PiP Regen Behavior?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Redpoint5, Feb 14, 2016.
  1. Redpoint5
    Redpoint5 Senior Member
    1,026
    508
    Portland, OR
    Please limit discussion to the topic of regen behavior. Post discussions of engine coolant temperature and engine-on behavior in another thread.
    I have noticed on several occasions now during long descents from Mt. Hood or Creator Lake, that regenerative braking momentarily ceases charging the battery, and the engine kicks on. Watching my Torque gauges, the 3 battery temperature probes and the 2 inverter probe temps never rise above normal. The state of charge was at 50% or less, so capacity wasn't an issue.
    What is the most likely cause of kicking out of regen? Have you noticed any temperature (or other) thresholds that kicked you out of regen?
    I don't understand why the engine must come on when speed isn't very high and no power is required. It's one thing to cease regen, and another to fire up the engine.
    FYI- Car was in EV mode with HVAC off, under 60 MPH.
    EDIT:
    Here is a video showing the described behavior:
    #1 Redpoint5, Feb 14, 2016
    48,946
    what kind of elevation drop are we talking? i'll try to replicate. is it 10 degrees there too?
    markabele likes this.
  3. Redpoint5
    1,026
    508
    Portland, OR
    From Mt. Hood, we're talking about 4,000 ft drop and about 10 miles of pure coasting / regen. Perhaps only the first 5 miles or so involves about a 6% grade. If I allow the car to stay near 60 mph, I can make the descent with regen kicking off just once.
    Creator lake was brutal, with near full regen for miles on end. I went in and out of regen many times, going from nearly zero EV range to 8.
    Outdoor temperature was probably around 50 degrees.
    I'll try to remember to record what happens the next time I'm up a mountain. Might be headed to Mt. Baker for spring break, or perhaps Yosemite.
  4. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    The engine will run to keep the coolant temp above 115F or so. With low ambient temps (and heater use) it doesn't take long to cool down.
    Silver Pine Mica likes this.
  5. Redpoint5
    1,026
    508
    Portland, OR
    HVAC wasn't on, and the trigger for the engine coming on was excessive regen, not engine coolant temps. I should have also mentioned I was in EV mode the whole time except when I exceeded regen.
    Good info though for those running the HVAC.
  6. bisco
    48,946
    there must be another parameter. charge speed?
  7. Redpoint5
    1,026
    508
    Portland, OR
    I'm ashamed to say I forgot one important temperature to pay attention to; MG2! I have no idea what temperature was reached as I have that gauge on a different page than my other temps.
    After reading the most excellent info in this post, it appears the maximum allowable temperature for MG2 is about 150C, or 302F.
    It's important to note that I have 100% blocked my lower grill, so that may contribute to increased MG temperatures.
    I do have a min/max temp gauge set for MG1 and MG2, so I'll monitor these temps to see if there is an upper limit at which MG2 is forced to stop regenerating energy. I'll note the temperatures observed next time the car kicks out of regen mode. Then I'll see if there is a correlation to regen shutdown and MG temperatures. Finally, I'll see if removing the grill block allows for reduced MG temperatures, or improved sustained regen.
  8. Redpoint5
    1,026
    508
    Portland, OR
    The more I think about it, the less I believe the MGs are to blame for kicking out of regen mode, but I hope to do a test soon.
    That brings up my next question; what are the various maximum temperatures for the battery, inverters, and MGs? I want to set an alarm when approaching those temps so that I won't miss it. From what I've read, it seams 300F is the max for the MGs, but I'd like to confirm if someone knows.
  9. roflwaffle
    roflwaffle Member
    381
    75
    Orange County
    I'm remembering this right, the engine will kick on based on what the last HVAC temp setting was. If it's set to 70, even if HVAC is off, it'll still kick on the engine to keep it at 70.
  10. markabele
    5,084
    1,782
    Nebraska
    Nope, not true.
