Once is more than enough.
Discussion in 'Prius v Main Forum' started by recurve57, Nov 25, 2015.
  1. recurve57
    recurve57 New Member
    Seguin, Texas 78155
    In December of last year my wife convinced me to buy a 2012 Toyota Prius v (lowercase v for the Prius v wagon) Wagon instead of another Honda CRV. Huge mistake. Since it was a used car as opposed to the new one I would prefer, we also purchased a Toyota Extra Care extended warrantee. (Something I have never done for any of the Hondas I have purchased). As it turns out the warrantee is not worth the paper it is printed on. I took the car to the dealership yesterday for an oil change; tire rotation, and inspection, normal maintenance.
    The service rep then told me I needed an alignment, not a problem. Shortly thereafter, he and the technician came into tell me I needed to replace the battery, not the hybrid battery, the regular battery for $360 dollars. In addition they had noticed a slight oil leakage around one of the bolts in the timing cover, and that I would need to have the O-rings sealing the timing cover replaced soon but this would be a labor intensive repair and I would need to leave the car there for several days at a cost of $1900.
    I asked if this was something my extended warrantee covered, they responded what extended warrantee. I told them we had purchased one at their dealership when we purchased the car. They researched it, found the warrantee and said it should be covered. I would need to leave the car a week so an adjuster could come out from the warrantee company to approve the repairs (48 hours) and then a couple of days to complete the work. Lo and behold, I got a call from the service rep today that the adjuster had been out and it really wasn’t a leakage, it was seepage so it would not be covered.
    Seems strange to me that it was urgent when it was my expense, but not a big deal when it was a warrantee issue. I will monitor the oil carefully and drive the car for little while then as the year comes to a close trade the Toyota piece of junk in on a new Honda, something I can depend on. The treatment I received from Universal Toyota has convinced me I will never but another Toyota. I have never been cheated or lied to by Honda.
  2. WilDavis
    WilDavis Senior Member
    2,489
    2,153
    49
    I think I would ask them (through my lawyer) to define leakage and seepage, and hear what they have to say - it might be entertining! Good luck. The "…the regular battery for $360 dollars…" would have got my attention, setting off all manner of bells and warnings (those batteries are available on-line for about ½ that price - here you are: AGM Toyota Prius Auxiliary Battery - Made in the USA: BatteryMart.com (without the labour to install) - Well, perhaps the owner of the dealership franchise had a payment due on his boat? Good luck, I hope you get it all sorted out to your satisfaction.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,594
    4,454
    Texas Hill Country
    That's assuming you really needed a 12v battery at all. Not extremely likely on a 2012. It's also unreasonable that the timing cover seal would cost $1900. Hopefully the extended warranty is really a Toyota warrantee and not from a third party. I would take the car elsewhere for a second opinion or simply wait until some trouble light comes up, if ever, and then go elsewhere. I assume Universal Toyota is the one in San Antonio owned by Red McCombs. I would go to North Park Toyota which is probably closer to you on the South side of town and is near the Tundra/Tacoma factory.
    #3 rjparker, Nov 25, 2015
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    Too bad your experience has been so negative.
    Kind of sounds to me like your problems really are stemming from the dealership.
    Not even knowing your car had a warranty that you purchased from same said dealership?
    That whole "Leakage vs. Seepage" deal is REALLY sleazy.
    You're probably so soured on the experience that their isn't anything I could say to convince you that Toyota's are good vehicles. But I've owned both Honda's and Toyota's and believe both companies make good products.
    I don't know what recourse you may or may not have with the warranty, but I surely wouldn't take the vehicle back to that dealership.
    I don't know if I'd necessarily conclude your vehicle is no good and Toyota is a bad company based on your regrettable experience. Dealerships are independent entities, I myself made a change from the dealership I purchased for service because of some questionable treatment by the purchasing dealership.
    If a change of repair venue doesn't help? Then....well I agree that Honda makes great vehicles.
    But I know from hanging around Honda Fit forums when I owned my Honda Fit, that problems arise occasionally at Honda Dealerships as well.
  5. fuzzy1
    10,043
    The 'junk' here is not your Prius, it is the dealership / shop that is trying to vacuum out your wallet. Select a different shop for future service and repairs.
    mmmodem likes this.
  6. recurve57
    Seguin, Texas 78155
    Thank all of you for the replies. I am certain the dealership is the problem. I went to them because they are a few miles from where i work. The Honda Dealership in San Marcos has always treated me well in the service arena. The dealership has soured me on Toyotas. Twenty some-odd years ago Gillman Honda almost soured me on Hondas but Honda intervened, told me take it to my mechanic and send them the bill. Then I found San Marcos Honda and renewed the relationship.
  7. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    What's the mileage on your odometer? The timing cover seal is covered under the 36 mo./60,000 mile powertrain warranty.
    FYI, I was quoted $1700 to replace the timing cover gasket for a dubious oil leak as well. I also have an extended warranty on our 2011 prius, but didn't need to use it because the timing cover seal was covered under the powertrain warranty. If your v falls within the mileage of the warranty, go online and print out the powertrain warranty from Toyotas own website and take it down to the dealership. They'll do the repair free of charge to you.
