1. Offline
    nemrut New Member
    Jul 22, 2009
    Message Count:
    57
    san francisco
    Your Vehicle Year:
    Is there an advantage to a 'Park Button' vs a 'Park Shifter Setting'? I personally find the Park function as a button less intuitive than a shifter setting.
  2. Offline
    jay_man2 jay_man_also
    Jun 11, 2009
    Message Count:
    1,246
    138
    Manassas, VA
    Your Vehicle Year:
    I rarely use the Park button. Power off automatically puts it in park. That was weird at first, but now I'm used to it, and would probably be annoyed to have to move a shifter to Park before shutting the car off.
  3. Offline
    JimboK One owner, low mileage
    May 1, 2006
    Message Count:
    2,817
    170
    Chesterfield, VA
    Your Vehicle Year:
    I agree that the button is less intuitive, but you'll get used to it.
    I'm not sure why Toyota didn't design it with P in the lever. I see no reason why it couldn't have been done. With shifting done "by wire" instead of mechanically, it seems it would involve only an added position for the lever.
    Like Jay, I power off without putting it in P, although I do still frequently use the Park button. As a fuel-saving technique (to avoid the initial warmup run-on), I leave the car on if it's sitting for just a few minutes, say, for a quick stop at the store.
  4. Offline
    32kcolors New Member
    Jul 14, 2009
    Message Count:
    4,515
    536
    Redondo Beach, CA
    Your Vehicle Year:
    Does the engine come on even when it's already warmed up upon restarting in the Gen III?
  5. Offline
    DeanFL 2010 owner - 1st Prius
    Apr 13, 2009
    Message Count:
    986
    321
    Leesburg Florida USA
    Your Vehicle Year:
    May I confirm this? Sometimes I may stop at Dunkin Donuts for a quickie to go. Leave my puppy in his car seat. I've been turning off the car so it can be locked (I'm gone for 2-3 minutes). So, can I put it into Park, leave the AC on, exit the car, and lock as normal since I have the smartkey with me.
    Don't recall seeing this in the manual; perhaps Toyota wouldn't want to mention this. And, if this can be done, I'd guess this is how some posters left their car on 'all day'.
    This would also be a good thing as not to clear the MID mpg graph data at power down.
  6. Offline
    May 1, 2006
    Message Count:
    2,817
    170
    Chesterfield, VA
    Your Vehicle Year:
    IIRC it does, though I suggest trying it for yourself to confirm.
    Often I'll leave it unlocked if I'm in what I consider a safe area and I can watch the car. SKS won't work outside the car with the car on, so you can't use it for this. Instead I put the driver's side window down, get out, close the door, reach in to lock it with the armrest lock button, then close the window (and move my arm quickly ;)). I unlock it with the mechanical key.
    Yeah, I don't see why Toyota would mention this in the manual. They conceivably could caution against it, but if they cautioned against every possible hack and workaround folks around here come up with, the manual wouldn't fit in the glove box. :)
    Leaving the car on all day almost certainly has been in an unlocked car. The car also won't lock with the armrest button when it's on with the door open, and someone won't go through the somewhat convoluted process I just described if they're not very aware of what they're doing and why.
    1 people like this.
  7. Offline
    cossie1600 New Member
    Jul 25, 2009
    Message Count:
    806
    71
    CT
    Your Vehicle Year:
    When I was at the DMV, I had to leave the AC running while puppy was in the car. The car refused to lock with button when car is on. I just ended up using the key to lock the doors manually, remember you can only unlock it with the key after!
  8. Offline
    royrose New Member
    Mar 21, 2009
    Message Count:
    347
    38
    Manitou Springs, CO
    Your Vehicle Year:
    My understanding is that this has changed with the gen III, that the ICE only comes on if needed, not if the car is still fully warmed up.
    A solution to leaving your dog in the car is to get the remote start. That way you don't need a workaround. Just hit remote start after you get out and lock the car. It is for a maximum of 10 minutes though.
  9. Offline
    Jul 14, 2009
    Message Count:
    4,515
    536
    Redondo Beach, CA
    Your Vehicle Year:
    Thanks for confirming. That's what I thought.
Share This Page
