Power Steering Light with C1513, Recommended Suppliers for Rack?
Discussion in 'Generation 1 Prius Discussion' started by MchEngNrd, Jul 9, 2014.
  1. MchEngNrd
    MchEngNrd Junior Member
    Indiana
    2002 Prius
    I
    7 months after the end date for the extended power-steering warranty, my system is on the fritz. Its exhibiting what seems to be the typical issues (from what I've seen on here), including the problem-problemSolved iterations and eventual shut-down of the power assist. While I haven't experienced any violent shaking, I have noticed that it feels as if its catching on something as I spin the wheel to the left (like a stick-slip condition), but only a couple times have I noticed this, and never when turning to the right (even as the issue present). More commonly it simply turns off without me noticing anything.
    I have access to techstream, so I used it to check for trouble codes and got C1513. It seems I'm looking at a replacement, unless recalibrating with techstream is an option (thoughts?) or someone is aware of a miracle cure. I plan to replace the unit myself if I cannot find an easy fix.
    The new part from the toyota dealer is reportedly entirely too expensive compared to the value of the car (2002 Prius with ~130k miles). So I would like to hear if anyone can recommend a good alternate source. I am extremely hesitant to go used, since this seems to be a ubiquitous problem, so I am currently leaning toward re-manufactured units. I would be very interested if a specific supplier addressed this issue so that this does not occur again.
  2. usnavystgc
    3,159
    988
    Tucson, AZ
    Unfortunately, there is not much data about this question since most have had it replaced via the recall.
  3. MchEngNrd
    Indiana
    2002 Prius
    I
    I thought that might be the case. I could call the dealership and beg, but I doubt that would work out very well.
  4. usnavystgc
    3,159
    988
    Tucson, AZ
    The worst they could say is no. :)
  5. ChapmanF
    15,074
    A few years ago I was totally about to pull the trigger on a Cardone 1A-1000 just when I got Toyota's letter about the warranty extension. As it happens I've never seen one close up and I don't know how they go about remanufacturing it, but if you try one, I'm sure a lot of PriusChat readers will be interested in how well it seems to work for you.
    -Chap
  6. MchEngNrd
    Indiana
    2002 Prius
    I
    Yeah, I think it was your post that I was reading about Cardone here on PC. I might just have to go off of general manufacturer reputation, unless someone is able to weigh in.
    I gave a call to the Toyota Dealer, but it became evident that the person I was talking to was neither well informed (saying things I knew were false) nor willing to look into it until I came in and paid the $100 to have them "diagnose" it for me. I might call back again hoping to talk to someone else and attack it from a different angle.
  7. MchEngNrd
    Indiana
    2002 Prius
    I
    I hate to leave posts abandoned, so I figured I would update. The issue has gone away almost entirely. Its done the crazy shaking thing a couple times in the morning when I was backing out of the driveway (I noticed some correlation to foggy mornings, but not enough to be certain). Since I doubt the new one will have the issue completely fixed, I'll just ride this one out until the issue becomes more regular.
  8. vaughnstark777
    180
    33
    Roy, WA
    2001 Prius
    I
    EBay has remanufactured OEM units for as low as $290.
  9. BigVanMan
    BigVanMan Junior Member
    27
    26
    Manchester, NH
    Hello all. I am new to the forums having just purchased a used first gen with 225k miles on it. I was worried about steering rack problems cropping up as well at that mileage. This weekend, my wife was driving it and got scared when she went to make a right and lost all power assist. Glad she was going slow at the time. I too would be interested in anyone's experience with any "rebuilt" units.
  10. ChapmanF
    15,074
    The assist really only matters when going slow - steering is easy at speed. The assist is programmed to taper away at speed anyway, and honestly while mine was on the fritz I could really scarcely tell it had gone out until I came to a stop and tried to park or something. Cruising, I would only notice that it felt a tiny bit heavier, which, to be honest, I sort of liked.
    So really, I wouldn't harbor any safety concerns about it cutting out at speed.
