Panel removal + moisture barrier questions
Discussion in 'Prius c Accessories and Modifications' started by col127, Apr 5, 2013.
  1. col127
    col127 Member
    345
    Illinois
    Hi all,
    Going to start sound deadening soon and had questions:
    #1 Moisture barrier - I'm thinking it's there for a reason so I don' want to remove it (would like to put it back) - so how do you remove it without ripping it? It's really stuck to that black goop...
    #2 Do you put deadening material on the door cover as well (the plastic trim that you remove)? Or just on the actual door itself?
    #3 Ran into issues when trying to take apart my car - since I'm not too savvy on what to do... :p Wheel wells in the back - I couldn't figure out how to remove the pieces off - I saw there were 3 screws holding it in place - but I couldn't figure out how to get them off
    #4 Floor carpets - how to remove? do you have to remove the seats to do that ? How do you remove the seats?
    #5 Headliner - is this hard to take off? What's the process?
    Thanks for any help!
  2. maddog61
    maddog61 Junior Member
    44
    Why are u adding sound deadening..... the c is not that noisy..........your just adding weight????????
  3. col127
    col127 Member
    345
    Illinois
    it's very noisy imo. i drive luxury cars and there's a huge contrast with this car.
  4. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    you can remove it and stick it back on. the goop is sticky enough, unless your car is too old or the weather is too cold.
