1. Offline
    silverbulletgrmi New Member
    Start a Conversation
    Aug 26, 2008
    Grand Rapids, Michigan
    Your Vehicle Year:
    I have a Sprint Centro phone using the Palm operating system and I can't seem to get my Contacts to upload via Bluetooth to my Prius's Phonebook. I've mangaed to get the phone to pair with Bluetooth so I can make a call but can't get my contacts to upload. Can anyone please help. Thanks.
  2. Offline
    albob New Member
    Jun 25, 2008
    Your Vehicle Year:
    This is the method I used (as found on LetsTalk), but it transferred all of the numbers as "+1"...the names went over fine. Please let me know if you have any better success.
    http://toyota.letstalk.com/brands/toyota-bt/pdf/398_05Navi.pdf
    On the Steering Wheel
    Press the Off-Hook button
    On the Nav System
    1. Select “Settings”
    2. Select “Phonebook”
    3. Select “Transfer Data”
    4. Select desired Group
    5. Select whether you wish to “Add” or ”Overwrite”
    On the Phone
    1. Select “Contacts”
    2. Highlight any entry you wish to transfer
    3. Press the “Menu” button
    4. Under the “Record” menu, select “Send Contact”
    * or select “Send Category”
    5. Select “Bluetooth”
    6. Select “Handsfree”
    7. Select OK
  3. Offline
    Aug 26, 2008
    Your Vehicle Year:
    I tried the procedure outlined above and it doesn't work. I called Toyota Customer relations last night and they walked me through it again and it doesn't work. When I select "Bluetooth" and then "HandsFree" it sudden says disconnecting and the car screen says transfer failed. I also don't know how to highlight my contacts in my Centro? I have 900 contacts all saved in one group in Outlook as Contacts on my Centro phone.
Share This Page
