1. Offline
    vertex New Member
    Mar 27, 2009
    585
    105
    new york
    Your Vehicle Year:
    I bought a salvage Prius last summer and rebuilt it with the idea of doing my own PHEV conversion. My plan is similar to what Nikki did, but I plan on NOT blowing up batteries!
    First, let me say that everyone (not here) said I was nuts for rebuilding a salvage Prius, but I have the car running really well now, and have it legally licensed and on the road, which means I got through both the salvage inspection, and the standard safety and emmisions inspections here in NY. In that process I learned a lot about the car, which was my goal in rebuilding it (besides the challange).
    Now that I am working on the next phase, PHEV conversion, I am looking for partners to work with me on the development. Others in this forum have mentioned that you need to be a EE to do this, have no fear, I am. As far as the hardware design, custom PCBs etc. I have no conern about getting that done. However, programming is my Achilles heal. I am looking for someone to work with me on that aspect of the project. Of course, anyone else that wants to contribute in any area, is more then welcome to join the effort.
    As I said before, I am looking at the general approch that Nikki used, that is adding extra Prius battery packs. The cost, KW/$ is much lower with used Prius NiMH batteries, then with LiO, which of course, I prefer, but can't justify the expense today. I also refuse to use lead acid, not enough bang for the buck.
    I plan on only charging, and using 1 pack at a time, and switching packs dynamically. My first task will be to reverse engineer the pack, unless someone has already done that.
    I will modify the pack to use more of the battery capacity, but have the Prius think a standard pack is connected. Not only will the packs HV need to be switched ( I think I can use the relays in the packs) but so will the CANBUS. This will need to be done intelligently, so that the switching does not create errors.
    I did not see any commercially available chargers that are reasonably priced, so I last year I designed one, which I have yet to prototype. The cost of the material, including the batteries should be under $3000. I have a spare battery pack to start with.
    Anyone interested?
    Howard
    1 people like this.
  2. Offline
    Sep 6, 2005
    1,377
    191
    Long Island, NY
    Your Vehicle Year:
    You are trying to re-invent the wheel all over again, again.
    My advise is, "google" about PHEV conversions and learn wherever had happen in the last 5 years, study past cases of fairlures and advancements, the best source is Cal-Cars.org as a source of information and in PriusChat is full of threads about.
    Associate yourself to one of the EAA chapters, here in Long Island is one with bright minds in all electric and Hybrids vehicles.
    1 people like this.
  3. Offline
    vertex New Member
    Mar 27, 2009
    585
    105
    new york
    Your Vehicle Year:
    I already reviewed everything online. Everything I saw seems to be half baked and too expensive, except for the new offering from Enginer in China. For instance, the need to shut the car off, and restart when the battery dies in EV mode. I think ther is a better way. I'll look into EAA, thanks for that tip.
    1 people like this.
  4. Offline
    band New Member
    Jun 13, 2009
    NorthWestern USA
    Your Vehicle Year:
    I would sure look at Norm's BMS+ system. If installed correctly with a proper, fully safe-guarded charging system (temperature and voltage cutoffs, plus timers), it works wonderfully.
    Best of luck. b. anderson
    1 people like this.
  5. Offline
    hobbit New Member
    Mar 23, 2005
    4,089
    443
    Bahstahn
    Your Vehicle Year:
    Any of the contactor-based systems I've looked at so far do not
    take any cross-pack currents into account. You could be the
    first to do it differently, because I probably won't have time to
    get that far.
    NY state, huh? East or west?
    _H*
    1 people like this.
  6. Offline
    vertex New Member
    Mar 27, 2009
    585
    105
    new york
    Your Vehicle Year:
    I'm located in Westchester County. I had another crazy idea. I am thinking of a 4WD system, where the rear propulsion system works as the primary drive system in EV mode. I would pull the accelorator sensor and feed that into my computer and my computer would produce its own output to control the Prius via the accelorator input. (simplified description). Has anyone ever made a 4WD Prius?
    1 people like this.
  7. Offline
    miscrms Plug Envious Member
    Aug 21, 2007
    1,436
    201
    Phoenix, AZ
    Your Vehicle Year:
    This has actually been done, but I wouldn't think it is particularly well suited to a Prius. Since the Prius already has motors and a very nice control system, you might as well use them. Where this sort of system is employed is usually in converting a non-hybrid vehicle to hybrid.
    I actually considered this for a while a year or two back. I was considering a small SUV like a RAV-4 that is available in both FWD and RWD versions. If you bought a used FWD, and a junked rear end from a 4WD you'd pretty much have all the mechanical parts you need. Add a pair of DC motors to drive the rear axle shafts, a pair of DC controllers and a battery pack and you'd be in business for pretty cheap. I was thinking of a return to center style joystick on the console as a simple way to control the electric drive forward and reverse/regen.
    Rob
  8. Offline
    Aug 21, 2007
    1,436
    201
    Phoenix, AZ
    Your Vehicle Year:
    BTW, nothing crazy about buying a salvaged Prius with the intention of building a PHEV out of it ;)
Share This Page
