1. Offline
    njfoodguy New Member
    Sep 9, 2009
    Your Vehicle Year:
    I have the traditional FM reciever Sirius installation for my 2009 Prius and it works terribly. I never had a problem before. Can the Sirius device be hooked into the auxiliary port if the car? Does that improve the signal?
  2. Offline
    acdii New Member
    Apr 5, 2007
    665
    25
    Only the Sat antenna can improve signal. If your unit uses the external RF antenna, then you might be able to find one that connects direct inline with the antenna cable of the radio. I had one of those rf units for an Ipod that never worked well in my 07 Prius, but worked OK in the Hyundai. The AUX port I think is for amplified outputs like an Ipod, the Sat units I believe are line level, so you would need an amplifier for it to work.
Share This Page
