Prius C owners - I need some help please..
Discussion in 'Prius c Accessories and Modifications' started by Scrittibear, Aug 4, 2013.
  1. Scrittibear
    Scrittibear Junior Member
    67
    I
    I own a Prius C one and I am installing a center Storage compartment/ Arm rest between the front seats (The C one doesn't include a center storage compartment).
    I need to know if the black plastic base of the Storage Compartment/ Arm rest unit is secured firmly to the floor of the Prius C, or is there a loose wiggle around the base (in fact can you slip your fingers up under the black plastic base "skirt?") -- or is it really tight and solid?
    Mine is loose and not firmly attached to the floor by the rear passenger's feet -- (To further clarify, there's a cup holder that unfolds out from the back of the central storage compartment and it's down around the base of the unit near the floor).
    I would really appreciate your help - I think I am missing some parts.
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Mine is nice and snug. I have the cup holder out the back.
  3. Prius Sea
    Prius Sea Junior Member
    Imperial Valley, CA
    I second ztanos. I can't budge the storage compartment. I can get a screwdriver under the skirt, but not even my very small fingers. The bottom of the skirt in the rear can be pushed less than a centimeter inward as it seems only to be attached to the base of the storage compartment.
  4. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
  5. Whirldy
    Whirldy Junior Member
    89
    Hopefully I will be able to install one soon :)
  6. Delta Flyer II
    547
    248
    69
    @ Whirldy you'll love it when you do...
  7. Whirldy
    89
    Did you install an OEM part, specific for C1 arm rest, or the one for the Yaris?
    :D
  8. Delta Flyer II
    547
    248
    69
    Yaris one....
