Prius C Custom PIDs
Discussion in 'OBDII Android App' started by ghwong, Apr 5, 2012.
  1. mcharest
    mcharest New Member
    Here is the output of a full scan. It's not complete because if I let run the scan for to long it ends up crashing, so I stopped it after about 2 minutes. Hope that is enough information for you.
    • scan.txt
      File size:
      19.9 KB
      533
    seckwielen likes this.
  2. mcharest
    mcharest New Member
    Just in case it might be useful here is the output of a normal scan (not full). For this one the application doesn't crash.
  3. vincent1449p
    vincent1449p Active Member
    879
    314
    Singapore
    Thanks mcharest! :)
    TorqueScan only scan for ECM (7E0) and the rest of the ECUs were not scanned. I suggest unzip my Test2.zip to your MicroSD card and load it into Torque. Then go to the "Select a PID to log" screen to get the "Latest raw value" by screen capture method or manually write them down.
    Vincent
  4. armseven
    armseven New Member
    can any PIDS use for prius c now?
    I cannt find any one useful..........
    thanks guys
  5. vincent1449p
    879
    314
    Singapore
    Here is the link to Google Drive. Many of the PIDs are not tested cos' I got no more updates from ghwong. However, I 've tested most of them in ScanGaugeII so it should work in Torque.
    Vincent
    minkus likes this.
  6. thefalcon
    thefalcon New Member
    I know this thread has been dead for a few months, but it seems to be the only place referencing Prius C PIDs for Torque.
    I imported your list, and it works great! Thank you for your effort.
    Before I ask too many questions, I should ask if you know what all/most of these values represent/where they come from, or did you find them in some reference manual?
    For example, there yaw rate sensor and yaw rate sensor2. Are they different sensors, or duplicate readings? What kind of sensor: gyro, accelerometer, etc?
    BTW, I'd be happy to test anything if needed, just let me know.
    minkus likes this.
  7. minkus
    minkus Active Member
    361
    120
    Cleveland, OH
    Hey Vincent!
    I just got Torque Pro and imported your custom PID list. I'm still playing around with it and getting used to the interface, but I'd be happy to pick up wherever ghwong left off (as would thefalcon, it appears). I have the US version of the c two, btw. Just let me know what you need me to do!
  8. Hodr
    Hodr Junior Member
    23
    Just ordered my ODBII reader and look forward to using the Torque tool. Has there been any further work on the PIDs for the Prius C? Looks like Vincent hasn't checked in for quite a while.
  9. Flying White Dutchman
    4,374
    300
    2012 Chevy Volt
    so any updates?
    is there a list specific for the prius c ( and yaris hsd ) with pid's for the app?
  10. Flying White Dutchman
    4,374
    300
    2012 Chevy Volt
    i have found them i think
  11. johnhlong
    johnhlong Junior Member
    89
    28
    East Carbon, Utah, USA
    I have the Torque app for my 2013 Prius C.
    I downloaded your csv file to my Win8 PC.
    Now what do I do ?
    Should I update to the pro version of Torque?
    John
    SLC, Utah, USA
  12. zmyr88
    zmyr88 Junior Member
    16
    Newark, delaware
    2014 Prius c
    which pid is for the regen in terms of voltage or amps produced by the regen system. wanted to know when i was at max regen but before friction brakes enable?
    curious which pid wou
  13. minkus
    361
    120
    Cleveland, OH
    How to add extended PIDs - TorqueBHP Wiki
  14. kingnba6
    kingnba6 Active Member
    982
    223
    NY
    good and useful info in this thread.
  15. zmyr88
    16
    Newark, delaware
    2014 Prius c
    i used the google docs for my torque app. but the SOC and regen don't seem right. soc is off a LOT. and the regen is not there. or at least i can't find it by name.
  16. vinnie97
    vinnie97 Whatever Works
    1,310
    227
    Somewhere out there
    Guess this is still a WIP. I'd like to see traction batt temp and associated fan RPM.
  17. fermuscolo
    fermuscolo Junior Member
    I just installed torque and the PIDs posted here, Im gonna test some later, What its is confirmed working? Is there a way to reset the maintenance screen?
    Thanks
