Oil Analysis Result - 10k miles on Toyota 0w-20
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Critic, May 11, 2012.
  1. markabele
    5,084
    1,782
    Nebraska
    Think in averages though. The average Prius in the US lives in a much more temperate climate than the average Prius of Canada.
  2. The Critic
    The Critic Resident Critic
    3,193
    2,319
    CA
    I doubt it's good for the engine, but I really think that the engine will be the least of my concerns with this car.
  3. sharaty
    sharaty New Member
    Have 2014 Prius and just did first oil change at 7500 mi and sending oil in for analysis to Blackstone for the first time. Live in Wisconsin (can get to 20 - 30 below zero in winter) and drive almost exclusively highway miles - 30K a year. Would like input on using the Toyota 0W20 synthetic verses the Mobil one. Can get the Mobile one for $2.50 a quart less - but am interested in maximizing the engine life. Plan to keep car and would like run it to 250K - 300K miles. Thanks
  4. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Other than brand loyalty debates, I've never read an actual report of anyone on PC having a problem specifically caused by using Mobil 1.
    I used it in my Prius 5, in my PIP and I intend to use it in my Volt.
    If you want to go above and beyond- take a look at the TRD filters for the Prius!
  5. markabele
    5,084
    1,782
    Nebraska
    Just a short rabbit trail here...but what is the oil change schedule like for the Volt?
  6. ny_rob
    1,968
    813
    L.I.- NY
    It's got the Oil Life Indicator system- most get 7500mi on the low side to over 10,000+ miles per change.
    In cases where the ICE doesn't run for enough to wear out or contaminate the oil- it's recommended to change it at 2-year intervals regardless of the (lack of) miles on the ICE. From my driving habits (1.5 full work weeks commute, 550mi on the ODO) the ICE hasn't started since I bought the Volt- so I'll be changing the oil at the 2 year anniversary it seems.
    markabele likes this.
  7. markabele
    5,084
    1,782
    Nebraska
    This is the exact reason I don't think people need to freak out about changing the oil every 10k in the PiP if they do a lot of EV miles.
  8. ny_rob
    1,968
    813
    L.I.- NY
    Agreed!
    My lifetime EV ratio with the PIP was about 40%, so the ICE didn't hit 10K miles till I had over 16,500 miles on the odometer.
  9. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    Just visualize Oil Analysis testing as the automotive equivalent of getting a blood-test for HEPATITUS or AIDS...information that ALL IS WELL--or NOT.
