1. Offline
    jdouge Junior Member
    Start a Conversation
    Oct 31, 2006
    Coastal California
    Your Vehicle Year:
    I recently got my 2007Prius back from the body shop after a 13k repair following a crash that crumpled my front end. The car seemed to be doing fine, until a long, steep climb had the battery drop to one bar, speed dropping to 40 despite a floored accelerator, and a red triangle that appeared briefly before disappearing just as we completed the climb. It's the dropping speed despite a floored accelerator and the warning light that have me worried.
    I've driven that hill frequently with no issues -- in fact, climbed the same hill the day before, and the other side of that hill with no problems later the following day. I had taken my Scangauge off while the car was in the shop; I put it back on after getting home from the hill trip, and it reported no errors.
    I'm not sure what to suspect, or what to do next. My issue was quite similar to the one summarized in this recent post:
    http://priuschat.com/forums/gen-ii-prius-main-forum/95641-power-loss-low-battery-during-climb.html . . . with some important differences: I did get a red error light, my loss of battery bars and general thrust was not "sudden," and my issue closely followed a major crash and repair.
    Haven't been up a major hill since (the hill in question is a distance away, we were heading on vacation) and have experienced no similar situations. Subjectively, it feels like maybe around town and on the freeway the Prius has a little less power, doesn't regen as much, gas mileage seems average or maybe a bit below, but I can't really say that for certain. (I had a non-hybrid rental with my Prius was in the shop for two weeks that went VROOM pretty easily, and may have skewed my perceptions).
    Browsing further, especially on this thread of common problems, I ruled out the battery vent issue (it was and is unblocked), probably ruled out the inverter coolant pump issue because I did not get a concurrent VSC light with the red ! light ( I don't think so, anyway, I was pretty freaked out and focused on my MFD and that red light!). I did perform the DIY 12v battery test from this thread and get some slightly low readings: 12.3 average for the unloaded battery (healthy range 12.4-12.8), 11.9 for a loaded battery (12.0 healthy minimum), and 14.3 for a charging battery (13.6-14.4 healthy range). I did some easy stuff myself: changed the air filter, checked tire pressure, etc.
    My first impulse was to get my HV battery, regen brakes, and ECU (the power was, apparently down at some point -- kept my memorizes NAV points but the annoying MFD/reverse beeps are back) checked by a Prius tech, but I don't really want to pay out of pocket for that (or even whether those are the likely culprits). At the same time, I don't want to take it back to the body shop without a clear idea of what's wrong.
    My options, I think, are:
    - replace the 12v battery, but I don't really know if my readings suggest real trouble there
    - have a Prius tech check the car out, out-of-pocket
    - take it back to the body shop with a vague descriptive complaint, and hope they agree to try and find something, and are competent at that
    - try and figure out how to track HV battery current and block voltages (another issue discussed in the common problems thread above)
    - something else that somebody on here recommends (I am an avid Prius owner and DIY as much as I can, though I am the farthest thing from a "car guy" or engineer).
    - drive up a nearby really big hill and try and replicate the problem (which I'm avoiding, but we do have another mountain trip in August, with even harsher grades).
    Any help appreciated.
    thanks
    doug
  2. Offline
    seilerts Battery Curmudgeon
    Mar 7, 2010
    3,296
    1,414
    Santa Fe, NM
    Your Vehicle Year:
    Not sure how you can get a brief red triangle that then disappears, other than perhaps the engine overheating or being low on oil.
    Do put your 12V on a battery charger, if you have one, at 4 amps or less. It takes many, many hours in Ready to bring it back to a full charge otherwise. Hook the ScanGauge back up and monitor BTA, SoC, and cell SoC delta (if possible -- I don't on one).
    Did you have the air conditioning on during the climb? Is there any reason to think that it may not be working correctly, like the compressor running high all the time?
    1 people like this.
  3. Offline
    andyprius New Member
    Feb 21, 2005
    2,181
    157
    Sacramento, California.
    Your Vehicle Year:
    Did you get the LSC done? Is your Inverter pump working? Is the coolant in the inverter reservoir full and gurgling ? Radiator and Overflow tank full??
  4. Offline
    Feb 21, 2005
    2,181
    157
    Your Vehicle Year:
    I'll bet the body shop did not bleed the air out or the Inverter coolant system properlyand/or the engine cooling system as well.
    1 people like this.
  5. Offline
    Oct 31, 2006
    Coastal California
    Your Vehicle Year:
    Thanks for the feedback, been checking through as many of these as I can today:
    It's not low on oil; unsurprisingly they overfilled it :) My Scangauge, as far as I can tell, will measure only voltage. Running/ready, it reads 13.9-14.0; engine off, it reads 11.9-12.2. Didn't have the AC on during the climb.