    You will be happier when it's fixed though. :)
    -Chap
  11. MchEngNrd
    Indiana
    2002 Prius
    I
    ChapmanF is correct. On the highway, I never noticed the effect, but in parking lots, it's quite difficult to maneuver. The primary safety concern is the erratic shaking that sometimes occurs (which has not effected vehicle control in my experience, but is certainly seems to have the potential to).
  12. ChapmanF
    15,074
    I also became pretty sure over time that the wet-dog-shake happened less often after I got in the habit of holding the wheel more steadily (not a white-knuckle death grip or anything, just having both hands on it most of the time with the fingers comfortably closed). It didn't seem only that this dampened the shaking when it happened; it seemed the shaking happened less. From back around that time there's a post where I was speculating about how that might be (using a lot of vague handwaving and not a single Nyquist plot). My explanation could be bunk, but the observation seemed real.
    -Chap
  13. Michael Lamb
    Michael Lamb New Member
    Virginia
    2002 Prius
    I
    Hey Chap I came across a garage that claims to take apart the PS rack and clean up the electrical surfaces. He has a nice write up with pics. Looks like a good DIYer could do the same. Maybe that is you? The priuschat site wont let me post the url though as I am new here, sorry. Maybe I can get around that restriction eventually.
  14. Michael Lamb
    Virginia
    2002 Prius
    I
    I have also noticed that if I hold the wheel tightly the shaking goes away in a few seconds. The shaking also only happens on cold/ cool mornings. With a afternoon sun warming no problems. I am rather convinced that the problem is lubrication stiffening inside the PS rack control box. That and/or the tin wiskers people chat about. I read one guy takes his apart and cleans up everything electrical with Jiffy Bright electronics cleaner/ preservative. Wish I had the guts to do that someday, maybe. Lots of fragile things in there is mess up if clumsy though. LoL
  15. ChapmanF
    15,074
    I've been known to post about using Jiffy Bath (a product from GC Chemical for cleaning and lubricating contacts), so you might be remembering me for that part. :)
    I also did buy a cheap rack from a salvage yard just to see if I could figure out how it comes apart, and I did post pictures and instructions for getting down to the torque sensor, so that might have been me too.
    Yes, a better grip on the steering wheel tames the problem. Just physics: what's happening is the whole steering assist system is becoming a simple feedback oscillator. A bit of electrical noise in the torque sensor makes the computer say "ah, driver is steering left!" so it sends "left!" to the steering motor, which makes the torque sensor say "right!" so the computer amplifies that and sends "right!" to the motor, so the sensor says "left!" ....
    Like in a lecture hall where somebody gets microphone feedback, there are just certain pitches that lead to sustained feedback because the system resonates. When your arms are more tightly coupled to the steering wheel, it makes the whole system a bit heavier and changes the resonant frequency, so the feedback quickly dies away.
    Nope, just electrical noise from the torque sensor contacts. If you have a Gen 1, you have lots of parts in the car that use mechanical potentiometers as sensors: the steering torque, the accelerator pedal position, and the positions of all three HVAC air doors. If you keep the car long enough, all of those sensors may eventually give you the same kind of noisy behavior. It's the steering gear jitters when the steering sensor does it, the Big Hand Syndrome when it's the accelerator pedal, and "is there a mouse in my heater?" when it's one of the HVAC door positioners. (The last diagnosis can be trickier if you park in a place where you really could have a mouse in your heater.)
    They all can be fixed the same way, by getting down to the dirty contacts and cleaning them. It's cheap and easy for the HVAC doors (at least the ones on the easy-to-get-to side of the heater), a little harder for the accelerator sensor (it's glued together), but quite a big job for the steering gearbox. It is not that hard to take apart once you have it out, but removing and replacing it is long demanding mechanical work.
    "Tin whiskers" are one way sensitive electrical contacts can go flaky, but not the only way. Nice thing about whiskers is there might be a way to 'burn' them away without having to get down to the contacts and clean them. Probably won't hurt anything to try (within reason), but I don't know that I've ever seen a "yeah I tried that and it totally solved the problem" here either.
    In later Prius generations, Toyota moved all those sensors to technologies that aren't sensitive to flaky electrical contacts.
    mroberds likes this.
