1. Offline
    pardreamer Member
    Start a Conversation
    Jan 30, 2008
    103
    San Diego
    Your Vehicle Year:
    [IMG]I am thinking about Powder Coating my original Prius V rims with deep blue color similar to the color on the logo? My Prius V is a Sky Blue Metallic so I think it goes well with deep blue rims. What do you think? Similar color to the rim in the pic.
  2. Offline
    Nervous Junior Member
    Aug 25, 2012
    33
    La Canada Flintridge, CA
    Your Vehicle Year:
    Well, since nobody else has chimed in yet... I think anodizing will look better. Anodized wheels have the appearance of dyed metal; which should compliment the 'metallic' characteristic of your Prius' Sky Blue Metallic paint color. Just my $0.02. ;)
    Please keep us posted... I'd like to see pictures once you're done.
  3. Offline
    GloryThief Junior Member
    Dec 17, 2010
    55
    The Westside
    Your Vehicle Year:
    anodized wheels will fade in the sun eventually won't they?
  4. Offline
    KK6PD _ . _ . / _ _ . _
    Mar 24, 2008
    3,578
    617
    Los Angeles
    Your Vehicle Year:
    So will powder coating. Unless you get the powder base with a good UV inhibitor in it! It's worth asking the coatings place a question or two on UV! Nothing looks worse than a white powdery smutz on your nicely colored rims!
  5. Offline
    Aug 25, 2012
    33
    Your Vehicle Year:
    I'm fairly certain that anodized wheels will standup to the elements just as well as powder coated wheels will as long as they're properly cared for. More importantly, aesthetics are the primary motivator here... So, form has to take precedent over function.
  6. Offline
    12get12 Junior Member
    Feb 22, 2012
    64
    SF-Bay
    Your Vehicle Year:
    The picture looks good on that car because of the Stance, Wheel type and the wheel color to body color contrast.
    I don't think the deep blue color is going to look good with the color of your car. Don't do it.
  7. Offline
    2k1Toaster HID Guru
    Feb 14, 2010
    3,221
    769
    Rocky Mountains
    Your Vehicle Year:
    If you do that, you have automatically singled out your wheels as a modification. You are then pretty much required to get lower profile tires and lower the vehicle's stance so that it doesn't look silly. Just changing the rims will get you laughed at. If you are doing it because you just want blue rims, then do what you want. If you are doing it to make your car look good, then do it only if you know it is step #1 in a multi-step process that should be done in sequence rapidly.
  8. Offline
    Rosie Benitez New Member
    Sep 12, 2012
    Your Vehicle Year:
    I think it would look amazing!!!!!
Share This Page
