Pandora sound quality?
Discussion in 'Gen 3 Prius Audio and Electronics' started by BreitrthnU, May 19, 2012.
  1. BreitrthnU
    BreitrthnU Less gas, more watches!
    254
    48
    Tampa, FL
    Every time I stream the sound quality of pandora sounds horrible. I hear normal radio nice and clear, but when I switch to Pandora it sounds all muffled and cheap. Does anyone else have this issue?
    Sprint with HTC Evo.
  2. Muzzman1
    Muzzman1 Member
    82
    So Cal
    Yes, I am also experiencing the same quality even in "high quality" mode.
  3. SamelCamel
    SamelCamel New Member
    60
    Kansas
  4. Big Steve
    Big Steve ramblin wreck
    402
    37
    Richmond VA
    I used it (Pandora) for the first time today.
    High quality -> iPhone 4 -> Verizon -> USB
    Sounded great, No pauses or skips.
    I suggest that each comment indicate phone and carrier so we can check whether there is any correlation.
    Jerry Mcl likes this.
  5. ProximalSuns
    ProximalSuns Senior Member
    1,882
    16
    27
    PNW
    ATT. iPhone4. Tethered accessing via Bluetooth. No skips on high quality Pandora setting. I can't tell difference between high and lower quality on the Pandora on the car radio, both sound good.
  6. BreitrthnU
    254
    48
    Tampa, FL
    Mine was on low setting however I switched it to high just now so on my ride home I'll see if theres any difference. So lets see if that fixes my issue
  7. hoddy4
    hoddy4 New Member
    118
    NC
    Volume is not consistent for me in Pandora. Sometimes way to low at same volume setting.
  8. Big Steve
    402
    37
    Richmond VA
    Started driving today twice with iPhone on USB, and Pandora resumed and sounds great still.
  9. Sweet Turtle
    Sweet Turtle New Member
    Gilbert, AZ
    High Quality -> HTC one S -> T-mobile -> USB
    When I listen to Pandora via Entune it sounds like it's playing in another room. The sound is muffled. When I go though Bluetooth and listen to Pandora without Entune it sounds great.
  10. wsbsteven
    wsbsteven Prius owner gone Leafer
    24
    Saint Louis
    High mode is only for Pandora One subscribers. If you aren't, it will be exactly the same as normal.
  11. Muzzman1
    Muzzman1 Member
    82
    So Cal
    Thanks for the reply! Are you 100% certain of this? Reason I ask is because when I listen to Pandora on the car I never hear commercials, so I actually assumed the cost of Pandora One is subsidized by the entune's annual membership, which means that HQ should be included.
    If you can confirm that Pandora one will actually provide HQ I'd certainly be willing to pay for it over SXM.
  12. fkong777
    fkong777 New Member
    Los Angeles
    I have the Prius 3 for two months now. Never got Pandora to work. However Im thinking Why am I even needing the Apps fromt he HU to work if I need to have the phone next to me anyways. Just use the Aux cable and use any streaming apps or playlist I have on my andriod phone. the entune system is way dumb...
  13. JJay
    JJay New Member
    123
    Vancouver, WA (near Portland)
    2012 Prius 3
    Verizon > Samsung Nexus > Entune app
    I use the "high quality" option in Pandora without commercials in the car and without paying for a Pandora subscription.
    Pandora Sound quality is much better than normal FM; equal or better to Satellite quality.
    There are some "dead" cell areas on my daily commute that Pandora drops out, but when it works (90% of the time,) it's a great free service.
    FYI Entune/Pandora has hit my Verizon data plan for about 1GB for a month, about 30 minutes of connect time per day, mostly Pandora, but some Fuel and Weather/radar lookup.
  14. AZGeek
    AZGeek Semi-informed Member
    638
    143
    63
    Arizona
    I have a Pandora One account and the sound quality via Entune is just fine. I almost exclusively connect using BT, and usually from an iPad. Works just as well with an iPhone 4 when I am connected to that. The reason why I don't use the iPhone all the time is because I get a lot of email and other notices that can interrupt the music, even if it only mutes a few decibels for a second or two. I am more incognito with the iPad. ;)
    new iPad ?
  15. d2mini
    d2mini Active Member
    533
    107
    Houston
    Pandora sound quality set to Hi is definitely better than the Sirius sound quality.
    Shockingly good even.
    JJay likes this.
  16. Muzzman1
    Muzzman1 Member
    82
    So Cal
    Do you find the quality to be good when using the entune app or when listening over BT? Do you find that the entune app is very muffled (low bit rate)?
  17. d2mini
    533
    107
    Houston
    All through Entune and iphone connected through BT. Phone in my pants pocket.
  18. Muzzman1
    Muzzman1 Member
    82
    So Cal
    That makes sense. My chief complaint is that the quality is significantly reduced when using the Entune App. I actually like the ability to control my music through the car's interface especially now in Los Angeles, if a cop sees a phone in your hand, you're getting a ticket. End of story.
  19. d2mini
    533
    107
    Houston
    I don't think it's making as much sense as you think it is. ;)
    I am using the Entune app. The iphone is connected through BT because it has to be in order to use Entune in the car.
    The phone stays in my pocket or in the ProClip cradle and I never touch it.
    Everything is controlled through Entune.
    Sound quality is set to high and sounds awesome.
  20. Big Steve
    402
    37
    Richmond VA
    That is not accurate. iPhone works through USB with Entune.
