Prius C Alignment issue
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by chrispdx, Jul 26, 2012.
  1. chrispdx
    chrispdx Junior Member
    Portland, OR
    So I purchased a Prius C 3 about a month ago, and ever since day one, I've had a nagging suspicion that the car was pulling to the left a tad. Finally it bugged me so much that I took it into the dealer, and lo and behold, there was a problem. The two front wheels were "pigeon toed" inward (defect from the factory), which they fixed.
    Now, the car is pulling to the right (when I have the steering wheel set dead-center), however if I let go of the wheel on a flat surface, say, a parking lot, the steering wheel settles at about a 3 degree turn clockwise and goes straight ahead. When I try to move the steering wheel back to "base" position, then it starts turning slightly right. I took it back to the dealer today and they told me nothing more was wrong. In fact, the service guy took me for a drive in my car with him at the wheel and driving down the road, the car was going straight with the wheel more or less level.
    Am I on crack? Is this normal? Do I forget about "base" on the steering wheel (which I define as "the Toyota Logo is perfectly level and the two yokes with the on-wheel controls are perpendicular"), and just let the car settle straight as it thinks it should? Is the fact that I'm an overweight guy (260lbs) factor into the equation?
    Part of me wants to take the car to another dealer for a second opinion. Part of me just wants to forget about it and enjoy my car. What should I do?
  2. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    632
    215
    Alignment refers to the process of hooking the wheels of a car to a machine which measures their position and making adjustments, if necessary, to bring them into the correct position, if possible. At some point in the process the steering wheel is supposed to be held in the straight position while checking if the wheels are pointed straight. If the wheels are adjusted straight while the steering wheel turned a little bit you will have the symptoms you describe. Also, normally, cars are set to pull to the left on a fat surface so that they will drive straight on the arched roads we drive on. I would see it they are willing to re-align it to remedy your concern, and it not, have someone else do it. Also, ask for the print out of the measurements. It is possible that the alignment equipment manufacturer has not provided an update for Prius c yet, this would make it harder to complete the alignment.
  3. Brendanlives
    Brendanlives New Member
    Binghamton, New York
    I have one. The rear alignment has no way to be adjusted. Mine they say is bent. Caused by running over a pothole. I've been driving a long time. Never had an unfixable alignment due to hitting a pothole. I have no recollection of hitting anything. Car is brand new. I think these things have weak or already screwed up alignments.
  4. TrafficMPG
    TrafficMPG Junior Member
    If the car "feels" good, then it is good. Don't focus on the steering wheel too much.
    It went straight with the mechanic in it. Enjoy the car.
  5. X HCH2
    X HCH2 Member
    108
    32
    Upstate SC
    All cars have a simple tie rod adjustment to center the steering wheel. Just find someone who knows what they are doing.
    X
  6. xs650
    xs650 Senior Member
    4,524
    1,391
    Northern California
    Most cars with el-cheapo twist beam rear suspension such as the Prius has can have their rear alignment corrected with shims. I haven't looked up a listing for the C, but the exist for the Gen II and III, probably do for the C.
    There is no alignment done at the factory, the parts are bolted together and of they are all in spec, the alignment is supposed to be good. There is some doubt about the reliability of that on other Prii, I doubt the C is any better.
  7. xs650
    xs650 Senior Member
    4,524
    1,391
    Northern California
    A competent alignment shop could align your front end to compensate for your weight. But then it would pull with a light weight driver.
