Prius C Valet Key
Discussion in 'Prius c Main Forum' started by vdefender, Feb 19, 2013.
  1. vdefender
    vdefender Junior Member
    32
    Renton, Washington
    What is the Valet key for?? Traditionally, the valet key is for the ignition only, and doesn't allow access to the locked glove box, or the trunk. But the prius c is a hatch back and the glove box doesn't lock. Is there anything on the car that doesn't function when using the valet key?
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
  3. prioki
    prioki Member
    116
    CA
    I'm confused. Both of the keys I got are exactly the same and fully functional. My husband carries the second one on his keychain. I do take it off when I valet so I don't have to give them my house keys.
    ztanos likes this.
  4. vdefender
    32
    Renton, Washington
    I have three keys. Two black with built in lock/unlock buttons. And a third which is grey and has no lock/unlock buttons
    RocMills likes this.
  5. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    That's weird. I received exactly what Prioki received. Which was exactly what the thread I linked to was saying all its members received. Hmm... But then both Prioki and I have a c4.
  6. vdefender
    32
    Renton, Washington
    I have a C 2. The manual for the C2 shows three keys, two with fobs, and one valet. It labels it as a valet but doesn't say what the difference is!
  7. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    I can't imagine there's a difference. Does the unlock button on the fob unlock all the doors? Maybe it will slow them down a little. o_O
  8. vdefender
    32
    Renton, Washington
    Well the two master keys, with built in fob, operate the same, and have the same shape. The grey 'valet' key I got has no buttons, and the tip of the key is shaped just a bit different. Which is normal because that would prevent it from opening the trunk for instance. But I don't have a trunk! Lol
    I guess when I get home from work I'll take the valet key and see if it works for driving and opening the door. Lol
  9. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    It would have to work for both... otherwise it's just a hunk of metal.
  10. vdefender
    32
    Renton, Washington
    Right. My main thought was, maybe it's not a key for my car and the dealer got it mixed up. But if it does work that's great because I'm going to put an aftermarket alarm on and use my valet key because its smaller and doesn't have the factory lock/unlock which would be useless with an aftermarket alarm
    ztanos likes this.
  11. PFlat
    PFlat Junior Member
    36
    26
    We bought 2 c2's 3 weeks ago. Each came with ONE fob-key and one valet key. Weird.
  12. vdefender
    32
    Renton, Washington
    There definitely something wrong here. How are we all getting different keys? Check your manuals and see what it says for keys. My manual says 2 fobs and one valet.
  13. 2015Prius2
    2015Prius2 Member
    150
    67
    Our C1 came with two key/transmitters and one valet.
    vdefender likes this.
  14. vernon birdman
    vernon birdman Active Member
    330
    141
    Vernon BC Canada
    I have the Canadian equivalent of the US C 4. I only received 2 fobs and no valet key
  15. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    Woah, a bit of confusion in this thread.
    If you have a One or Two (ie. no SKS), you are supposed to receive a total of three keys - two "Master" keys with the built-in remote fob and one "Valet" key without the remote. There's a slight difference in appearance for the Valet keys between the One and the Two, because the latter has an immobiliser.
    If you have a Three or Four (ie. you have SKS), you just get the two fobs.
    In the US manual this information is on Page 44.
    I've got no idea why Toyota gives a Valet key when it's a hatch with no lock on the glove box.
  16. Phil 29 Palms CA
    119
    44
    Twentynine Palms, CA.
    My Prius C 2 came with two fob keys and one valet key. all keys will manually open all locks on the Pruis C. the only difference between the keys is that the 2 fob keys have a battery controlled transmitter which allows the user to open the door locks remotely from a distance. two clicks within 2 seconds on the fob keys will open and close all door locks on the car, One click on the buttons only unlocks or locks the driver side door. One interesting thing to know. I removed the transmitting electronic device fron the fob key (including the electronic circuit board AND battery for a test. Note: The key with the electronics removed still worked perfectly in the Priuns C 2 ignition switch. That is to say, "I got a READY light. Bottom line... If the battery becomes dead with time or use the fob keys will still start and operate the Prius C 2, The only function of the battery in the fob keys is to remotely open and close the doors!
    Klaatu likes this.
  17. RocMills
    RocMills Active Member
    789
    276
    Las Vegas, Nevada
    My C2 and my mother-in-law's C2 both came with two regular keys and one valet key as many others have described.
  18. norahs
    norahs Junior Member
    52
    Bay Area, CA
    I have a C3 and received 2 smart keys/fobs. Each one has a little button that says "push" on it and the bottom key portion pulls out. The dealer told me that this pull out portion is for valet. I've never quite figured out how that would work... I would just hand them the key portion and take the fob with the lock/unlock buttons? What difference would it make
  19. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    Oops... your dealer was completely wrong. The pull-out mechanical key on the SKS fob is ONLY a back-up if the SKS is not functioning and all it will do is open the driver's door. It has no other function. To start the car in this situation, you need to press the brake pedal and hold the fob's Toyota logo to the Start button until the car detects it through induction (and displays the usual symbol on the MFD), then push Start.
    There is no Valet key with SKS and if you don't give them the whole fob, they won't be able to start the car.
    vernon birdman likes this.
  20. norahs
    52
    Bay Area, CA
    thanks! psh.. dealers. hehe
