1. Offline
    usbseawolf2000 HSD PhD
    Sep 22, 2004
    Message Count:
    9,659
    1,270
    Queens, NY
    Your Vehicle Year:
    This post is for soon-to-be or wannabe Prius newbies... for those DIYers that change their own oil. This video demonstrates how easy for a Prius to drive up a ramp. The torque and power precision control of the electric motor shows the superiority without loud noise (gas engine) and chemical odor (exhaust).
    This precision control also make the bumper-to-bumper traffic a breeze to drive. If you have been behind a Prius in the traffic congestion and notice how rare you see the brake lights, this is why!
    [ame=http://video.google.com/videoplay?docid=3175183213517953777&hl=en]Prius: Precise control while driving up a ramp (using electric motor)[/ame]
    Video Description Text:
    This video demonstrate how easy a Prius can drive up a ramp to do an oil change. It highlights the torque response / control of the electric motor. You will notice that the gas engine is not running.
    In the video, you would hear two different sounds. The first rattling sound is from the brake hydraulic pump. The pump kicked in as I step on the brake to put the Prius in D gear.
    The second high pitch sound is actually from the inverter, not the electric motor. The inverter converts the direct current from the HV battery pack into alternate current for the electric motor to operate.
    The electric motor makes 295 lbs-ft torque @ 0 RPM. However, the computer controls this massive torque and makes it a very smooth acceleration.
  2. Offline
    mingoglia New Member
    Oct 25, 2007
    Message Count:
    841
    Gilbert, AZ
    Your Vehicle Year:
    I'm not going to lie. that was the most exciting video I've ever seen. ;) Just kidding. I have the same ramps and will be pulling them out this weekend as I now have 250 miles until my next oil change.
  3. Offline
    cycledrum I like Prius
    Apr 9, 2008
    Message Count:
    5,266
    432
    NorCal
    Your Vehicle Year:
    I've done a hundred oil changes on my cars and motos, but on this new car, I'ma let Toyota handle it.
    Kudos to you DIYers.
  4. Offline
    Jul 12, 2007
    Message Count:
    10,558
    430
    Adelaide South Australia
    Your Vehicle Year:
    Pity, Prius is a very easy car to change the oil and filter.
  5. Offline
    rigormortis New Member
    Feb 14, 2007
    Message Count:
    1,318
    san jose, ca
    Your Vehicle Year:
    i bet he cheated by using either an ev switch or just starting the car and getting it on the ramp and turning it off within 7 seconds to engine start
    or maybe re reversed the footage!
  6. Offline
    Feb 26, 2007
    Message Count:
    7,432
    984
    Carmichael, CA
    Your Vehicle Year:
    Nah, if the car is already warm, driving up the ramps without the ICE is not a problem. I just did the same last week when changing the oil. You can actually stop partway up the ramp if you want.
  7. Offline
    Sep 22, 2004
    Message Count:
    9,659
    1,270
    Queens, NY
    Your Vehicle Year:
    I used the EV button because I didn't want to waste gas to warm up the engine (and the oil) just to drive up the ramp and drain the oil. That in itself is a cool way to use the EV mode.
    Dogfriend is right, I could've driven up the ramp without activating the EV mode.
  8. Offline
    Flying White Dutchman New Member
    Dec 29, 2007
    Message Count:
    3,765
    235
    Your Vehicle Year:
  9. Offline
    Jul 12, 2007
    Message Count:
    10,558
    430
    Your Vehicle Year:
    You are supposed to warm the oil before draining, it flows better and will have more muck in suspension to run out rather than settled on internal horizontal surfaces.
  10. Offline
    2009Prius A Wimpy DIYer
    Mar 25, 2009
    Message Count:
    2,152
    317
    Your Vehicle Year:
  11. Offline
    Sep 22, 2004
    Message Count:
    9,659
    1,270
    Queens, NY
    Your Vehicle Year:
    A quick google on Rhino Ramp came back with the incline angle of 17 degrees.
    1 people like this.
Share This Page
