1. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    If you want to find out about the HUD, check out the new 2010 RX at Lexus.ca or lexus.com
    It shows the speed, radio and nav instructions (radio and nav share the same real estate and are invisible if nothing is applicable).
    The HUD is height adjustable.
  2. Offline
    Boo Boola Boola Member
    Feb 13, 2007
    Message Count:
    5,086
    602
    Flushing, NY
    Your Vehicle Year:
    What's a HUD?
  3. Offline
    EJFB1029 New Member
    Jan 16, 2008
    Message Count:
    4,726
    204
    Corpus Christi, Republic of Texas
    Your Vehicle Year:
    Heads Up Display, projects info on your windshield, actually very similar to what we have for our digital display, which reflects onto screen on dash.
  4. Offline
    Jul 12, 2007
    Message Count:
    10,558
    430
    Adelaide South Australia
    Your Vehicle Year:
    Will Prius have a heads up display?
  5. Offline
    spwolf New Member
    Sep 16, 2005
    Message Count:
    2,230
    156
    Eastern Europe
    european one will... and i guess japanese one too.... thanks for the tip.
  6. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    In the U.S. we have our heads up something else.
    Tom
  7. Offline
    Mjolinor New Member
    Oct 20, 2008
    Message Count:
    229
    Greece
    Your Vehicle Year:
    2002 Prius
    That should carry a warning, I nearly choked.
  8. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Tom?
  9. Offline
    pjm877 New Member
    Dec 2, 2003
    Message Count:
    255
    austin, tx
    Your Vehicle Year:
    I would just love the hud... well really die for for one... This would be SOOO very Cool.. darn lawyers getting in the way of us getting the really neat stuff over here across the pond...
    now I am sad knowing that other countries will have the option of HUD on a Prius...
    OH well I have seen a HUD display .. it was on a Old Oldsmobile Toronado Troféo
  10. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    At least we get IPA now. I hope it's more useful (after going through a few iterations since 2004).
  11. Offline
    RobH New Member
    Sep 18, 2006
    Message Count:
    1,417
    230
    Sunnyvale, California
    Your Vehicle Year:
  12. Offline
    ManualOnly New Member
    Aug 16, 2006
    Message Count:
    193
    28
    Is the Lexus/Toyota HUD projected images focused at infinity ? (meaning as if you are reading the figures virtually at a distance)
    Helps reduce eyes fatigue.
  13. Offline
    ronhowell New Member
    Oct 4, 2007
    Message Count:
    677
    30
    Cypress, CA.
    Your Vehicle Year:
    It should be, otherwise it is not a true HUD, which incidentally has been a standard option in the aerospace industry for at least 30 years. But in aerospace cost tends to be secondary to safety, since the speeds are somewhat higher.
    I happen to think that the current depiction of key travel data on my current 2008 Prius is a great improvement on the old thru-the-steering-wheel displays we used to have. It may not be a true HUD, but the eye movement required is probably less than 5 degrees, with a minimum of re-focus.
    OK with me.
  14. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Note that the Prius one also shows the Hybrid System Indicator on the HUD!
  15. Offline
    antiflash New Member
    Aug 9, 2009
    Message Count:
    93
    42
    Port Hueneme, CA
    Your Vehicle Year:
    i looked at a newish corvette several years ago here in cali and it had the HUD. I really wish there were more information out there as to why we do or don't get specific features like this. If nothing else, it would make sense for toyota to offer them as dealer installed accessories or DIY kits, as they already paid for the engineering to make it...
    Anyone heard of attempting a retrofit of the 2010 euro HUD into an american model?
  16. Offline
    AussieDave New Member
    Sep 10, 2009
    Message Count:
    Melbourne Australia
    Your Vehicle Year:
    The HUD is available on the Oz Prius. So far only got to use it on a long test drive.
    Controls are
    Shows
    speed
    horizontal bar display for economy but can have the other column graph displays on the main display
    shows turn arrow and distance to turn from sat nav but not continuously but at approx 800 metres and 300 metres and then just at turn. I assume these distance will change as speed increases as even an 800 metre warning at highway speed is leaving things a bit late.
    There are buttons to
    turn on and cycle through the speed/eco display
    move the display up and down to suit drivers height
    set the brightness (did not get a chance to see if the brightness also varied with the brightness of the other instruments)
    If you get sat nav another button controls its display.
    The satnav info, when displayed, cuts out the speed and eco display.
    Still got a month to wait for mine and then I will be able to explore it fully.
    David
  17. Offline
    Jul 12, 2007
    Message Count:
    10,558
    430
    Your Vehicle Year:
    I loved the HUD when I test drove the Gen III Prius in Sydney. :D
  18. Offline
    Fujisan New Member
    Jul 11, 2009
    Message Count:
    102
    Warrington UK
    Your Vehicle Year:
    Love the HUD :cheer2:
    No more taking your eyes off the road to look at the instruments or the sat nav directions...a great safety feature. :thumb:
    Never quite understood why if you want to reduce costs you build cars to different specifications for different markets (within the limits of local safety and enviromental legislation). :huh:
  19. Offline
    Rainingblood New Member
    Jun 28, 2009
    Message Count:
    35
    Italy
    Your Vehicle Year:
    in italy HUD is standard in all the prius 2010,
    il like it but the H.S.I. bar is too little!
  20. Offline
    tjp74 New Member
    Jul 29, 2009
    Message Count:
    92
    31
    Bothell, WA
    Your Vehicle Year:
    So who is going to look into to see if it can be retrofitted into US models??? :hail:
Share This Page