  11. roflwaffle
    roflwaffle Member
    381
    75
    Orange County
    I'll double check, but I seem to remember this happening. It could be coincidence too. The next time I steal the wife's car for a long drive I should be able to keep an eye on things with torque.
  12. Redpoint5
    1,026
    508
    Portland, OR
    The engine does not come on due to HVAC settings when the HVAC is turned off.
    My particular inquiry is definitely linked to prolonged regen, and nothing else. Light prolonged regen takes much longer before kicking out of regen, and heavier prolonged regen shortens the amount of time the battery recharges before the engine turns on and regen is halted. After a brief period of no regen with the engine running, it will go back into EV mode and resume regeneration. I can only assume this is because a temperature fell back within operating range.
    In my mind, the only 2 questions are:
    1. what temperature probe is causing regen to momentarily turn off?
    2. what is the upper temperature limit for that probe before regen turns off, and what temperature does it have to fall back to before regen is re-enabled?
  13. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I don't have an answer for you but I notice the same thing coming down the Santa Cruz mountains on 17 and from Yosemite on 108. I don't monitor my temps but I do notice that if I kept speeds at around 50 mph for those two descents, I'm able to keep ICE off. This is easier said than done as cars behind me go much faster. Once I hit 60 mph, it's inevitable for the ICE to turn on as I need to brake harder which raises the temperature of "whatever" that turns on the ICE or I go faster than 64 mph which triggers the ICE.
    Redpoint5 likes this.
  14. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    My observation is the same as yours. I know others are saying the engine will not activate to heat the car if HVAC is off, but I believe it does.
    _____
    Set temp to 75° - Leave car off for an extended period - Turn on car with outside temp at 50° and HVAC off - Engine starts.
    Set temp to Low - Leave car off for an extended period - Turn on car with outside temp at 50° and HVAC off - Engine does not start.
    _____
    Outside air flowing through the vents will match the temperature setting even with the HVAC off.
  15. markabele
    5,084
    1,782
    Nebraska
    You must have a glitch. No one else's PiP does this.
  16. Fred_H
    Fred_H Misoversimplifier
    546
    473
    26
    Germany
    min cat temp?
  17. mmmodem
    2,732
    1,703
    Bay Area, CA
    Are you sure HVAC is OFF and not on lowest fan setting?
  18. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    SAronian, when do you turn off the HVAC, before shutdown or just after startup?
  19. Redpoint5
    1,026
    508
    Portland, OR
    Please stick to the topic of this thread (regen behavior, not engine starting). I'm not interested in guesses as to what causes the engine to come on. If someone knows what causes regen to momentarily stop, or has run some tests to narrow it down, that is useful. Providing info on maximum operating temperatures for various components is also helpful.
    mmmodem- Thank you for providing your experience. I'm not sure if I'll drive on the 108 when I visit Yosemite next month since Google has me take the 120 from Stockton. Perhaps the Siskiyou pass will provide enough of a hill to give me the data I need.
    My ultimate goal is to know what temperature threshold is causing regen to cease, and to set an alarm on Torque when I approach the limit. This way I can briefly use friction braking to bleed off some speed before temps exceed the regen parameters. I'll also experiment with providing more airflow to cool whatever component is getting too warm.
    Can't be it. The regen will kick off even if I had turned the car on in EV mode and left it there, never having run the engine. Cat temperatures are only relevant when in HV mode.
  20. roflwaffle
    roflwaffle Member
    381
    75
    Orange County
    Yeah, it's been my guess that the engine coming on is based on some HVAC temperature setting, especially since I can turn off the HVAC with the heater set to something highish and still feel some heat from the vents, which in my mind means the valve between the heater core loop/engine loop is still open even if I turn off the fan. The next time it's cold I'll try setting it to something higher in ready (~85), turning off the HVAC (fan off, no AC), and see if it still kicks on the engine. If I have enough time with the car I'll see if different temp settings with HVAC off change what coolant temp the engine kicks on traveling downhill in EV mode.
