Power Loss
Discussion in 'Gen 3 Prius Technical Discussion' started by jwads, Jan 23, 2012.
  1. jwads
    jwads New Member
    63
    Los Angeles CA
    Was sitting in my car on my lunch break playing the radio and had my seat heater on, and all of a sudden my radio kinda went staticy and died and my car completely died. Had to power it back down then back up to get it running, battery didn't show very low, but when I went into start mode (non accessory) it immediatly started the ICE and charged.
    Wondering if this happened to anyone else?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    What mode were you in? Were you in IG-ON or READY? If latter, where you in any "gear" other than Neutral?
  3. jwads
    jwads New Member
    63
    Los Angeles CA
    Im not sure. I was in what I call AUX mode, like where your radio and stuff works but the car won't drive b/c I hadn't pressed on the brake. I was still in park, wasn't driving in any gear
  4. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    DO NOT run your Prius for too long in either ACC or especially ON (formerly known as IG-ON) otherwise you will drain the very small 12 volt very rapidly, which isn't good for it.
    I have a 2nd gen so I have no seat heaters (weren't available). ACC should be where the stereo works but you don't see any dash indicators. ON should be the above + turn all the warning lights initially and leave most of the dash indicators on. See pages 164-167 of your manual.
    If you want to sit there w/the stereo and esp. the seat heaters for a long period, you should be in READY mode (READY indicator on the left). Being in READY mode allows inverter to supply power to the 12 volt bus, charges the 12 volt and allows the ICE to fire up to maintain charge on the HV battery.
  5. ETC(SS)
    6,492
    Concur!
    You may want to start learning how to replace your 12V battery.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Don't do that. That's the simple answer.
    Tom
  7. ken1784
    ken1784 SuperMID designer
    2,940
    1,359
    67
    Yokohama, JAPAN
    Owners manual says...
    Code:
    [B]Auto power OFF function[/B]
    If the vehicle is left in ACCESSORY or ON mode (hybrid system is not operating)
    for more than an hour with the shift position in “Pâ€, the “POWERâ€
    switch will automatically turn OFF.
    Ken@Japan
  8. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    UK model turns ACC off after 1 hour to prevent flattening the 12v.
    just beat me to it Ken ;0)
  9. jwads
    jwads New Member
    63
    Los Angeles CA
    Good to know. I know I wasn't in that mode for an hour though, but still good to know. I was under the impression the Prius had a huge battery, so doing that wasn't a problem. Good to know!
  10. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Charge that 12V asap. 2 amps for 10 hours.
  11. jwads
    jwads New Member
    63
    Los Angeles CA
    Ya, ive been running it a lot since, and haven't kept it in AUX mode ever. How exactly does it flatten the battery? Why isn't it a normal charge recharge cycle?
  12. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    The "huge battery" (the HV battery, in the metal box that runs the width of the vehicle) is not in use when you leave it in ACC or ON (aka IGN-ON) mode. It's running off the tiny 12 volt in the rear corner which is not being charged via the inverter while in those two modes.
    This is why you should be in READY mode if you want to run the radio, seat heaters or any accessories for any length of time.
  13. richard schumacher
    7,663
    1,038
    United States
    To sum up: leave it Ready, shifted to Park, and the parking brake set. Then you can listen to the radio until it runs out of gas, which will take something between two days and two weeks.
  14. jwads
    jwads New Member
    63
    Los Angeles CA
    Ya, Ill have to do that from now on, I always thought it used the huge car battery. Is there any way to get a charge on the little 12 volt in the back from any of the main indicators up front?
  15. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
  16. qbee42
    18,058
    3,073
    Northern Michigan
    Your Prius must be Ready and not in N to allow the engine to charge the battery. If you sit in Park the engine will come on and charge when necessary, then turn back off.
    In Acc mode the small 12V battery is on its own; it doesn't get recharged by the big battery no matter how dire the level of charge.
    In Ig-on the 12V bus is being supplied by the big battery, but the engine cannot come on to recharge the big battery. All of the circuits are powered up in Ig-on, so it doesn't take a long time to run down the big battery.
    Tom
  17. lorraine
    lorraine New Member
    39
    monroe, ny
    My car losses power sometimes when I am driving it. I have to pull over and restart and then it is fine. Has anyone else had this problem?
  18. AtoyotA
    AtoyotA Junior Member
    Chicago area
    Hmmm, good clear explanation of the difference. I was never quite sure which did what. Thanks!
  19. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Can you give us more details? Do warning lights come on? Is the engine revving high, or is it completely off? Do you hear the hv battery fan running in the back?
    Power loss while driving is definitely not normal.
  20. lorraine
    lorraine New Member
    39
    monroe, ny
    No warning lights come on. Not revving high, everything seems normal. I told my dealer about this and he said he did not have any other complaints.
    Car is fine otherwise. Can it be bad gas?
