1. Offline
    msgm New Member
    Start a Conversation
    Jul 4, 2012
    Your Vehicle Year:
    [IMG]
    [IMG]
    Mr strados ,
    thats my screen shoot ,, so whats next my brother ...
  2. Offline
    strados Junior Member
    Apr 24, 2012
    Germany
    Your Vehicle Year:
    Quite right. backup means copy. I'm generally using Windows Explorer running from -> Start -> Programs -> Windows Explorer. It's better than CECMD.exe (TotalCommander) cause keyboard pop up for rename or something else is no problem. First step you have to terminate the UI. Put this tool into root of sd card and click button "Update" on screen Options / System.
  3. Offline
    Apr 24, 2012
    Germany
    Your Vehicle Year:
    Unfortunately your unit has built in radio tuner "NATURE". I'm sorry, but there is no MCU update for these units with NATURE tuner. This special Update would ne necessary to replace UI D2880 by i9. Without MCU update i9 UI would'nt work.
  4. Offline
    slp New Member
    Jun 29, 2012
    17
    Your Vehicle Year:
    So eazy just read this forum fron bigining. I did the same. Make sure ti bavkup your NAND FLASH drive and Staticstore before you do anything.
    Sent from my GT-P1000 using Tapatalk 2
  5. Offline
    slp New Member
    Jun 29, 2012
    17
    Your Vehicle Year:
    Hello strados, have you tried the 1.55 version is it good. Whats different compare to 1.51 also pls give the link.
  6. Offline
    Gaga78 New Member
    Jul 6, 2012
    Your Vehicle Year:
    I search in the forum how to start for beginner but unfortunatly didn't find post about this.
    I found some information but it is give me clear idea about how to start, step to do, etc...
    Kindly I need your support to know how
    1- Backup my actual NAND or whatever need to be backup
    2- To upgrade my OS from 1.40 to 1.53 (what's the tool, steps, etc...)
    thanks guys for your support.
  7. Offline
    msgm New Member
    Jul 4, 2012
    Your Vehicle Year:
    o_O
    thats mean i cant do any thing to update that old version at all ?
  8. Offline
    Bulle Member
    Nov 5, 2011
    256
    34
    Your Vehicle Year:
    please take a look at post #1 in this thread:
    Ottonavi HU: How to customize (a bit) the UI | PriusChat
    It's like a FAQ; there is *some* information about how to upgrade your GUI, MCU or OS at end of post #1.
    For Prius, backup is simply copying the files in NAND FLASH and StaticStore folders ona USB disk or SD card.
    For non Prius cars, the names might be a little bit different.
    You should also always backup the original SD card you received in case something goes wrong later.
    seckwielen likes this.
  9. Offline
    Apr 24, 2012
    Germany
    Your Vehicle Year:
    I'm sorry, but that's right. The only thing you can change is to add new skins if you like.
    Here are some to download. If you don't know how to replace current logo by Toyota pls ask I can do it for you.
    - Brushed metal: China-RNS.com
    - Black orange: China-RNS.com
  10. Offline
    Gaga78 New Member
    Jul 6, 2012
    Your Vehicle Year:
    thanks Bulle.
    In this link I found how to upgrade my OS, a good step -)
    But still I have some miss:
    How can I know my UI version ?
    http://img809.imageshack.us/img809/580/photo2kr.jpg
    How can I know if my system is 128M or 256M RAM (i have brand "Roadrover", model "C7047T1") as I found 2 different 1.53 firmware
    Last question: what is the last IGO version to be install on the unit?
    regarding your comment:
    You lost me now -))
  11. Offline
    Apr 24, 2012
    Germany
    Your Vehicle Year:
    Have a look at top right corner of main screen. Maybe V1.25.5 or less
    Run tool ResInfo.exe It will show all system infos.
  12. Offline
    Gaga78 New Member
    Jul 6, 2012
    Your Vehicle Year:
    thanks strados,
    The main screen I post photo as you requested...there is nothing write...only day, hour....
    you mean this one:
    Also how to save my "NAND" on my product?
    thanks in advance for your time and support and sorry for all questions
  13. Offline
    Apr 24, 2012
    Germany
    Your Vehicle Year:
    GUI version at topright corner is very tiny and pale but it's there.
    NAND FLASH is just as StaticStore one of the drives under My Device.
    Put this tool into root of your sd card and push "Update" on screen Options / System. It will terminate the GUI and you will see Windows Desktop. Then run Start/Programs/Windows Explorer and you can copy & paste complete drive NAND FLASH same way as StaticStore.
  14. Offline
    Gaga78 New Member
    Jul 6, 2012
    Your Vehicle Year:
    I success to get my memory level....95Mo !!!! is it possible ???? cf below screen
    So can I upgrade my system to 1.53?
    For the main screen UI version (top Right), really I have nothing...I put britness to max, contrast...nothing !
    Regarding the NAND, yes thanks I went in NAND disk then wrap and drop all files and folder in my USB keys.
    Also I have a question for my poor sound quality...there is an option E-AMP or I-AMP, when I select one or the other, not difference at all in the sound...is it normal ? I have JBL Syntethis in my CAR...is there any link ?
    [IMG]
  15. Offline
    Apr 24, 2012
    Germany
    Your Vehicle Year:
    Yes 95.8 MB is ok. That's just available for program memory. The other part of nearly 30 MB is already used my Windows.
    About GUI version: I know it's displayed very pale, you must see from above sloping.
    About OS V1.53: Yes you undate without risc. Just put the 4 files into root od a SD card and after inserting the card power on the unit. Update will run automaticly.
    About E-AMP / I-AMP: This controls the audio output on RCA plugs. It means Internal or External (amp)
  16. Offline
    Gaga78 New Member
    Jul 6, 2012
    Your Vehicle Year:
    thanks strados for your explanation.
    I will proceed with OS update to 1.53 using the 128MB version one I found.
    Regarding UI, I check the screen at all and no version. Is there any way to get it from tool ?
  17. Offline
    Apr 24, 2012
    Germany
    Your Vehicle Year:
    No, not available from tool. Try to change the skin maybe it's better visible on another skin.
  18. Offline
    Gaga78 New Member
    Jul 6, 2012
    Your Vehicle Year:
    any skin recomendation ?
    and how to get back actual skin ?
    thanks strados
  19. Offline
    Apr 24, 2012
    Germany
    Your Vehicle Year:
    Skins can be selected in screen Options / System. I assume there should be more than one skin (subfolder) stored into your folder D2280\Skins ? If that is right but the GUI will not show all to select, pls post you file config.ini which is stored in D2280 and I will check and edit it.
  20. Offline
    Gaga78 New Member
    Jul 6, 2012
    Your Vehicle Year:
    I have in system 2 skin: Cyan and Orange and with both impossible to get UI version
    I attached my config.ini
Share This Page
