Prius Plug-in Hybrid Concept Debuts at Frankfurt Motor Show
Discussion in 'Gen 3 Prius Main Forum' started by classic, Oct 19, 2009.
  1. classic
    classic Junior Member
    16
    Pennsylvania, USA
  2. classic
    16
    Pennsylvania, USA
    The Prius Plug-in Hybrid (PHV) Concept made its long-awaited debut on Tuesday, September 15, at the Frankfurt Motor Show. In late 2009, 500 PHV test-fleet vehicles will roll out globally, with 150 of those vehicles coming to the United States for testing under a variety of driving conditions and scenarios.
    The PHV Concept, based on the 3rd-generation Prius, utilizes first-generation lithium-ion battery technology and enabled electric operation at higher speeds and longer distances than conventional hybrids. When fully charged, the vehicle is targeted to achieve an electric-only range of approximately 12 miles and will be capable of achieving highway speeds in electric-only mode. For longer distances, the PHV Concept reverts to "hybrid mode" and operates like a regular Prius. This ability to utilize all-electric power for short trips or hybrid power for longer drives alleviates the issue of limited cruising range encountered with pure electric vehicles.
    Photo credit: Corporate Communications, Toyota Motor Sales, U.S.A., Inc.
    Concept vehicle shown.
  3. asj2009
    asj2009 Member
    224
    56
    I'm going to kick myself in the a** for buying this year if they roll out this plug-in vehicle next year :D
  4. classic
    16
    Pennsylvania, USA
  5. asj2009
    asj2009 Member
    224
    56
  6. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Hey Prius Team - I'm the perfect candidate to test this car for you! With my short commute I'd never use any gas. :cool:
  7. DanCar
    DanCar New Member
    117
    What happens to the gas in the gas tank after sitting there for a year? I've seen my lawn mower spare gas looking very nasty.
  8. asj2009
    asj2009 Member
    224
    56
    and what happens to your electric bill after plugging this car everyday to recharge?
  9. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    It goes up of course. And guess which bill plummets (Hint, gas)
  10. asj2009
    asj2009 Member
    224
    56
    The question then becomes, so how much is the net savings after weighing the two?
    And also, switching from using oil to dirty coal as the source of the car energy surely isn't too smart, unless we can get more renewable energy as the source of the car electricity.
    Also, no one has yet figured out what might happen to the grid when a substantial portion of the population plugs into it at night (usually an off-peak time). More blackouts? Brownouts?
  11. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    Hopefully, Toyota will offer upgrade kit for our 2010s. :)
    Is it only battery & s/w upgrade? Or the electric motor and alot of toher stuff need upgrading too. :eek:
  12. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    Absolutely good comments. As for the cost, a friend and I were discussing the cost per gallon equivalent of electric vehicles and at the time (last year) it was around $0.25 per gallon equivalent.
    As far as renewable energy, something has to be done to replace our aging and antiquated energy system regardless if cars are going electric or not. Any cheap domestic renewable energy source would be a good thing for the automotive industry.
  13. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    I promise to occaisionally travel further than 12 miles. :D
    As someone else pointed out, most people that have done the caluculations come out with a much lower cost.
    FYI, down here in Texas we get to choose from a wide variety of possible electricity providers, including all wind providers. We also have a nuke down here. Dirty coal is not the most prevalent source down this way. I also buy into the argument that a single source power plant is much more suceptible to pollution controls than multiple car sources.
  14. esoniat
    esoniat Junior Member
    79
    Marietta
    I haven't seen the grid capacity addressed but gasoline distribution and combustion verse coal has been studied and there is a net gain so society will probably benefit from plug ins assuming the actual car manufacturing does not get to negative.
    Our grid is in bad shape. This certainly will increase the load but it also might increase the attention. Might make a good case for having a plug in hybrid until the grid has proven its capabilities. After all it always makes sense to have a backup.
  15. robinson
    robinson Junior Member
    31
    DC
    As this thread is about plug-in cars.... WOOOOT! GO PLUG-IN!
    The real question is when can I get a conversion kit for my '10 prius??
    Somethings really bugs me, so here goes... Since i really don't want to argue, I'll post quotes and links from various 'sites. If you disagree -- go argue with that website, not the messenger.
    That is misinformation.
    Surprisingly, many people forget several things.
    1) [ame="http://en.wikipedia.org/wiki/Economy_of_scale"]Economies of scale[/ame]
    For example: A .01% improvement in the production/process of power generation would result in a 10%+ improvement for the end user -- as opposed to a .01% improvement at the end user is still just a .01% improvement.
    2) It's significantly easier and more cost effective to clean-up the gunk from ten sources than from 10.5 million sources.
    3) Any sort of power plant is going to be significantly more efficient than an Internal Combustion Engines. (ICEs are only ~15% efficient.)
    4) Not all electricity comes from coal plants.
    - Hydro
    - Natural Gas
    - Oil
    - Wind
    - Geothermal
    - Nuke
    - Check it out
    Unless you live in Appalachian Mnt. region, you don't even use coal! With very few exceptions, see the map for more details.
    I'm not disagreeing that coal is horrid, it really is! However, where I find insulting is your presumption that we use coal as a primary power source in the US. (Only one region in the US actually uses coal as it's primary source.) You might as well claim that we still live in the Stone Age...
    Even if we use 100% coal power, getting away from using the ICE is an enormous step in improving things. This is based on the logic that 20,000 efficient power plants are better for us than 143,781,202 really, really inefficient cars.
    It would still be an huge improvement even if those power plants ran on the blood of virgins.
  16. Tad Moody
    Tad Moody New Member
    35
    Duarte, CA, USA
    Isn't a plug-in hybrid a "tri-brid"?
  17. asj2009
    asj2009 Member
    224
    56
    No, actually, that's my opinion. I wasn't saying switching to electric vehicles is bad, I was suggesting we could do more.
    agreed.
    I suggest looking at that map again, because if you selected COAL in the drop down, it'll show the vast majority of states use coal as their primary energy source, with the main exceptions of the California area and the upper upper north east.
    That's because we do. Coal is the single largest source of electricity for the USA, contributing 50% or more of the total.
    Btw, if you've ever been to areas with very high coal usage you wouldn't keep thinking coal is so much better than ICE. In fact, a study done earlier this decade concluded the damage done by coal fired plants in the US amounted to about $62 billion per year, while the aggregate vehicles amounted to about $56 billion. So, the sooner we can clean up coal generation or switch to other sources, the better, before we replace damage via ICE with coal-damage as electric cars come into play and more demands are placed on the grid.
  18. drees
    drees Senior Member
    1,782
    247
    While it may be the largest, it's under 50% and falling every year for at least the past 20.
    Electric Power Monthly - Table 1.1. Net Generation by Energy Source
    Natural gas (much cleaner and much more efficient) and renewables are growing significantly to take market share.
  19. asj2009
    asj2009 Member
    224
    56
    exactly my point. we should continue to push non fossil fuels as the main source of electricity before cars start piling up onto the grid.
  20. drees
    drees Senior Member
    1,782
    247
    If we wait until the grid is "perfect" we'll never get there. Just like if we wait until EV tech is "perfect", we'll never get there, either.
    Even with the current grid mix, EV/PHEV is a huge win over oil. You miss the point completely.
