1. Offline
    priussoris New Member
    Apr 5, 2007
    1,005
    Well the 118308 draw tite trailer wiring harness arrived today.
    and it does work on the 2007 prius.
    Follow the EVNUT.com info on prius mods for plug and play and it will work just fine.
    I even converted the reg. incand. lights on the trailer to LED's just to keep the amp draw down.
    I did have a slight problem with one connector , in regards to removing the pins, the locking bar did not release them untill I had pulled it completly out. ( as seen in the pic.) I got nervous at that point, but took my time had a cold drink and all of a sudden JOB done.
    I did put some caulking around the harness as it went through the rubber grommet , since I go through a laser car wash that has an under carriage wash, just to make sure it is water tight.
    I also drilled another ground screw just above the OEM grnd point , was not sure if disconnecting all the grounds back there before removing the battery grnd would make a problem. So a hole was born.
    [attachmentid=11559]
    [attachmentid=11560]
    [attachmentid=11562]
    [attachmentid=11563]
    [attachmentid=11564]
    [attachmentid=11565]
  2. Offline
    Chris_Kewl New Member
    Apr 25, 2007
    Kent, OH
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(priussoris @ Sep 20 2007, 04:24 PM) [snapback]515448[/snapback]</div>
    I went to EVNUT.com and I cannot seem to find the trailer wiring harness information page. Can you guide me to a guide on how to install a wiring harness for a trailer? I am using a U-Haul trailer for a January trip and I want to make sure I have everything right.
    I also own a 2007 Prius.
    Thanks!
    Chris
    I am also going to get a Curt hitch, either from UHaul or someplace else. They quoted me $250 including instal for this, which is just too expensive. Any suggestions would be great on where to go and how to do this.
    Thanks!
    Chris
  3. Offline
    05 Solar Prius New Member
    Mar 17, 2008
    24
    Reno Nevada
    Your Vehicle Year:
  4. Offline
    timm Rural Mail Carrier (Sub.)
    Dec 29, 2006
    119
    Spring Green, WI
    Your Vehicle Year:
    Here's a pic of how I store the wires and connector in the little cubby inside the vehicle. I shut the hatch on the wires when actually using a trailer. Two years old now... and the plug is just like new! If I had it hanging outside all the time exposed to road salt and crud this would not be the case.
  5. Offline
    n8kwx New Member
    Feb 10, 2004
    236
    Arlington Heights, IL - NW Chicago Suburb
    Your Vehicle Year:
    Quick caution on timm's suggestion.
    I don't know if your harness is the "modulite" one.
    I used the generic modulite (electrically isolated) unit on my Camry. Like timm I keep my harness in the trunk.
    Be careful not to get the wiring caught in the trunk latch when closing the hatch! :eek:
    I did on my Camry, and saw firsthand how the modulite prevents blown fuses (or worse!).
  6. Offline
    Dec 29, 2006
    119
    Spring Green, WI
    Your Vehicle Year:
    Good Point n8kwx! :eek:
    Take a good look at my pics to observe how the wires are well to the side of the latch. In addition... double-check everything, everytime when hooking up a trailer on any vehicle to insure that nothing is going to get pinched, kinked or ripped off when going down the road.
  7. Offline
    coturstyle New Member
    Aug 12, 2007
    Cleveland
    Your Vehicle Year:
    Craig,
    What type of weight do you pull? I am thinking about taking a storge box, attached to my hitch, down to Florida. I've had a bike rack w/two bikes on the same trip. Just want to make sure I don't over think what the Prius can do!
    - Stef
  8. Offline
    momocentur New Member
    Mar 17, 2009
    Massachusetts
    Your Vehicle Year:
    I have terrible luck with electronics so I've been nervous about using EVnut's adaptation. I see that Drawtite now has a kit for the Prius II (P/N 119146KIT from etrailer.com). Anyone have any experience with this kit?
Share This Page
