Prius C Ground Clearance?
Discussion in 'Prius c Main Forum' started by ThomPrius, Dec 16, 2011.
  1. ThomPrius
    ThomPrius Pondering Prius
    Kirkland WA
    My wife and I don't own a Prius yet, but we are seriously considering replacing one of our cars with a high mileage car and Prius seems to top that list. The Prius C seems especially appealing...so far.
    I couldn't find anything in a search on the Prius C ground clearance, and Toyota doesn't seem to have that data out yet.
    After much searching around I found "lower than a regular Prius" and reference or two to 60mm LOWER than a Toyota Yaris. THAT would put the ground clearance of a Prius C at only 79.7mm (3.14inches).
    IF thats true, and I am hoping someone got the math wrong, it would be a deal breaker for ME. Anyone confirm or deny?
    3 inch ground clearance would make the thread on "AWD" sort of a moot point, if the car high-centers on a heavy frost, much less snow. And that clearance would not get it past the speed bumps in my neighborhood or up the rounded curb they call a driveway entrance at my house. It certainly kills it for even an lightly gravelled road. :(
    I was hoping the high mileage car we end up with could be used for getting to distant hikes on smooth roads and maybe some smoother gravel roads. Probably have to look at a "regular" Prius. I am not sure the Prius C could handle the distance anyway, as its touted as a "city car".
  2. ken1784
    ken1784 SuperMID designer
    2,938
    1,307
    67
    Yokohama, JAPAN
    The overall height is 60mm lower than Yaris, but the ground clearance is the same, 140mm.
    [email protected]
  3. xerox6135
    xerox6135 Junior Member
    89
    michigan
    Mine drags the front bumper pulling out of the drive way BIG DISAPOINTMENT Had i knew this I would have not bought this car:confused:
  4. R11
    R11 New Member
    101
    16
    Portland, OR
  5. Ashley7
    Ashley7 Active Member
    534
    194
    Oregon
    Hm... I've been in and out of a local grocery store with a super steep driveway, and haven't scraped. No problems with our apartment's speed bumps either. Sorry to hear you're having issues :confused:
  6. ProximalSuns
    ProximalSuns Senior Member
    1,882
    16
    27
    PNW
    Per the dimensions on the Toyota web site, the Prius C is 5.5" vs. the Prius 5.3".
    More ground clearance on the C than on the Prius.
  7. fgp
    fgp Active Member
    462
    114
    nashville
    for me, it just feels lower. i have not had a problem, but it feels like its going to scrape. i definetly wont be looking for any lowering springs!
  8. ProximalSuns
    1,882
    16
    27
    PNW
    It did to me also but C definitely has more ground clearance. I measured two side by side as I was looking at a C initially.
    I think the seat is lower so that when you get out it feels lower.
  9. fgp
    fgp Active Member
    462
    114
    nashville
    very cool. thanks. sometimes just feeling like it is happening even if it is not. kind of like psycho stuff:)
  10. donny612
    donny612 "Captain Jack Sparrow"
    117
    Apex, NC
    I've not had any problems with speed bumps or driveways as of yet.
  11. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    182
    TN, USA
    What are your tires inflated to?
    If the pressure is low it lowers the ride height. It's not much but it could be the difference between scraping or not.
    Try adding 5 psi to all the tires and see if it makes any difference.
    Oh and make sure you don't have a bunch of stuff permanently stashed in the car that would compress the suspension. A few bricks of gold in the back would be a bigger factor than the tire pressure. :D
