Power outlet on lower dash broken
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sheepdog, Aug 9, 2008.
  1. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    I stuck a new gps power cable in the lower power outlet and when I pulled it out it was stuck-read too tight- and I pulled and the whole assembly came out.
    It appears to have blade type connections to the power cable but is it that easy to fix? and has this happened to others easily or did I in fact break it?
  2. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    That stinks. I have a cell phone charger that I thought the same thing was going to happen in my center console. I'm surprised some of these devices don't have better tolerances. After all, what's it been, like 50 years that a cigarette lighter have been in cars? :confused: You'd think they'd have the size down to a science by now. :)
  3. harold johnson
    harold johnson New Member
    charleston,sc
    The same thing happened to me when I plugged a GPS into the dash power plug. I went by the dealership, and they said it was not covered under warranty, and wanted over $100.00 to fix it!!!. Needless to say, I drove away.
  4. paulccullen
    paulccullen New Member
    276
    Seattle, WA
    Same thing happened to me in my '05. Cell phone charger fit too tightly, when I pulled it out the whole receptacle came loose and stopped working.
    It was months later (when I was installing an audio module and had the dash apart) that I got round to fixing it. The blade connectors looked a little flimsy, so I soldered the buggers on so they wouldn't disconnect again. :)
    I'm amazed that Toyota is still using the slightly undersized adapter in 2008 (four years after introducing the current model) as indicated by the OP.
  5. Sheepdog
    1,125
    Sanford FLorida
    blast. I guess I shall have to learn how to fix it myself then!
  6. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    Hmm. I had so much trouble plugging my gps in I thought I had the wrong cord at first. I guess I'd better be careful with it.
  7. Sheepdog
    1,125
    Sanford FLorida
    Paul, I wonder if their is a different sized unit I could hard wire in to replace the tight ones?
  8. GadgetCar
    GadgetCar Junior Member
    San Antonio, TX
    I have the same problem with both plugs. How difficult is it to re-plug it in?
  9. Sheepdog
    1,125
    Sanford FLorida
    judging on how easy it came out I would say the issue is how well will it stay in after being put back? Im hoping that a third party unit can be wired in but right now I dont have another car to try the plug in. Another non toyota that is. My wife said the phone charger was tight in her car. I did plug the gps traffic plug in the center console outlet but am not gonna be so quick to pull it out without using needle nose or the like to keep the outlet in place.
  10. Sheepdog
    1,125
    Sanford FLorida
    has anyone done any work or mods on the lighter receptacles? Just wonder if there are any tips or tricks to getting to them? and anything I have to watch for in wiring a new plug in?
    thanks
  11. HalBurke
    HalBurke Junior Member
    28
    Rockledge, Florida
    Hi Paul,
    How do you get to the back of the power outlets. Mine's been broke about 2 months. Im too cheap to have the dealer do it but i cant figure out how to get to the back. I am mechanically challenged....
    Best
    Hal