    Sounds like I need to recharge the battery, though .I'm trying to track down a friend of mine to borrow a battery charger; found a thread here on how to do it for a Gen II Prius.
  6. Offline
    Oct 31, 2006
    Coastal California
    Your Vehicle Year:
    I have not had the LSC done, but I did not get an error code, nor (I think) did the VSC and brake lights go on during the power loss, which seems to be the signature of an inverter pump failure. The reservoir is full and, when I run the ICE, churns and bubbles a little. Is that sufficient to show that the pump is working? It might just be the percussion of the ICE shaking the reservoir, but there are bubbles -- I'm just not sure if I'd say it's gurgling.
    The radiator looks low; in fact (it's hard to see with that apron in the way) I can't see fluid in it at all. If in fact they didn't bleed the radiator and therefore the fluid is low, then this would go along with seilerts' diagnosis of the problem -- the car may have been just at the limit of overheating.
    The only thing that makes me suspect that this isn't the key is that we got the warning light on a foggy morning; on the return trip up the same hill at over 80 degrees, the car did just fine.
    It seems like what I need to do is take the car back to the body shop and have them top off the coolant (if they forgot to bleed the air, is this sufficient now that the air has, I think, cycled out, or do I need to require them to do a complete flush?)
    I also will recharge the battery.
    Any suggestions on how to further determine the fitness of the inverter pump?
    Thank you for responding and tolerating my lack of automotive knowledge!
    doug
  7. Offline
    Flaninacupboard Senior Member
    Apr 25, 2010
    1,293
    193
    Midlands - UK
    Your Vehicle Year:
    You should look for movement in the inverter fluid with the ICE -off-, but the car in Ready.
    1 people like this.
  8. Offline
    2009Prius A Wimpy DIYer
    Mar 25, 2009
    2,469
    382
    Your Vehicle Year:
    The inverter coolant pump may be checked in IG-ON (not READY) mode. This way the ICE won't come on and you can hear the pump clearly (the only noisy thing running if you turn off the radio). I just looked at my inverter coolant reservoir recently. If I shine a strong light on the side of the reservoir and look down at the coolant (reservoir cover removed of course), then I can see the fluid fluctuating but no bubbles. If I shine the light on the surface of the coolant, then I do see really tiny bubbles (like pin holes or tiny spec of dusts) floating on top of the fluid surface and moving very quickly toward the front (radiator direction). Hope this helps and good luck!
    1 people like this.
  9. Offline
    Feb 21, 2005
    2,181
    157
    Your Vehicle Year:
    If you get the LSC done you also get free new SLLC in the inverter system as well as proper bleeding. At that time you may want them to check for the right stuff in the radiator and proper bleeding. Did the body shop put in SLLC in both systems. Did the body shop KNOW how to bleed both systems? Yes it is always a good idea to charge the 12 volt battery. Did you know that you can leave your car in ready all night and it will charge the 12V and only use ONE gallon of gasoline ? You should see "turbulence " in the reservoir. You can take that apron off so you can see the levels, they should be topped up. And no air does not cycle out
    1 people like this.
  10. Offline
    Oct 31, 2006
    Coastal California
    Your Vehicle Year:
    I was able to see turbulence in the inverter system (bubbles looking into the reservoir in the top, and feeling movement in the tube leading up to it) AND hear the pump (I think, it was a pleasant pump-like sound right underneath the inverter fluid container) in non-ICE "ready" mode.
    Also charged the battery with a really nice charger my friend borrowed from a university MechE lab, so that should do the trick.
    Since I'm determined to do the LSC, we filled the radiator with generic antifreeze/water for the short-term-- it needed more than a quart.
    Unfortunately, we did this before reading andyprius's post. When I get the LSC done, should I just have them bleed the radiator, and drain and fill the coolant? Is that the only way to be sure that system is 100%, air out, etc.?
    I am taking the Prius up a local steep hill tomorrow unless anyone thinks that's a dangerous idea :)
  11. Offline
    V8Cobrakid Green Handyman
    Jun 6, 2004
    3,775
    132
    Your Vehicle Year:
    oil isn't supposed to be overfilled either. that's a small problem itself that can potentially cause problems down the line... not quite yet?.. idk for sure.
    if your 12v looks to need a charge.. then it's dying.... if it's dead, it's dead.. it won't really show dying till it's dead...
    it seems like you weren't carrying excess weight or anything obvious.
    there are a few things it could be still... a clogging battery fan... do you ever hear a fan noise at the rear passenger seat? if you do, can you feel air being pulled in?
    the other thing that's less likely is an ignition coil failure.. but from what i've seen and experienced, it seems to only happen when water is around... i think water caused mine to start to fail and i didn't see it till over 20k miles later...
