Power Loss
Discussion in 'Gen 3 Prius Technical Discussion' started by jwads, Jan 23, 2012.
  1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Bad gas would give you all kinds of warning lights, from flashing check engine for misfires, to the red triangle. It would set codes like P030x, P0A0F, P3190, P3191. The only thing I can think of is some type of overheating: engine, battery, inverter, transaxle MGs. The battery in particular will cause some odd behavior for high heat level before setting a code. The good news, if that is possible, is that warranty coverage is at a minimum 5 years, 60K miles.
    Is it completely random, or can you reproduce it? Under what conditions does it seem to happen? Is the gas engine running or not? What is the battery level?
  2. lorraine
    lorraine New Member
    39
    monroe, ny
    It appears to be completely random, which is the scary part. My dealer could not offer any explanation, which is not surprising since they are usually not very knowledgeable. I learn a lot more from this site.
    Thanks.
