1. Offline
    davidkde New Member
    Start a Conversation
    Aug 2, 2012
    Your Vehicle Year:
    Posted this in technical forum, but only 1 response that didn't work..
    Hello,
    I have 1 personal iphone 4s and 1 work iphone 4.
    Can someone tell me how to pair both phones onto the radio? I have a c2.
    When i go to BT pairing it asks me if i want to delete all devices (if i press NO, it doesn't do anything.) If I press YES, i can only pair one of the phones and the other one will say "make sure BT is on and device is in range" or something like that.
    I would like to pair both if possible (for safety reasons when driving and getting a phone call).
    Any help will be appreciated!
    thanks!!
  2. Offline
    davidkde New Member
    Aug 2, 2012
    Your Vehicle Year:
  3. Offline
    oberkc New Member
    Aug 14, 2012
    Ohio
    Your Vehicle Year:
    My understanding is that you pair the second just like the first... put one in discoverable mode and search with the other. Just be aware that I don't believe you can pair a second (or third) device if the first is connected. Also, I don't believe you can use more than one at any point in time.
  4. Offline
    Nall New Member
    Jun 21, 2012
    Your Vehicle Year:
    You can pair one at a time and have both in the stereo's memory, but you can only use one at a time. If you go to paired devices in the settings you can switch between them. You can't get calls or play music from both without doing this though, the car will reconnect with whichever phone was last connected when you start it up.
  5. Offline
    Holly Ormseth New Member
    Mar 3, 2013
    Your Vehicle Year:
    Hi !
    I have a similar problem. I can't connect multiple devices. However I can't even click on the "add new device" button, and I can click on the "delete" button for the already paired device- is there some way that I don't have privileges to do these things?
    The paired device is far out of range. I've tried restarting the system .
    Thanks!!
  6. Offline
    B2FiNiTY Member
    Dec 17, 2012
    453
    86
    Your Vehicle Year:
    Is your car in park and with the ebrake on while you are doing this?
    Do you get any error messages?
Share This Page
