OK wHAT HAPPENS IF YOU PUT IN 4 QUARTS OF OIL?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ski.dive, Apr 14, 2010.
  1. ski.dive
    ski.dive
    Expand Collapse
    Member
    361
    23
    Hutchinson Island,FL. Mt. Snow,VT
    2008 PRIUS, I put in 4 quarts of oil instead of 3.9 quarts, what will happen?
    How can 2 ounces make a difference?
    Are overfilling problems by 2 ounces a MyTH and B.S. INFO???
  2. boppo
    boppo
    Expand Collapse
    Active Member
    775
    131
    Owego, NY
    little less MPG. 3.75 would be good.
  3. Dark_matter_doesn't
    Dark_matter_doesn't
    Expand Collapse
    Prius Tinkerer
    676
    141
    Seattle, WA
    Engine oil capacity w/filter change on a 2010 Prius is 4.4 qts. With 4 qts, you should see the dipstick level about 2/3 from the bottom.
  4. David Beale
    David Beale
    Expand Collapse
    Senior Member
    4,984
    928
    Edmonton Alberta
    Yup, posted in the wrong section of the forum. Perhaps a mod. will move this for you.
    Second gen. -may- experience a slight drop in mileage with a bit too much oil, but 4 qts. may be ok for a 3rd gen.
  5. ski.dive
    ski.dive
    Expand Collapse
    Member
    361
    23
    I've been getting 46.5 mpg over the last 150 miles.
    I'm going to check my mileage with 4 full quarts of oil, to see if it is a MYTH and get less mpg's with an over fill by 2 ounces.
  6. Patrick Wong
    Patrick Wong
    Expand Collapse
    DIY Enthusiast
    15,836
    4,015
    I doubt that you will see any change with such a tiny change in oil level.
    What might be more interesting is if you were to monitor your mpg with 3 quarts of oil in the crankcase, and see if there's any improvement. That will still give you an oil level above the bottom dimple on the dipstick.
  7. paulemus
    paulemus
    Expand Collapse
    New Member
    93
    San Diego
    You might get a big bill down the road for replacing oil seals. Most dipsticks clearly warn: Do not overfill.
  8. ski.dive
    ski.dive
    Expand Collapse
    Member
    361
    23
    Tell me...How am I going to damage my OIL SEALS, by having 4 quarts of oil instead of 3.9 quarts of oil in my motor?:mad:
    That's only 2-3 extra ounces of oil.:mad:
  9. richard schumacher
    richard schumacher
    Expand Collapse
    shortbus driver
    7,652
    899
    United States
    3.9 quarts is the dry system capacity. At an oil change 3.5 quarts will fill the system including the filter. Three quarts exactly works just fine. Try it.
    It may not damage any seals but even a little overfilling has been found to start fouling the MAF. That can reduce fuel economy drastically.
  10. CharlesJ
    CharlesJ
    Expand Collapse
    Member
    463
    26
    38
    Monterey
    No matter how many fuel tanks you go through, there is enough variability from tank to tank that such a change will ever show up, if it is in fact a real change. You just cannot get a good feel for MPG even if the level, whatever you have it at will remain the same from tank to tank. Urban legends;)
  11. chuckknight
    chuckknight
    Expand Collapse
    New Member
    194
    33
    In reality, you wouldn't cause any damage. BUT it'd be a good excuse to refuse any warranty claims, if you have a shady dealer where you live.
    After all, even if it was only extremely minimal overfilling, they'd legitimately have a point that it was overfilled.
  12. ski.dive
    ski.dive
    Expand Collapse
    Member
    361
    23
    What size threads is on the prius oil drain plug
    in order to get a drain valve?
  13. turnbowm
    turnbowm
    Expand Collapse
    Junior Member
    So. Calif.
    FWIW, my 2008 Prius was overfilled (~3/16" above the full mark) by the factory and again by the dealer at 5,000 miles. This seems to be common practice by many Toyota dealerships.
    IMHO, Toyota would be on very shaky ground trying to deny a warranty claim for this reason. They tried this with the engine sludging problem a few years back and lost big time!
  14. hobbit
    hobbit
    Expand Collapse
    Senior Member
    4,084
    418
    Bahstahn
    3 quarts *is* sufficient for a drain/refill and filter change in
    a second-gen, placing the level somewhere between the marks on
    the stick [duh, like we were taught to check for back in the day]
    but on the lower side of that range. The third-gen takes a little
    more. Most of my changes are less than 3.5 quarts these days, and
    I keep an eye on it for any need of a top-up but it doesn't seem
    to lose any at all between changes. Mostly filling the new filter
    before putting it on helps re-establish circulation a little
    faster at startup.
    _H*
