Prius battery life and replacement cost?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by morris, Oct 31, 2005.
  1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Scenario: car is at the body shop long enough that the 12V runs down. They jump it in order to deliver the car to you. Battery is still >90% discharged by the time you get it home. Then you go to start it two days later and it is dead. I'll give you a 5% chance that trickle charging restores it.
    Here's the problem. After 5 years on the original 12V, you are on borrowed time, and one little incident like what you describe is all that it takes to cause a fatality. Especially on the non SKS cars, the 12V is extremely fragile. I just lost one out of a 2007 on its last legs by having the car in Ig-On for just 30 seconds. Now it has a dead cell.
    The body shop may have been the catalyst, but most likely it was on its last legs.
    2 people like this.
  2. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I am in agreement with seilerts. :)
  3. mailprs
    mailprs Junior Member
    Seilerts, F8L,
    thanks for your replies. I will confirm after my visit to the dealer shortly.
    -Prs.
  4. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    This may be a good time for you to purchase a multimeter so you can keep track of your battery without having to rely on the dealer. :)
    Keep us posted!
  5. mailprs
    good point. I will do that shortly. however, reading this thread, I did the vehicle signal check and got the following readings:
    IG OFF - 12.4V and with the headlight on, 12.1 V
    IG ON - 11.6 V and with the headlight on, 11.3V.
    somewhere I read that the nominal should be 13.9V with IG OFF. How do I know if the battery is good/ bad with this information?
    Also, the service check revealed some codes - are those the OBDII codes? or what the dealer will be finding out?
  6. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    13.9 v (or there about) is the reading you should get in "Ready" mode (when the battery is being slowly charged).
    Your 12v battery is weak as it should hold its voltage better under load.
    No, you need to use an OBDII reader that handles the CAN protocols to read codes on a Prius.
    JeffD
  7. ralexj
    ralexj New Member
    Alpharetta
    My 2006 just lasted 6yrs and I am in the process of replacing the battery now with a quote of $4000 at the dealer I am going to a refrub battery for 1250, installed cost averager $400 to 700 from the dealers.
  8. ralexj
    ralexj New Member
    Alpharetta
    What I really would like to know is the average time it takes to replace the battery?
  9. uart
    uart Senior Member
    4,215
    1,200
    Australia
    How many miles have you put on it ralexj?
  10. jdenenberg
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    3 to 4 hours for a refubished battery, but add one hour to swap the ECU if you get a new battery from Toyota.
    JeffD
  11. davisnc
    davisnc Junior Member
    I just replaced the original 12V battery in my 2008 Prius, 106k miles. It had a date of April 2007 on it meaning it is 6 years old. Dealer had done a free test and indicated it tested "weak." Checking the voltage on the MFD confirmed this, and I noticed the ICE running more often around town, which is a symptom of a weak 12V battery. Went with the Optima from Advance Auto, found a $50 coupon code! It was pretty simple and took me 30 minutes. Be sure to have a 10mm socket and wrench handy.
  12. Cynda
    Cynda Junior Member
    We are being told by dealer both batteries on our 2006 Prius have failed and need replaced. 137k miles, and $4300.00. Reading these replies, we're confused as to whether replacing the 12 volt only, may give us a little time before having to replace the hybrid supply battery? Also, does the forum lean toward refurbishing rather than replacing the hybrid supply battery?
  13. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    What state do you live in? Some states have Hybrid battery coverage to 10 years or 150,000 miles . I would certainly replace the 12 volt first, then see. If you have to replace the Hybrid battery call Reinvolt - I believe their rebuilts are $1200....
  14. Cynda
    Cynda Junior Member
    We are in Texas, and we'll look into Reinvolt too, thanks!
  15. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  16. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Definitely replace the 12V battery first Cynda, then see what it drives like. The things you're looking for are driveablilty problems like low power and high engine revs, coupled with rapid swings in the state of charge (red-blue-green bars on the multifunction display).
    cwerdna likes this.
  17. Cynda
    Cynda Junior Member
    it's doing all of that, exactly that. Bars changing status constantly, the engine sounding like it was rev'd/pedal to the floor, and the fan running full time.
