Plastic in undercarriage broke off. Need replacement clips.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ThreeDEf, Mar 10, 2012.
  1. ThreeDEf
    ThreeDEf Junior Member
    cincinnati, oh
    Some genius lost something from their truck bed and it landed right in front of my car. I avoided it with my tires but had to drive directly over it. It pulled off a piece of plastic that is thankfully still hanging on. I believe I need to replace the clips that were once I'm place to hold it there, but I have no idea which clips it requires. How can I find this out?
    The panel is located slightly behind the front wheels and I'm not sure what it exposes when it hangs there. Currently rigged up but not permanently at all.
    2010 Prius III
    Thanks.
  2. Analogkid1958
    Analogkid1958 Member
    119
    61
    Yorktown, IN
    Your dealer might be able to set you up, but not all dealers have a body shop, so you may need a body shop to check it out. While you're at it, have them check the sheet metal structure under there.
    I ran over a piece of truck tire a while back and wound up replacing the entire plastic nose tray as well as the radiator supports and cross member. Thank heavens for good insurance! Hopefully this won't apply to you, but better to be safe.
    Good luck!
  3. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Look at this post for cheap replacement clips/pins.
  4. Mike500
    Mike500 Senior Member
    2,593
    763
    Equivalent replacements are inexpensively available on eBay;
    I got these 8mm small ones from this guy in the US;
    eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
    They have Philips screws, which makes them hold better and take off easier. I got them in 4 days.
    It took me two weeks to get the larger 10mm ones from Hong Kong;
    Hope this helps all...............
  5. ThreeDEf
    cincinnati, oh
    I purchased the clips, but they still had to touch-up some of the Used car since I got it right after they got it, so I mentioned it to the dealer and we will see. I'm definitely not going to pay for a repair, I'd rather replace it myself.
  6. Therand
    Therand New Member
    31
    Atlanta, GA
    I found that the clips wear out over time. This was especially true for removal/replacement of clips surrounding the oil access panel during oil changes. I took the two different sized clips with me to Lowes and found replacements. They were not exactly the same but were the same size, had the center pull pin/spreader design, and when installed held the plastic undercarriage firmly. I ended up spending around $10 for two, five clip bags and kept the extras for future spares.
  7. LuvMy2010
    LuvMy2010 Junior Member
    33
    Wichita
    Similar situation happened to me and I got an entire new under cover because there's a TSB for warped plastic in this area. It's TSB 0032-11. Check it out!
