Panic button doesn't work on base Prius?
Discussion in 'Gen 2 Prius Technical Discussion' started by luckyboy, Jul 29, 2007.
  1. luckyboy
    luckyboy Member
    204
    29
    I have a 2007 base prius with no option (no smartkey). I was told I could not program the car to make the "beep" when I lock the doors, but recently I also discovered the panic button on my FOB does nothing. Is this normal for a a base prius without the smart key (or alarm options)?
  2. chunky
    chunky New Member
    <div class='quotetop'>QUOTE(luckyboy @ Jul 29 2007, 05:45 PM) [snapback]487227[/snapback]</div>
    I too have a base model and thought the panic button didn't work when I tried it. But then I read you have to hold the button down for a second or too: Bingo - action, lights, camera!
    If I may add a rant: thank heavens you can't get the car to beep! Beeping cars are incredibly irritating to those not involved with that particular car.....
    Chunky
  3. priussoris
    priussoris New Member
    1,005
    Thats the only thing about the fob I do not like , Is the panic button, if you bend down the button hits your keys and off it goes.
    Be glad it does not work, or you too could wake the neighbors at all hours :p
    I would like to know how to disable that part of the fob :D
  4. kenmce
    kenmce High Voltage Member
    1,509
    493
    NY
    <div class='quotetop'>QUOTE(priussoris @ Jul 29 2007, 09:54 PM) [snapback]487249[/snapback]</div>
    Tape a piece of stiff plastic over the back?
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    <div class='quotetop'>QUOTE(chunky @ Jul 29 2007, 09:29 PM) [snapback]487238[/snapback]</div>
    I hate beeping doors on cars. The ones on the Prius use a softer sounding beeper instead of the car horn, so they aren't too bad.
    Tom
    Open the fob and place a small piece of electrical tape over the contacts.
    Tom
