Prius Driver Needs Tips to Maximize Hybrid Battery Life
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dhillonflygirl, Oct 8, 2014.
  1. Dhillonflygirl
    Dhillonflygirl Junior Member
    Cleve, Tx
    If you have tips you can share, please post.
    I'm just a driver.
    I do not store or park my car without driving, it is driven everyday.
    So please keep comments simple for me. LOL
    I think I'm doing ok since my battery did not fail until 205,000 on my 2010 Prius and the hybrid battery is still going strong on my 2008 Prius at 184,000. But I'd love to do better!
    If I can change something or change my driving I will, I would have loved to have gotten up closer to 300000 with my 2010 Prius, I've seen dream stories of people that have made it. And hey that is what I want! If you know any secrets to getting there, help me out.
    So I have a few questions, and share on how I drive....
    Do you let your Prius Warm up? I usually just jump in and go. And I am generally in a rush, so gas pedal down.
    Do you use the ECO mode in traffic or highway or both?
    I usually keep the car in ECO mode. I rarely have used the EV mode.
    Do you do any maintenance to your hybrid battery?
    I have not done any maintenance on mine, until what looks like now I'm facing replacement.
    Sometimes I'm just sitting for an hour, running ac, and cellphone chargers.
    I do not know if any of my actions have ill affects on the hybrid batteries....
  2. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    On the 2008 a little warm-up may help...you wait a minute and the engine comes on and then it goes off. Then you go.
    Don't run the HV battery empty (if you run out of gasoline)
    Be sure keep A/C on in heat as it helps cool off the battery due to blower fan in the backseat.
    Make sure batt blower fan is clean (Gen2 it gets lint especially if dogs are in there a lot)
    Dont park in the heat with all the display bars in the Green...rather get down a few bars into the blue (the batt can heat up when parked) this is usually not an issue but some folks have a huge downhill that gets the battery fully charged and then they park it like that.
    Dhillonflygirl likes this.
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Don't we all.
    It is mostly a crap shoot and about all you can do is keep up with the routine maintenance recommended and try to keep the car (battery) out of extreme heat as much as possible. Then trust the car's programming to treat the battery good.
    Don't worry; be happy !!!
  4. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    I bought a Scangauge II and programmed it to monitor Battery temperature (BT2) and the state of the Battery Fan Motor (BFM) from 0 (off) to 6 (maximum). When the battery temp is ramping up past 40 degrees Celsius and the battery fan is going to level 3 or above, I start taking any possible actions to cool the battery raning from reducing speed, increasing air conditioning, or increasing air flow in cabin in cool weather. Also be careful not to block the cooling air intake for the HV battery or parking it when battery temperature is high as the cooling fan cuts off immediately and the battery temp can increase dramatically. Good luck!
  5. bisco
    48,987
    batteries die. sorry, but there you have it.
  6. arthur92710
    arthur92710 Junior Member
    25
    NY
    Not sure how it works in the prius, but when most battery packs "die" usually it's because only one of the cells actually dies. It is then possible to disassemble the pack and replace the individual bad cell.
    For increased reliability I assume that the Toyota engineers have some way for the pack to disconnect individual bad cells. But there is a limit to how far that will help and the pack "dies".
  7. Robert Holt
    1,313
    888
    Er, no, the cells are connected in series so one bad cell will in fact kill the pack. You can disassemble the pack and replace individual cell assemblies, but to do that well is quite involved. The battery ECU is sensing voltage differences among cell assemblies and will post warnings and finally quit if those differences become too large. Priuschat has threads on that HV battery disassembly process, but the voltages and amperage involved are quite dangerous, so the process is not for the faint hearted.
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Top ten ways to get long HV battery life, by priority
    1, 2, 3, 4, 5) Use the A/C. If you are warm, the HV Battery is warm. The whole reason it is in the passenger compartment is to get A/C.
    6, 7, 8)Drive like a normal car, do not do tricks to stay in EV.
    9) The EV mode button is not your friend.
    10) Drive your car at least every 3 months.
  9. Former Member 68813
    3,524
    981
    US
    Since you're from Texas, don't park in sun. Don't discharge the HV battery if you can help it (ie. high acceleration on cold engine, excessive EV driving, excessive "idling", etc).
