Prius Newbie Question
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Cassie Matos, Sep 2, 2015.
  1. Cassie Matos
    Cassie Matos Junior Member
    San Jose, CA
    Hey guys, I just bought a used Prius. Obviously I'm trying to do some minor tweaks to make it look as good as new. One of the most visible things was discoloration of these Gasket-ish things in between the door and around the wheel wells. I've looked at multiple Prii and they don't even have them.
    My questions are:
    -Did the previous owner put those on themselves?
    -Is this done often? If so, where can I get new ones?
    -Are they necessary? Thanks!
    ~Cassie
  2. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    They are a dealer installed accessory - color matched door edge guards. Some dealers install them on all the vehicles on their lot, so they can charge the customer a little bit extra. You can remove them, or you can replace them. Up to you.
