1. Offline
    ryogajyc Active Member
    Start a Conversation
    Aug 30, 2004
    950
    153
    Reseda, CA
    Your Vehicle Year:
    Really? I checked my 2004 manual and I couldn't find an oil consumption max number. 1.1 qt/600 miles seems like a lot. Intuitively, I would think that 1.1 qt. consumed in 600 miles would mean the engine is in really bad shape.
  2. Offline
    usbseawolf2000 HSD PhD
    Sep 22, 2004
    11,330
    1,769
    Queens, NY
    Your Vehicle Year:
    Unfortunately, that's for the 2010 prototype model.
  3. Offline
    stacey ☆☆☆☆☆
    Aug 2, 2004
    108
    Lancaster, PA
    Your Vehicle Year:
    Before, if you picked "Prius PHV" from the list of vehicles, only the 2010 showed up. The 2012 is there now too. The manual documents specifically say "2012" on them.
    ryogajyc likes this.
  4. Offline
    Aug 30, 2004
    950
    153
    Reseda, CA
    Your Vehicle Year:
    Yep, thanks. It turns out my link doesn't actually select the correct year/vehicle. If you have visited the page previously, the vehicle shown is cached from the last one you have selected. I've corrected my post above.
  5. Offline
    gwmort Active Member
    Mar 22, 2011
    969
    176
    Delaware
    Your Vehicle Year:
    What if the "pranksters" are your local municipality that just invented a bright yellow J1772 handle with a locking release mechanism to use for "booting" EV's?
  6. Offline
    mitch672 Technology Geek
    Mar 10, 2004
    1,069
    189
    Randolph, MA
    Your Vehicle Year:
    I say good for them, those scofflaws who don't pay their parking tickets should be booted, and done in the most cost effective way, a locking J-1772 handle that disables the vehicle from being moved will be easier to deploy, cost the city less, etc. Of course on several vehicles like the Volt, the J-1772 door opens from the inside.
    There is enough to worry about in the world without being concerned about this one.
  7. Offline
    drash Member
    Jan 5, 2005
    449
    37
    Upstate NY
    Your Vehicle Year:
    Where I live, I have more concerns with the local wildlife than pranksters. Anybody else though think this is a great anti-theft gadget in the making? Quick get a patent going.
  8. Offline
    Aug 30, 2004
    950
    153
    Reseda, CA
    Your Vehicle Year:
    I updated my original post with the compiled Owner's Manual to include the Display Audio with Navigation Owner's Manual. Sadly, the the Premium HDD Navigation Owner's Manual is not yet up.
    Owner's Manual post
    2 people like this.
  9. Offline
    Jul 14, 2009
    517
    146
    Chicago western burbs
    Your Vehicle Year:
    So we can now look at the actual tire pressures on all 5 tires from the Audio screen by pressing "Car" then "Tire Pressure." Nice!
  10. Offline
    Tracksyde Member
    Sep 21, 2011
    1,064
    512
    So Cal
    Your Vehicle Year:
    You mean all 4 tires since there is no spare, right? :)
  11. Offline
    Jul 14, 2009
    517
    146
    Your Vehicle Year:
    It will display all four and up to five, if you decide to install a spare with a TPMS thingy. Page 193 in the 2012 Audio and Display PDF indicates this. I will assume, and maybe not correctly, that the PiP and the regular 2012 higher end displays have similar features for TPMS readouts. I wonder if one can have it read out in psi instead of kPa?
    [IMG]
  12. Offline
    rogerv Senior Member
    Dec 10, 2008
    1,047
    190
    Simi Valley, California
    Your Vehicle Year:
    I vote for carrying a compact spare, and somebody at Toyota must have felt the same way. Otherwise, why would you need a jack? The air compressor inflates the tire, the goop goes into seal it, and running the tire causes the goop to spread and seal the leak. No jack needed for that, unless I'm missing something.
    Now, if the bolt pattern is the same as any other Prius.......
  13. Offline
    Aug 30, 2004
    950
    153
    Reseda, CA
    Your Vehicle Year:
    Updated my original post with Warranty and Maintenance Guide and Premium HDD Navigation Owner's Manual. Also added download links.
    Owner's Manual post
  14. Offline
    9G-man Active Member
    Jul 2, 2005
    1,230
    142
    Atlanta, GA
    Your Vehicle Year:
    Apparently you are not much of a do-it-yourselfer. That jack comes in handy for oil changes, tire rotations, brake inspections, etc,. and in the event of serious tire failure, I'd want to be able to remove and replace the wheel for tire replacement, instead of letting some schmuck drag my car around on the rim.
  15. Offline
    Jul 14, 2009
    517
    146
    Your Vehicle Year:
    Post #71, above, has information that no one has been able to verify. Prius can not show tire pressures currently. Unfortunate that the manual was printed/released before the car shipped. There is no such functionality. Toyota screwed up.
    Perhaps Toyota will get this straight after a while and offer up a firmware upgrade. It obviously did do what it says in some pre-released version, so we know it is possible to display individual tire pressures.
  16. Offline
    bilofsky Priuspatic Member
    Nov 14, 2011
    324
    68
    S.F. Bay Area, CA
    Your Vehicle Year:
    I have modified and reposted the Owner's Manual here:(link deleted - see update below) with the following improvements:
    • Page numbers in the PDF now follow the numbers on the pages, so you can go to a page number and get to the right place.
    • Added bookmarks with chapter headings
    • Bookmarks don't mess up page view
    It looks like the page links only work if they were in the same section in the split document, and that'd be a bear to fix.
    Is the index available anywhere?
    Update: ryogajyc has updated the Quick Guide, Owner's Manual, and Premium HDD Navigation Owner's Manual linked from his earlier post and they are better - see explanation here.
    3 people like this.
  17. Offline
    devprius /dev/geek
    Jan 2, 2006
    834
    208
    San Francisco Bay Area, CA
    Your Vehicle Year:
    I have found another error in the owners manual. The description of the headlight stalk is incorrect for the base model. The owners manual on pages 292, 293 and 294 describes 3 different types of stalks: A, B, & C.
    Type A has 4 posititons (starting from the bottom): DRL offf, Headlights & parking lights on, Parking lights only, Auto on/off
    Type B has 4 positions: Off, Parking lights on, Headlights & Parking lights on, Auto on/off
    Type C has 4 positions: DRL On, Parking lights on, Headlights & Parking Lights on, Auto on/off
    What I actually have on my base model is: Off, DRL on, Parking lights on, and Headlights & Parking lights on. I've attached an image of my stalk:
  18. Offline
    ukr2 Active Member
    Feb 5, 2007
    803
    136
    Victor, NY
    Your Vehicle Year:
    Right. My Base is like yours. No Auto.
    Also the CAR button of the Display is on the right of the display, not the left as in part of the manual.
    Was the Manual not checked with the Actual car?
    And why 3 Types when there are only 2 models?
  19. Offline
    Aug 30, 2004
    950
    153
    Reseda, CA
    Your Vehicle Year:
    Because the manual is for all of North America and Canada has different models.
  20. Offline
    ukr2 Active Member
    Feb 5, 2007
    803
    136
    Victor, NY
    Your Vehicle Year:
    What is different in Canada?
    I'm in Rochester, NY, go to Toronto yearly and practically Canadian, eh.
Share This Page