  12. Offline
    Jun 6, 2004
    3,775
    132
    Your Vehicle Year:
    actually.. since you are post crash.. ignition coil(s) could have possibly had bad ignition... not the spark plugs fault.
  13. Offline
    Feb 21, 2005
    2,181
    157
    Your Vehicle Year:
    Jdouge: Great progress on all accounts. Yes, I would have Toyota ascertain that SLLC is in Radiator too, NO, it is not a problem going up the hill today, now that you are aware of conservative driving and use of AC. DO have Toyota assure you the HV Pack cooling fan is NOT running backwards. The rule on saving on Auto repair is: Do what you think you can do. Socal rates are now almost $300/ Hour. :cheer2:
    1 people like this.
  14. Offline
    Mar 25, 2009
    2,469
    382
    Your Vehicle Year:
    Make sure the dealer check for leaks in the radiator too. Good luck!
    1 people like this.
  15. Offline
    Oct 31, 2006
    Coastal California
    Your Vehicle Year:
    Car made it up a five mile grade twice in the heat with all loads running (A/C maxed, stereo, headlights, okay not wipers) and never dropped below three bars on the HV battery. Looks good.
    I have two last questions:
    1) About a quart of what's in the radiator is what I put in (generic antifreeze and water) -- the level is fine now; is it important hat I go to the body shop and have them drain and fill it (and bleed it, not knowing if that's why the level was low last time)?
    Also, the 12v battery readings have me confused, especially since the MFD and Scangauge are giving different readings (at literally the same time -- sorry, can't format this "chart").
    ACC Mode/IG-ON/READY
    Scan gauge 11.8 / 11.6 / 13.9
    MFD 12.2 / 11.9 / 14.3
    Scangauge shows 13.7 constantly when driving the vehicle.
    2) Is this a 12v battery that needs to be replaced?
    thanks
    doug
  16. Offline
    koolingit Member
    Mar 17, 2009
    110
    27
    Mocksville NC, USA
    Your Vehicle Year:
    I think you need a third opinion on the voltages. Do you have a digital volt meter?
    According to your MFD, your battery is borderline okay.
    According to your scan gauge, it's time for a new battery.
    I don't know what a volt meter will say.
    1 people like this.
  17. Offline
    Oct 31, 2006
    Coastal California
    Your Vehicle Year:
    The volt meter that was on the pretty high-end battery charger gave readings (pre-charge) that were higher than the MFD or the Scangauge -- it indicated that the battery didn't need recharging, though we did some anyway. So I guess my three readings of the battery show healthy/borderline/replacement . . . a tough call. Does it make sense to monitor the battery over time and when it starts to lose charge, even a bit, replace it in 6 mo/a year? Normally I am pro-preventive (or, in this case, pre-emptive maintenance). Still, I want to replace my battery only once, and I'm hoping to drive long enough that I want to wait as long as is reasonable before going over to the Optima battery.
    Regarding the radiator and its contents at the moment -- having Toyota check (and, perhaps, drain, fill, and replace the fluid, etc.) it when I have the LSC done would, I assume, be an extra expense. Instead, should I take it back to the body shop which just replaced the radiator, but apparently misfilled it (didn't bleed it would be my guess) and lobby them to repair it without cost, but risk them screwing it up again?
    I realize these are increasingly subjective questions, but I appreciate any input.
    doug
  18. Offline
    Mar 25, 2009
    2,469
    382
    Your Vehicle Year:
    Harbor Freight sells cheap multimeters and I have compared the voltage measurements with Fluke meters and found them quite accurate, definitely good enough for checking 12V batteries.
    If the body shop had just replaced the radiator then yes they should be responsible. Bring the car back and demand they do it right. Good luck!
    1 people like this.
  19. Offline
    Jun 6, 2004
    3,775
    132
    Your Vehicle Year:
    12v battery.... if it says it's ok.. it's dying.. if it says it's dying, you probably won't be able to get into the car electronically... without a jump under the hood.
    it goes downhill fast. the way i see it, it's dead enough, change it out now to save yourself the headache in a little bit.
    as 2009Prius said, have the body shop top it off... once they do.. take it around the block at a quick pace.. get things moving in there.. come back and check again.
    1 people like this.
  20. Offline
    Oct 31, 2006
    Coastal California
    Your Vehicle Year:
    Dropping the car off at the body shop tomorrow, they admit fault and will provide (ick!) a rental. Ordered an Optima battery and hopefully . . . that will be the end of it.
    thanks folks
    doug
Share This Page
