pressing the brake, but the green light never comes on
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by J2014, Jun 8, 2014.
  1. J2014
    J2014 Junior Member
    37
    2014 Prius Plug-in
    Does anyone know what causes this? The car is less than two weeks old and this ishappening.
    48,985
    what is happening?
  3. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Are you referring to the "ready" light when starting out? Or the hill holding feature? Not sure what green light are you looking for, and under what conditions are you expecting it?
    48,985
    stop light?
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    (I am assuming READY, if not, ignore me)
    The 12 volt battery does a CPU check of all systems and if all is well, it closes relays to allow the big battery online, then the 12 volt battery is done for the trip and can be recharged.
    If the salespeople left your Prius PHV in Accessory mode, or off with doors open, or committed other stupidities with the 12 volt battery being drained while they yammered on in the showroom, then your 12 volt battery may be shot. Make them install a new one.
    Andyprius1 likes this.
  6. retired4999
    2,652
    625
    Eau Claire, Wi.
    Brake light switch?
    Press brake a little harder, or have dealer check.
  7. bisco
    48,985
    is that the 'go' lite?
  8. retired4999
    2,652
    625
    Eau Claire, Wi.
    Yep!!!!:D
  9. bisco
    48,985
    you won't go with yer foot on the break!
  10. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    Probably a faulty switch in the brake assembly. The switch is there to, normally, make sure you are pressing the brake pedal when trying to make the car Ready. If the switch is faulty, the ECU thinks you aren't pressing the brake pedal and won't allow the car to go into Ready mode.
    SCH-I535
  11. J2014
    J2014 Junior Member
    37
    2014 Prius Plug-in
    It's the green light on the power button. Sorry I wasn't clear earlier.
    When I press the break the green led does not light up.
  12. J2014
    J2014 Junior Member
    37
    2014 Prius Plug-in
    What is an ECU?
  13. xliderider
    7,848
    3,102
    Honolulu, HI
    ECU = electronic control unit, AKA a computer chip or module. There are many ECU modules in all modern cars to control and monitor the functions throughout the vehicle.
    SCH-I535
  14. bisco
    48,985
    does the car start? if not, you may need to press harder on the brake pedal.
  15. J2014
    J2014 Junior Member
    37
    2014 Prius Plug-in
    We have to reset it by doing the 15sechold on the power button...
    I hear there was a ecu recall recently. I purchase the car next than two weeks ago. Would they be selling the vehicle without the software update? I'll bring it into the shop on Wednesday.
  16. xliderider
    7,848
    3,102
    Honolulu, HI
    Negative, all vehicles on the dealer lot have to have the new software update prior to sale.
    SCH-I535
  17. J2014
    J2014 Junior Member
    37
    2014 Prius Plug-in
    Thanks xlide .. We will find out on Wednesday. I hope we can still drive it there.
  18. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    When you press on the brake there is a green light just above the word "POWER" in the power button that should go on. Is that what is not happening?
  19. J2014
    J2014 Junior Member
    37
    2014 Prius Plug-in
    The green light does not come on in the power button.
  20. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    Guys, what's this 15 second hold reset maneuver?
