P3191 And p0300-p0304
Discussion in 'Generation 1 Prius Discussion' started by Johnmo, Nov 23, 2014.
  1. Johnmo
    Johnmo Junior Member
    29
    2003 Prius
    I
    Ugh, 2001 just started it up, check engine pops up, engine does not come on as expected. Restarted it and engine came on, stumbled, then back off. Suggestions. What would cause the 3191 plus all cylinders to misfire? Money is an issue here so I need to exhaust all options myself first.
    Can I spray the MAF while it's still installed or will the dirty cleaner cause problems.
  2. Patrick Wong
    18,198
    6,464
    1. When was the last time the iridium spark plugs were replaced? If more than 60K miles have been logged, replace them with the correct NGK or Denso plugs now.
    2. While the plugs are removed, inspect the spark igniters for burn marks, cracks, or rust deposits on the plastic body. Replace any igniter that has a problem. If you see rust, this means that water got into the spark plug well. That would cause misfire in that cylinder.
    3. Remove the mass air flow sensor for cleaning. Use the correct MAF cleaner spray.
    4. Clean the throttle body interior and throttle plate using throttle body cleaner. Use the minimum amount of cleaner, ideally by spraying the cleaner on a cloth and using that to scrub away at the interior and throttle plate. You would need to remove the air cleaner housing for access.
  3. dabard051
    dabard051 Tinkerer-in-Charge
    237
    87
    Rochester, NY USA
    2002 Prius
    Patrick has excellent points, and I would add, think about fuel quality... when did you last fill up? If the tank was nearly empty, and the vehicle has sat for a day or so, it's possible that the ethanol in the fuel has soaked up enough water from the air that the prius is having a hard time combusting what it gets.
    Your profile doesn't say where you are, or whether it had been raining / snowing when this occurred...
    A bottle of Techron prior to the next fill, preferably at a high-volume station, of good quality fuel (premium, if you can afford the price delta) will also do wonders.
  4. Johnmo
    29
    2003 Prius
    I
    Cleaned MAS an throttle body and the problem has not changed. Starts fine, runs fine for 10 seconds, then sputters and shuts down and check engine comes on. Ugh
  5. Patrick Wong
    18,198
    6,464
    I doubt that the gasoline engine has actually started. More likely, MG1 is just spinning the engine which has not started.
    If you want to verify that the engine has started, see whether it responds to the accelerator pedal. If it does not, the engine did not start. Or, shift into N while the engine is "running" and see if it continues to.
    What do the spark plugs look like?
    When was the last time that the car operated correctly?
    royfrontenac likes this.
  6. Johnmo
    29
    2003 Prius
    I
    Patrick was right , engine did not redpond to accel. Decided to drive down hill to shop today. Unplugged battery, replugged, started driving on battery only, engine not kicking in first 1/8 mile, batt went to 25%. Coasting down hill, oddly check engine not coming on. I give it some gads to see how it reacts, engine comes to life. Batt charges back to 75% and now damn car runs perfect. Will post later as I get more info. I'm sure this is not over.
  7. Johnmo
    29
    2003 Prius
    I
    Updating, had this problem happen again and it turns out it was probably the 12v Aux battery.