  8. recurve57
    Seguin, Texas 78155
    The car is at the dealership until I pick it up in the morning but I believe it is 77K and change.
  9. xliderider
    7,848
    3,102
    Honolulu, HI
    Most here will say if it's a small leak (seepage), then monitor your oil level periodically between oil changes, something you should be doing anyway, and don't really worry about it.
    The seepage is so minor the oil isn't even dripping out of the vehicle onto the ground below, correct? There's no oil stain below the vehicle where it's parked?
  10. Air_Boss
    Air_Boss Senior Member
    3,912
    1,068
    New Yawk
    Hint: don't ever buy a Jeep... new, or otherwise.
    Who may still be stinging from the financial disaster that was this year's F1 race at Circuit of the Americas (McCombs Partners owns the track) in a post-tropical monsoon, not to mention the State of Texas backing down on its financial backing of the $25 million annual race sanctioning fee. Gotta make up the losses somewhere!
    #10 Air_Boss, Nov 25, 2015
  11. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    That doesn't really make sense. Nor have you actually make any statements about whether you like the car or not. You do have some recourse against the dealer by going directly to Toyota, and certainly Toyota should hear about this dealer's practices.
    Having said all that, it seems to me that what really has you pissed off is that you allowed yourself to be fleeced. Which has nothing to do with the car.
    Lucifer likes this.
  12. recurve57
    Seguin, Texas 78155
    It might seem minor to many of you but I grew up with craftsmen who took pride in their work and stood behind it. The car is OK but nothing to write home about. My treatment by this dealer is what I know of Toyota, first impressions last. As far as being fleeced goes, fool me once shame on you. I will not be fooled twice.
    Air Boss. You are probably right on the mark about Red McCombs. When I was telling the story to a coworker yesterday, he told me a few years back he had purchased a used, "low mileage", Nissan Maxima from Universal Toyota. When he got home he found a document in the glove compartment that had been left there accidentally. It showed the vehicle had been received from Jordan Ford with more millage on it than when he bought it. He then went home pulled out his files and showed me the mileage reported when Jordan Ford sold it to Universal and the receipt showing ti had less mileage on it when he bought it. When he went back it was resolved financially to his satisfaction. Red McCombs Universal Toyota s as crooked as a dog's hind leg in my opinion.
  13. rjparker
    7,594
    4,454
    Texas Hill Country
    North Park Toyota in San Antonio has a much better reputation.
  14. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    The standard mantra is that the only thing wrong with Toyota's is that you have to buy them from a Toyota dealership.
  15. Fore
    Fore Don't look back!
    494
    107
    In the future ask yourself this very important question when buying another vehicle. Which car depreciates faster Toyota Prius or Honda CRV. The answer is the Toyota Prius. You should have bought another Honda CRV.
  16. cucaio90
    cucaio90 Junior Member
    48
    debary ,fl.
    2015 Prius v wagon
    No donut holes are the same,same thing with Toyota dealerships.
  17. bisco
    48,969
    the most reliable car on the road is okay, but nothing to write home about? all in all, i would rate toyota dealerships no worse than any other, and better than some. maybe honda is better, or maybe you just found a good one. does your wife still like the car?
    #17 bisco, Nov 26, 2015
  18. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    I am dedicated to my Toyota dealer because they've been extraordinary, but I've never dealt with another dealer. I have dealt with other brand's dealers, and the treatment was so utterly horrible, I've never been back, either for service, or another car.
    I've even taken other car makes to my Toyota dealer, with similar (meaning great), results.
    I'm actually scared to go to another dealer ;)
  19. Montgomery
    Montgomery Senior Member
    2,254
    2,234
    Orange County, CA
    No matter what kind of car I have owned, 7 out of 10 times, my experience with Dealerships is negative. From the mechanic who thinks looking at my car is a "waste of my time", to the service manager who seems to think "my problem is in my head", to the 20 something reception clerk who thinks she's hotter than $#@! and thinks you should just pay the bill and have dreams about her. Having vented all that, it has been the life of the vehicle that has turned me to finally land on Toyota. I too, finally opted to get the best warranty that Toyota (not the Dealer) has to offer, so that no matter where I go, I got the company behind me, not little miss hottie at the reception desk, or Mr. impatient service manager, or the mechanic that seems to think you know nothing about cars from a dealership. Yes, I have had good experiences, but they all happened when I use to drive Saturn Vehicles. (yep, I owned 4 of them).
    bostonbruins8703 likes this.
  20. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Sounds like a way huge overreaction. But this is why Tesla doesn't do it and doesn't want to. Toyota can make the best cars in the world, but when they are sold by slime, it hurts the overall brand.
    I've only been to the Toyota dealerships around me twice I think. Once for a recall, and once to buy a second Prius in addition. Both times were less than awesome experiences compared to visiting the Lexus dealership. But the extra $40K it costs to buy a Lexus RX is not made up for by the free bakery items and beverages in the leather chairs.
