Prius 2001 engine working but no panel (dashboard off) what is the problem?
Discussion in 'Generation 1 Prius Discussion' started by la_amor_fashion, Feb 4, 2014.
  1. la_amor_fashion
    la_amor_fashion New Member
    London, United Kingdom
    2001 Prius
    Today in the morning i run the engine on my Toyota
    Prius 2001, it works as normal then after 2 min the
    panel power is gone ( it just gave me a quick warning)
    then i switched off and on the engine, still works fine
    , i can drive forward and backward , but no power at the
    panel, power steering not working, no wipers , no lights, doors and windows are not working, computer screen off,the long panel for the speed, fuel ... all off, i have tested all the fuses near the passenger door they all works fine, then i disconnected the positive cable form the 12v battery for 1min , still no lights on the dashboard, what do i need to test next?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Moved from the Prius v forum to the gen 1 forum.
  3. ChapmanF
    15,060
    My suggestion would be to go to techinfo.toyota.com and download the wiring diagram manual. Maybe print the pages that show all the things you just listed as being without power. (Look toward the back of the book, there's a section with a condensed diagram showing everything on a bunch of contiguous pages, as opposed to the earlier sections that are broken out by the different systems.)
    On the printed pages, highlight the things you're seeing without power, and trace the wiring backwards to see what they have in common upstream. With a meter, start poking around from that point and up.
    -Chap
  4. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    Sounds like you have a bad main fuse blown somewhere. I would check the one back by the 12 volt battery and than go up under hood and check all of them. Sorry I don't know which one it will be..
  5. AlexY
    AlexY Member
    160
    45
    UK
    Check all fuses under the hood. When you will find faulty one need to find reason why it fail.