  8. alexjeppson
    alexjeppson New Member
    I've been having the EXACT same issue. I test drove a Pruis C 2013 and decided I wanted a different color. They went to the warehouse and found the color I wanted, brought it back and I never test drove that specific car. Obviously I am kicking myself now for not first test driving the car they brought because the second I drove the car off the lot it was pulling hard left. I brought it back immediately and the service rep told me they have been having issues with the alignment pulling a little left out of the factory. Due to how busy the dealership was that day (Toyota Santa Monica) I was scheduled to come back the next weekend to resolve the issue. I came back, they took my vehicle into the shop, and when I got the car back it was still just as bad. I called them back the next day after driving it a little just to make sure it wasn't just me. I brought it back the next weekend and they tried again. When I got my car back 2 hours later, IT WAS JUST AS BAD!! I brought it straight back AGAIN and the manager went on a drive with me and I showed him how if the steering wheel was lined up straight the car drifted right, and if I tried to set the car on a straight path, the wheel would settle a few degrees to the left and eventually pull left after about 20 to 50 feet. They tried to fix it again that same day and guess what happened.. STILL JUST AS BAD!! I immediately called the service rep again and was then told that actual alignment program for my model was not in their machine yet due to how "new" my car is. I gave them the benefit of the doubt and brought it back in AGAIN the next weekend. They tried to fix it again (now with the supposed correct alignment program) and when I got it back.. STILL BAD!! At this point I was very frustrated and called service to insist this car is a lemon and they need to give me a new one. They asked for one more chance to fix it so I gave it to them. I brought my car back in 3 days later and they said I needed a new rear bar assembly and changed it. When I got the car back (three days later), it seemed to be better on city streets... but as soon as I got on the freeway, the vehicle started washing 2 to 3 feet back in forth at speeds over 60 mph and the wheel still settled a few degrees off to the left and would eventually pull left on a flat surface. I came back and took a service manager on a drive with me and he threw ever excuse in the book at me as to why it was going off a little.
    Excuse 1: There is a crown in the road.
    Excuse 2: With only one person in the car, the weight is not evenly distributed (I only weigh 160 lbs).
    Excuse 3: It doesn't seem to be happening all the time.
    Unfortunately for me, the 10 freeway near Santa Monica almost always has traffic so I couldn't get the car up to a high enough speed to show how obvious the problem still was. I told him it might be okay but I would need to drive it on the freeways at a higher speed some more to be sure. After a day, it was obvious to me that the alignment was still just as bad. I called the service rep again and am now being told that they can only make appointments for lemon law inspections during the work week. So now I have to miss a day of work just to prove something which is obviously an issue with more then just MY Pruis C. They better give me a working car or I'm going the the BBB with this. Technically they only get 3 chances to fix the problem and I gave them 4 (2 of which were on the same day). Enough is enough. I'm not wasting any more of my Saturdays trying to get the NEW CAR I PAID FOR!!!
  9. nubomb
    nubomb Junior Member
    16
    somewhere
    Don't think your on crack and I don't consider myself overweight at 200 :) My car does the same thing. Drives straight but steering wheel is tilted towards the right. I can see it by looking at the top of the steering column (if that's what it's called).
  10. ztanos
    ztanos All-around Geek!
    2,544
    773
    40
    Duluth, Georgia
    You can take it in and have them re-position the steering wheel. Sounds like it was installed off kilter.
  11. HarSherm
    HarSherm Junior Member
    28
    Burlington, Vermont
    Repositioning the steering wheel will not fix the problem. The steering wheel can be put on upside down and the problem will still occur.
    Don't blame you for being angry. I test-drove a nearly new 2012 (13,000M) car, same issue, pulls to the left. The seller actually took it to Toyota, and it came back exactly the same. Repositioning the wheel of course did not help; you can install a steering wheel upside down and it will not effect how a car pulls, since there is no magical link. An alignment did not help, probably because, as another reply mentioned, they come from the factory that way, and there is no way to align the rear except by shimming it. It is a shame, because the car I tested was very good in all other ways...but I cannot see getting into payments for a car that is not right (no pun intended) I would never be happy with. And what if I wanted to sell it later? The first person to test-drive it would immediately comment on it.
  12. ztanos
    2,544
    773
    40
    Duluth, Georgia
    How do you figure? He says when he lets the steering wheel settle to "it's" center, the car drives straight, it's just that the wheel is 3 degrees off center.
  13. smackdownC
    smackdownC Junior Member
    56
    16
    2014 Prius c
    Mine was brand new and off from the factory. Thought it was road crown, but when I got on familiar roads, not so. Brought it back to the dealer, they checked it, and it was off.
    As for having to service the car 3/multiple times, don't be afraid to get in touch with a lemon lawyer. Even if the car is fixed. You'll get something for your troubles and "negative service history" which I've done on GM & VW and won.
