Passenger iPad Mount
Discussion in 'Gen 3 Prius Accessories and Modifications' started by clokwise, Dec 23, 2013.
  1. clokwise
    clokwise Member
    114
    Nashville
    Hi! I am looking for an iPad mount that meets the requirements below. I know there are lots of mount options, but I am trying to be specific so I thought I'd ask. And any pictures of your specific setup is always appreciated.
    • For front seat passenger (no need for headrest mounts for backseat passengers)
    • No screw holes, adhesives, or anything permanent required
    • Will fit an iPad in a case
    • Does not require a special case or mount to be installed on the iPad itself (if an adhesive piece an be installed on the back of an existing case that would work)
    • Able to easily remove and put back in when needed.
    Thanks!
  2. dbastille
    dbastille Junior Member
    23
    New England
    I found this iMagnet for the iPad works really well. Very strong and holds even with case on iPad.
    You just stick a disk on case or back of iPad. It even includes a case with disk on it for the iPad 2/3.
    Only thing to watch is that if you leave the mount stuck on dash or something when the weather is hot it will come off. Easy to take on and off though.
    iMagnet Mount for Tablets | iMagnet
    Good Luck!
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    When I am using my iPad with Engine Link I just stand it up in its case and slide it in the small window just in front of the mirror. Nice fit.
  4. ou812
    ou812 Junior Member
    40
    A "Ram Mount" works in my 2010.
  5. t0pgear
    t0pgear Member
    50
    30
    Colorado High Country/LA/Bay Area
    The best IPad & Tablet | SeaSucker The seasucker mount is INSANELY strong. I have one for mounting gopros on the outside of my car, and no joke they use this same mount technology to mount bikes and surfboards to your car, its that strong. Your window would brake before that mount falls off.....
  6. clokwise
    clokwise Member
    114
    Nashville
    I really like the imagnet product. Does it suction to the prius dash pretty easily? The dash isn't exactly smooth and ideal for suction cups.
    Turn off signatures in Tapatalk Tapatalk
  7. dbastille
    23
    New England
    Yeah it sticks with just a push down clip....super strong.
    I have stuck it on the dash as well as on the console drink cover.
    Well worth it!
  8. clokwise
    clokwise Member
    114
    Nashville
    Awesome that looks great. That might be the one. Thanks.
  9. swaggingprius
    swaggingprius Member
    88
    29
    East Coast
  10. Ronnyguru55
    Ronnyguru55 New Member
    Los Angeles
    Have you looked into MagBak - it's something you can add to your iPad case or directly to iPad.
