1. Offline
    MJ225 New Member
    May 26, 2009
    Message Count:
    39
    Sorry for the noobie question, but are all pedals build to some standard size? Can I just pick any performance replace pedals and put them in myself? Thanks.
  2. Offline
    wvgasguy New Member
    May 6, 2009
    Message Count:
    1,256
    176
    a
    Your Vehicle Year:
    I guess when you're drifting with your Prius you really need a good foothold on the pedals?
  3. Offline
    shawnb2 New Member
    Mar 21, 2009
    Message Count:
    468
    Thousand Oaks, CA
    Your Vehicle Year:
    I'm hoping you're just speaking of pedals for the appearance to make it look more sporty? You realize this is a Prius right? To each his own I guess. I'm sure there are pedal covers out there that will work. Not like it's any different from any other automatic car when it comes to pedals.
  4. Offline
    Rokeby Member
    Jan 21, 2008
    Message Count:
    2,890
    591
    Ballamer, Merlin
    Your Vehicle Year:
    A note of caution here.
    While I don't have a Gen III, what I see in my Gen II suggests that
    adding a generic pedal appearance set may not be a good thing. Not
    really bad or unsafe, just not good if you're looking for good-2-high
    MPGs.
    On the Gen II:
    * The "go-pedal," accelerator, and its supporting arm are a single,
    hard, smooth (one might even say slippery), light weight plastic
    casting without a covering pad.
    * The brake pedal and its supporting arm is a unitized single metal
    piece with a soft, somewhat sticky rubber covering pad.
    (Could one of the Fortunate Few Gen III owners check what the current
    arrangement is?)
    Why does the brake pedal get a protective pad, but not the go-pedal?
    I suspect it has to do with the very small pedal movement that we use
    to move between blue arrow regen, no arrow glide, and yellow arrow
    electric drive. The go-pedal/shoe combination is the interface between
    the demi-intelligence of the HSD and the assumed higher intelligence
    of the operator. It is probably a near-slippery smooth surface for a
    purpose and making it thicker and stickier may add some static at the
    interface, as when some posters have experienced that wearing heavy
    winter boots nets them lower FE/MPGs... just a thought.
    Automotively speaking this is a case of, What is purportedly good for
    the goose (non-Prii), is not necessarily anticipatibly good for the
    gander (our beloved Prii).
Share This Page
