OMG......Center Dash Rattle.... HELP!! (please)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jharper03, Jul 9, 2014.
  1. jharper03
    jharper03 New Member
    23
    Omaha, NE
    OK so I bought my Prius a little over a week ago and there was no rattle. I drove it 350 miles to get it home and it was completely silent. A couple of days ago I heard a slight rattle, and its not even a rattle is like rubbing 2 Styrofoam cups together, but now today it is extremely loud. So loud that I can still hear it over the radio blasted. I have pressed everywhere on the dash and cannot quiet the noise. It sounds like it is dead center under the vent. First thing I did was to come on here and research. I have read tons and tons of threads regarding removing dash and placing felt but I could not find instructions on how to remove the dash. Does anyone have step by step instructions?
    Thank you in advance.
    Josh
  2. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
  3. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    It's the Gen III (2010-2015) that has generic problems with dash rattles. You will need to get a helper to push on the various sections of the dash/console will you drive. You might find the problem area that way.
  4. alexeft
    alexeft Member
    139
    23
    Greece
    It's most probably not the dash but the plastic part that goes above the windshield and under the hood. It's mounted with some clips and uses some foam between it's two parts. Check that. I would bet you would find your rattle.
    jharper03 likes this.
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Print and read the link nh7o posted. Then grab a 10mm socket, a Phillips screwdriver, and a small thin putty knife. Now follow the directions and rip your dash apart. I can do mine in 10 minutes As you pull it apart look and feel around for something loose. If necessary, with most of the dash left out of the car, it will still drive fine. Find a safe spot to do some test driving, better yet have someone else drive around and you listen for the squeek. To put the dash back, reverse disassemble order! Or take it to a dealer and spend hundreds for them to do the exact same thing!
    Prius_Angie likes this.
