Prius dies no power
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jpepsi, Nov 30, 2015.
  1. Jpepsi
    Jpepsi New Member
    Eastbay to sf
    Driving on the freeway over 50 miles per hour the car dies goes really slow goes down to 30 miles per hour almost no power
  2. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    You have to get the DTC codes read. I'm assuming all kinds of warning/error lights came on the dashboard?
    Have you checked for leaks, especially from the inverter coolant loop? If nothing leaking, check for flow/turbulence of the inverter coolant fluid. Could be a failed inverter coolant pump and the resulting overheating and shutdown of the inverter.
  3. Jpepsi
    Jpepsi New Member
    Eastbay to sf
    I get a red rectangle the check engine light
  4. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    how many miles on her?
  5. Jpepsi
    Jpepsi New Member
    Eastbay to sf
  6. wjtracy
    11,314
    3,588
    Northern VA (NoVA)
    ....Assuming that's 89,838 you should be under CARB warranty, assuming car is orig from Ca.
    Sounds like HV batt but you need to get codes
  7. Jpepsi
    Jpepsi New Member
    Eastbay to sf
    ?? What is Carb warranty
    My car was bought at a used car lot
    #7 Jpepsi, Nov 30, 2015
  8. wjtracy
    11,314
    3,588
    Northern VA (NoVA)
    Assuming you live in CA and your car always lived there, you get extended warranty 10-yrs and 150k miles on most of the expensive hybrid components. Otherwise it's 8-yr 100k miles...you could be covered in either case, but some 2007's are over 8-yrs old already. You'd be close.
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    Don't you have a thread (Help 2007 Prius ) you posted earlier where you reveal the same symptoms AND a whole lot of codes you evidently did retrieve?
    You should choose ONE thread with full disclosure, to limited confusion and get the most direct help.
    #9 The Electric Me, Nov 30, 2015
    SFO, uart and xliderider like this.
  10. Jpepsi
    Jpepsi New Member
    Eastbay to sf
    I bought the car in Oregon in coming back to California from used car dealer you think is so covered
    #10 Jpepsi, Nov 30, 2015
  11. fuzzy1
    10,045
    Fuel starvation is one way do this. Running the tank empty is the most common way to get there, but some fuel system mechanical failures can do it too.
  12. wjtracy
    11,314
    3,588
    Northern VA (NoVA)
    I am confused, but Oregon is also a "CARB state" so this car may be under warranty...
  13. bisco
    48,988
    when did it become carb?
  14. Jpepsi
    Jpepsi New Member
    Eastbay to sf
    OK I have to take a look into it
  15. bisco
    48,988
    even non carb might barely make it, 8/100.
  16. The Electric Me
    9,083
    5,796
    My understanding is Oregon is a Carb State.
    I hope so, because that's the clock I have ticking against my Prius.
  17. bisco
    48,988
    yours is covered, but if they became carb after '07, pepsi might not be.
    The Electric Me likes this.
  18. wjtracy
    11,314
    3,588
    Northern VA (NoVA)
    Correct we show 2009 for Oregon, so sounds like somebody intentionally sold this car around 8-yr mark. With luck slightly before 8-yrs., but I'd be worried. In any case, OP should take a shot in CA for warranty coverage. I was just reading the 2015 warranty today, and it is not very clear about the rules.
    2007 warranty even less clear, I feel Toyota may help in the cases where the warranty was not worded clearly. If that fails, OP can ask Toyota for goodwill coverage,as a last resort, if needed.
    Ugh we are getting several used buyers grabbing problematic Prii that the owner ditched just as the warranty was up.
    #18 wjtracy, Nov 30, 2015
  19. uart
    uart Senior Member
    4,215
    1,200
    Australia
    I think that in the majority of these cases the HV battery probably either started showing signs of failure or outright failed (and had codes reset and perhaps one or two cells replaced) before the car was sold. In other words, I think there's a strong reason why the majority of these Priuses are being sold off.
    There might be some cases where people sell a perfectly healthy running Prius purely because the warranty is up, and then just by coincidence the HV battery fails one month later. To be honest though, I think these would be only a small minority of the cases.
    Exactly!
    Just so we have all the relevant info in the one thread, here is the relevant info from the other one.
    #19 uart, Dec 3, 2015
    wjtracy likes this.
