Optima ds46b24r Youtube Vid
Discussion in 'Gen 2 Prius Main Forum' started by moshe_levy, Jan 16, 2012.
  1. moshe_levy
    moshe_levy Junior Member
    62
    Hi All-
    My 12VDC OEM battery is dead as a doornail. I ordered a new Optima to replace it, and am using my motorcycle (brrrrr - cold!) until that comes in. Anyway, sometime back I thought I remember reading or seeing the Optima rep posting a Youtube vid of installation. For the life of me I can't find it here or on Youtube. Anyone got a link?
    -MKL
  2. DGH
    DGH Thread Terminator
    365
    93
    Wales, WI
    Not for the Optima but basically the same process.
    2 people like this.
  3. moshe_levy
    62
    Yes, this is good, but I wanted to see if there were any special steps required on the Optima.
    -MKL
  4. DGH
    365
    93
    Wales, WI
    More or less the same, should be no big deal.
    Good Luck...Dan.
  5. jdenenberg
    jdenenberg EE Professor
    3,837
    1,827
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I put an Optima "Pencil Post" in my 2004 at 213,000 miles (The OE was still working dated 1/16/2004) two weeks ago with no difficulty. It was a bit longer than my OE (the non SKS battery), but it fit.
    JeffD
  6. moshe_levy
    62
    Installed the Optima yesterday - easy as pie! Only pain is I lost all my radio presets when removing the old battery.
    -MKL
  7. DGH
    365
    93
    Wales, WI
    Oops, my fault, I should have mentioned leaving 12v connected at the fuse block to retain memory.
    Glad it all worked out for you.
  8. notime
    notime Junior Member
    Washington State
    2014 Prius v wagon
    I need to replace my 2007 Prius battery soon. What do I need to do to leave the 12v connected at the fuse block? Thanks.
  9. AquaJan
    AquaJan Junior Member
    47
    17
    US
    Just follow owner's manual instructions for jumping a dead battery (see Youtube). You can use any 12v battery or another car with jumper cables. The other car doesn't have to be running. You have to be a little more careful not to short out the positive assembly if you do it this way.
    One thing I found easier to do was to unscrew the negative jumper from the car body itself. It's easier than trying to get to the clamp nut on the negative terminal when it's in the cubby. Then swap the jumper to the new battery before installing.
    Also, lay an old towel over the spare tire area while you work to prevent dropping screws and tools down the deep, dark well
  10. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yep, if you do this then the positive assembly stays live even after you remove it from the battery, so you have to be very careful not to let it touch any metal parts.
    I've found the best thing is to place it (positive assembly) into a stout plastic bag immediately upon removal, and then place an elastic band around the bag to hold it in place. Takes about 20 seconds to do and makes it safe and easy. :)
  11. blzlovr
    blzlovr Junior Member
    25
    Riverside, CA
    2018 Nissan LEAF
    Thank you for the video. My husband replaced our dead battery (2007) with a Optima DS46B24R. I bought it from Advance Auto parts and had a 50.00 off code I found here in the forum. It took him less than 30 minutes to replace.
  12. jim240
    jim240 Junior Member
    24
    Does the Optima DS46B24R have the pencil posts?
  13. khoakhoa
    khoakhoa Junior Member
    96
    28
    san diego
