1. Offline
    lenjack New Member
    Dec 1, 2006
    Message Count:
    592
    Pennsylvania USA
    Your Vehicle Year:
    On my G2, I use a Fumoto drain plug. May I assume this would be fine with the G3?
  2. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    Probably, there has been a concern about a clearance issue, but the plastic bottom is so flexible even if it touched it may not be a problem. I'd check for clearance first.
  3. Offline
    Dark_matter_doesn't New Member
    Aug 8, 2009
    Message Count:
    469
    Seattle, WA
    Your Vehicle Year:
    The drain plug bolt head almost touches the access cover now. I had been considering getting one, but after doing an oil change I really don't think there's clearance for one.
    1 people like this.
  4. Offline
    JACoH New Member
    Oct 11, 2009
    Message Count:
    95
    Oregon
    Your Vehicle Year:
    Best drain plug I have found, and have used for my last 5 cars is the Fram EZ Drain, model SD3 fits the Prius. I believe these are discontinued but can be found on ebay. You replace the plug with it and only have to unscrew the cap, and attach the hose which releases the oil. Cannot leak if the hose is not attached as it is held closed by oil pressure. I put a 5 gallon jug under car and attach the hose and it drains directly into the jug, no mess, no leaks!
Share This Page
