?
  15. Offline
    Sep 26, 2009
    Message Count:
    152
    23
    Raleigh,nc
    Your Vehicle Year:
    Bought housing from one dealer and lights from another. Both refused to carry out this mod.
Share This Page
